C63 AMG (W204) 2008 - 2015
Straight pipe's for 2nd cats or resonators??
Old Feb 25, 2010 | 11:04 AM
white_beast's Avatar
C63 AMG
Hey guys just wAnted to know straight pipes instead of the 2nd cats or resonators!?? And Which gives me more gains taking out resonators with straight pipes or taking out 2nd cats with straight pipes, plus I have the k2 so want the most of it!! Thanks...
Old Feb 25, 2010 | 02:06 PM
Dads C63's Avatar
2014 Audi RS7
You will definitely see more gain by losing the secondary cat. I do not suggest removing the resonator because the stock resonator has the crossover pipe integrated into it. That crossover balances the two banks. Just my suggestion.
Old Feb 25, 2010 | 02:12 PM
avengerboater's Avatar
C63 AMG
I second the secondary cats removal. Removing the resonator will be obnoxiously loud. No offense, Keith.
Old Feb 25, 2010 | 02:14 PM
Dads C63's Avatar
2014 Audi RS7
No Offense taken. Trust me, when I'm not at the track the stock resonators and exhaust goes right back on. Takes about 1/2 hour to exchange out.
Old Feb 25, 2010 | 02:39 PM
Sincity's Avatar
Do you have a lift at home? That would be awesome!
Old Feb 25, 2010 | 04:02 PM
Dads C63's Avatar
2014 Audi RS7
Nope, back it up on ramps here at the office and can change it in 30 minutes. Since it bolts on its really very simple with hand tools.
Old Feb 25, 2010 | 04:19 PM
clktoc63's Avatar
'09 C63 Performance Package - Steel Grey/Sahara Biege
If you have K2, why not take off both cats and leave in the resonator? This is essentially what most folks would have running the LT headers right? I assume with the K2 programming you'll pass emissions tests either way...and without the program, you'd fail either way. Why not go for the extra horsepower?
Old Feb 25, 2010 | 06:33 PM
miami1lt's Avatar
'09 C63 AMG, '10 ML350 4Matic
Can you pass emissions with cat deletes? Even though no CEL, I still would think the emissions folks will know you don't have cats and fail the vehicle...not that it takes much to reinstall for an annual thing...
Old Feb 25, 2010 | 06:43 PM
clktoc63's Avatar
I've been told if I'm in a state where the emissions test is the OBDII test, passing emissions should be no problem with a Kleeman tune and cat delete. The secondary O2 sensors need to be plugged in for the ECU to see a signal, but it won't matter what the signal reads.
Old Feb 25, 2010 | 06:53 PM
C63 AMG
Thanx for ur suggestion man I know that's the best way for free flowing the exhaust and givin more power so I guess I'll do that!! so what bout sound how is Gina be really loud or slightly louder!??
Old Feb 25, 2010 | 06:57 PM
C63 AMG
So I guess I'll replace the secondry pipes with straight pipes and hope fully have more power and hopefully not get any check engine lights!!
