Has anyone found any AMG door lock pins?
believe me I know - I posted a thread like 8 months ago on how cheap these things look - what a disgrace
Cause the rear is not screwed in
For those yet to try it, very easy. I couldnt get a grip on the fronts to twist so I wrapped them in a towel and use pliers to twist them off. Fronts screw right on (although I had trouble with one side...it didnt want to twist much the first 2 tries but the third time I got them both to the same height)
As for the rear, they just pop right off. I didnt even twist. Theyre held in by just a little ball socket. I wrapped it in the towel and used the pliers just pulling straight up.
i chose NOT to use any glue to hold down the rears because I want to remove them to sell wen I get rid of the car.
Hint - as someone else said, unlock the doors - but also roll down your windows, you'll have more room to work with.
All in all 10 minutes.
Also, for the rears - wen u put them on, push down and lock it to secure it down.
Its an expensive mod considering how small the parts are, but well worth it imo.
as for the fronts - unlock the doors, unscrew oem pins. then screw down in unlock position. It should stop or start to get tight about 3/4ths of the way down
