Kleemann ECU upgrade. Who to use
mb e63
I am thinking of doing a stage 1 Kleemann upgrade before I put my new c63 on the road....This will done by sending in my ECU by Fed Ex. What tuner would you use. Thanks...........
2009 C63
If you're doing a Kleeman K1, I'm assuming you'd be using Kleeman as a tuner?
If you're trying to decide which ECU to do, there's threads on it and it's mostly preference. Personally I don't think you can go wrong any of 'em. Good luck.
CLS63
Give James at ACG a call. I think they now also have a New York location. ACG is a sponsore on this forum ..
If you have someone local that has the equipment to flash it, then use them. We don't have anyone here in Vegas so I just sent my ECU to Cory @ Kleemann. Sent it in Monday afternoon and got it Wednesday.
If the dealer does the re-flash do you think MB will still honor the warranty if they find out it has a dealer re-flashed PCM in the car? I don't think MB will be required to honor the warranty any more than a re-flash from any other aftermarket vendor. Your only hope might be that the dealer will work with you and not disclose the fact to MB. If MB does find out then I think you and the dealer will be in deep dodo.
False security?
False security?
If you subsequently lose an engine or a transmission and MB declines the warranty because of arguments about the tune then do you really think the dealer will or should come good for it? I think I would want to know in advance and in writing.
Former Vendor of MBWorld
Whatever we're tuning!
Congrats on your new found power Jeff.
Filters will be delivered tomorrow and then I will tell you how to do that custom airbox mod!
Next up Quaife ATB LSD!!
Enjoy!!
Enjoy!!
I'd let the car sit while the ECU was flashed back to stock, and then take it for repair...
Don't ever take a car into a dealer with an upgraded ECU...that is the easiest thing for them to find fault with...
Unless is on writing(like you said) I wouldn't trust them, they are risking potenmcially lossing a lot of money on repairs.
https://mbworld.org/forums/c63-amg-w...mystified.html
Are you talking about removing the charcoals? Because the only "custom" thing I see you can do to a NA airbox top is to remove the funnels and replace with custom made/cast Euro funnels.
Thanks for the pictures!
