Benefits of an LSD, advice please
1 Post
C63 AMG
I think it comes down to if you track more than 2 times a year and you track HARD(and i mean hard) then you would definitely want an LSD. Cause from tracking my non-LSD C63 for couple of times I find that its very hard to put the power down coming out of the corners.
For everyone else LSD is basicly useless.
1 Post
2011 Ultima GTR
I'd break it down like this, and it really comes down to driving style in the end and what people do with their cars.
You would enjoy an LSD: If you track (circuit/hill climb) it or are a bit of a hoon (even a little) on the road. If you look outside when its raining and think "yay!". If an empty car park in the middle of no where looks tempting when road tripping across the country. If you enjoy the 3h mountain drive (which you turned into a 1.5h drive) to a ski resort more than the resort itself. In all these instances, you will not regret buying an LSD.
If none of the above sound like your cup of tea, you probably wouldn't benefit from an LSD.
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
#32
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
By "different car" I meant driving dynamics of the car, tendency to oversteer or understeer, weight distribution, and so on.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
#33
'09 C63 AMG
There is nothing to be sorry about. My C32 puts down 370 lb-ft RWTQ on a Mustang dyno and a 1/4 mile (straight line) in 12.52 secs. With an LSD. ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
By "different car" I meant driving dynamics of the car, tendency to oversteer or understeer, weight distribution, and so on.![slap](https://mbworld.org/forums/images/smilies/slap.gif)
+1. Yep. That's me.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
+1. Yep. That's me.
FWIW, I ran 12.4 sec. @ 115mph (with a cruddy 2.048 sec. 60ft.) my first time running my the 1/4mi. in my C63...with shot rear street tires and without an LSD.
#34
'09 C63 AMG
#35
Quaiffe makes an excellent LSD. I have not tried it on the C63 but I have had a few of them over the years. This is their world and they know it well.
Brian is this a bolt-in replacement?
I've heard that the Kleeman LSD is an excellent price but I don't know the features or durability. It appears that you also have to send them your differential and they actually modify it. Any Kleeman reps out there to confirm?
Anyone know what's the locking % is for each?
#36
2012 E63 PP, 2012 Ferrari 458, 2012 Boxster S
I do not agree with the sentiment that LSD is only for hard core track use. I tested both with and without LSD before ticking the option off and there was a noticeable difference when simply powering out of corners. Without LSD the inner tire would constantly spin. With LSD I spin a lot less (and I can of course power slide out of corners with both wheel spinning provided enough juice
Ken
#37
DRs...absolutely yes (on any car for that matter), LSD...not so much, imho. But, I do not have an LSD and haven't driven a C63 w/ an LSD, so I do not know for certain. But, as others have said, the LSD doesn't seem to matter all that much, especially when comparing launches and 1/4 mi. ETs and Traps.
I would have to absolutely disagree there.....An LSD and drag radials make a huge difference.....
If you're limited to only a 1400 RPM launch and your boost doesn't hit until after that, then sure maybe you wouldn't see a difference....
But if you're a C63 with Traction Control off there will definitely be a difference.....
That's why pretty much every serious drag racer has a locker or at least an LSD.....
It's common sense that when both tires hook you leave harder and quicker
#38
C63 AMG, BMW 135i
Ken
I agree. Having tested with and without back to back, I also noticed a big difference in the way the two dealt with tight corners. Still if you’re not into spirited driving, you’ll never miss the LSD.
#39
LSD produces hallucinations and there is no way to anticipate whether the "trip" will be a good or a bad one prior to use. A trip can last for several hours. This drug also makes the pupils dilate, increases heart rate and blood pressure, and causes dryness in the mouth. Insomnia and tremors are common effects of LSD use. Some users feel paranoid or anxious while under the influence.
On the side note, My car came with LSD and the best I have used it for was a track event and perfect donuts!
#42
GF
#43
2016 C63s AMG
How does a stock LSD affect traction/ESP. Does the ESP still try to correct tail spin? If its raining and you have ESP on and you floor it will the car be all over the road or does it correct its self?
