C63 AMG (W204) 2008 - 2015
Has anyone found any AMG door lock pins?
Old Mar 12, 2010 | 04:54 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Originally Posted by Sincity
Tks!
Shop Foreman says its easy. Fronts screw off and rears he says will either PULL and TWIST half turn or PUSH and TWIST half turn.
Old Mar 12, 2010 | 05:46 PM
Jae Duk's Avatar
'09 C63
I thought for the rears you had to take off the panel? That seems to be what everyone is saying on the w204 section.
Old Mar 12, 2010 | 06:45 PM
Definitely did not remove the panels in the rear.
Old Mar 12, 2010 | 07:13 PM
PatSC23's Avatar
2009 C63
Wait...so where are the pics?
Old Mar 12, 2010 | 07:39 PM
Ok ok... Give me 5 min
Old Mar 12, 2010 | 08:03 PM
Rear Install simplified
1) Unlock your rear doors.
2) Pull and twist to remove OEM Plastic Pin. Tip pull up as straight as possible
3) Install Stainless Steel AMG Pin (Female) over OEM plastic (Male) base Pin
Its that easy
Attached Thumbnails Has anyone found any AMG door lock pins?-oem-ss-pins-rear.jpg   Has anyone found any AMG door lock pins?-rear-oem-ss-pins.jpg   Has anyone found any AMG door lock pins?-oem-rear-pin-removed.jpg   Has anyone found any AMG door lock pins?-rear-ss-pin-installed-unlocked.jpg   Has anyone found any AMG door lock pins?-ss-pin-locked.jpg
Old Mar 12, 2010 | 08:05 PM
  #32
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
3) Install Stainless Steel AMG Pin over OEM base Pin
Its that easy
Thanks, N44.
Old Mar 12, 2010 | 08:07 PM
  #33
PatSC23's Avatar
2009 C63
Its that easy
Thanks - so I guess those other guys were removing the whole assembly
Old Mar 12, 2010 | 08:16 PM
  #34
Not sure why you would remove the whole assembly...
Old Mar 12, 2010 | 10:37 PM
  #35
Sincity's Avatar
Tks North! Since the rears slip over, do you see a gap when the pin is in the unlock position?
Old Mar 12, 2010 | 11:09 PM
  #36
Tighter than original. Great fit.
Here is another shot
Old Mar 13, 2010 | 01:08 AM
  #37
Sincity's Avatar
Sorry. I meant the rears in fully up position.
Old Mar 13, 2010 | 07:23 AM
  #38
Sin. That last shot is of the Rear Unlocked. No gap. Caps extend abot 1/2 inch into the door panel when unlocked
Old Mar 13, 2010 | 09:57 AM
  #39
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
So to be clear - pull up very straight while twisting 1/2 turn to remove them?
Old Mar 13, 2010 | 10:02 AM
  #40
Yes. You could forego the twist but it helps unseat the OEM PIN. Coming straight up keeps the under pin in good shape to accept the new cover and keep it tight. One of my rear pins was a little loose and the dealer added a tiny strip of cotton tape to 1 side of the head just to snug it up.
Old Mar 13, 2010 | 10:10 AM
  #41
Awesome - thanks.
EDIT: Wow - took me literally about 2 minutes, including the time to turn on the car, listen to the cold start & smile, roll down the windows, then pop off the plastic pins and install the AMGs.
Old Mar 15, 2010 | 08:15 AM
  #42
racetested's Avatar
08 MB
People like myself were originally removing the door panels and modifying "longer" door pins to fit flush.
Looks like these current pins (which were not available 1-2 years ago) were finally designed to eliminate all the extra steps needed to work properly.
Old Mar 15, 2010 | 10:47 AM
  #43
Got ya...
Old Mar 15, 2010 | 11:06 AM
  #44
Jae Duk's Avatar
'09 C63
In other words now is a good time for the purchase.
Old Mar 15, 2010 | 11:40 AM
  #45
jackrycheung's Avatar
2009 Fully loaded C63 AMG - black on black and CF trim; 2006 Lexus IS250 AWD;
Hi Barry, can you please post some pictures of the rear wheels taken from the back, I am interested to see how -2 camber settings look like. Thanks in advance
Old Mar 15, 2010 | 12:07 PM
  #46
Sincity's Avatar
Thanks Barry!
Old Mar 15, 2010 | 03:26 PM
  #47
PatSC23's Avatar
2009 C63
So now I have to spend $200 on 4 door pins - damnit. I had just convinced myself doing the front 2 was good enough!
Old Mar 15, 2010 | 08:00 PM
  #48
Sincity's Avatar
Go spend some time in the back seat if you need an affirmation.
Old Mar 15, 2010 | 10:27 PM
  #49
danielemccabe's Avatar
2010 C63 P31, 2003 C32
Yeah Pat, time to spend the cash on the pins, the stocks are just too hideous. i get my car on thursday or Friday and my dealer is putting them on . best 200 i'll spend on the car.
Old Mar 15, 2010 | 11:03 PM
  #50
Jae Duk's Avatar
'09 C63
Why spend time sitting the back seat if you can be handling the beast