What about an after market LSD like renntech that has 100% lock up. How does this affect the traction/ESP.
Basically what I am trying to figure out is, with an LSD can I drive the car in the rain and still have ESP woking for me?
Ive test driven a C63 with out LSD and the ESP was constaly correcting the car which made me feel secure. I cant find any with LSD to test drive.
#44
I'm driving in a very wet and right now very cold/snowy environment. With the right tire setup the car is very stable in any environment really. Just don't turn off the ESP completely
Ken
#45
2010 C63
I have just over 3,000 miles on my C63 - the first 1,600 miles without a LSD and the rest with a locking LSD. I just do not understand why this car does not have an LSD standard. Even around slow corners in town the car without the LSD would spin wheels with just a little rain or dirt on the road -- with the LSD, there is far less wheel spin and fewer blinking lights. Even if you accept that an LSD provides only marginal improvement to acceleration on a smooth, clean, straight, rubber-coated track, it will help a great deal on any road that is dirty, wet, bumpy, twisty, dusty, or some combination of these -- that is, 97.5% of roads. In fact, I really noticed how well the LSD worked as I accelerated with one wheel on the rumble strip back onto the interstate after a nice talk with with Trooper H yesterday (I shouldn't have waited on the Passport 9500ci). ![slap](https://mbworld.org/forums/images/smilies/slap.gif)
I would highly recommend an LSD. A Quaife unit, installed, is about $2,000 (assuming 7 hours labor at $100). A modest sum compared to the price of the car.
Some will say that you could get by without one if you drive like Granny (and they may be right), but I can't remember the last time I saw Granny driving a C63. I think Trooper H would agree with me on this point.
#46
Think of it this way: a LSD isn't necessary to sell the car. But if a consumer really wants a LSD then it's available through an expensive (and very profitable) option package. It's a win for Daimler AG and their shareholders.
#47
2016 C63s AMG
Absolutely. The LSD option does not in any way interfere with your ESP. If anything it helps in situation where you are on slick surface with two wheels and dry with the other two. Without the LSD I would veer slightly to one side before the ESP cut in. With the LSD I feel that the direction of the car is more stable.
I'm driving in a very wet and right now very cold/snowy environment. With the right tire setup the car is very stable in any environment really. Just don't turn off the ESP completely![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Ken
Ken
#48
LSD option for C63
Hi there,
Just purchased a C63. Would be a proud owner-but instead of waiting 4 months for a car to come in with the LSD option, i bought one "off the floor".
DISASTER. After hearing the sales man tell me that they never sell this option....bla bla bla..just so he could sell the car on the floor, i am bitterly disappointed.
The inside wheel spins if i so much as break wind near the accelerator when going around a corner. Ofcourse the traction control kicks in...and then its all over. Thats in the dry. In the wet..better drive like your on Vallium.
Unless your some kind of freak, who ONLY bought the C63 for the sound it makes..and not the stonk...this is not an option-its a necessity.
Sitting here listening to people say its only required if you use the car on the track....etc etc. No chance. THis is required....if you use the c63 as a daily driver. Its required if you EVER like to give it a "Squirt" or take someone on the inside lane at the lights.
How an LSD is considered an option on a C63 is beyond me. Its an utter disgrace.
Anyway, now im told Bavaria Cars in Gladesville Sydney will install a Drexler LSD for $6K. Im about to book it in.
Does anyone have any info on Bavaria cars or any other reputable diff installers, that can install the Drexler and are 100% trust worthy. I've never done an aftermarket mod and im hesitant...with my new baby (actually i call her a tart until i get the diff installed).
Cheers
Jo
Cheers
Jo
#50
LSD on C63
Totally agree 101%!
In other words, if you bother to buy the top donk...you need a LSD.
Incidentally, i used to own an E55 and it would blow my new C63 to shreds...especially at 80km/h kickback. Why have Merc gone backwards?
Guess thats why the 63 engine is the most shortlived ever in the Merc Range, with the twin turbo V8 destined for arrival later this year!
