C63 AMG (W204) 2008 - 2015
C63 Oil Change w/ Mityvac :: Write-up and Photos
Old Feb 10, 2017 | 12:03 PM
  #176
Mr.McGibblets's Avatar
2013 C63 AMG Coupe
Originally Posted by AhhMyyGawd
The real questions is, why do your own oil change if you get free maintenance?
Because it's allegedly been 6,000+ miles since the last one, the next one isn't for another 250 days, and I don't like to go the full 15k miles (or whatever the default interval is) between changes.
Lastly, I examined the oil and it's pretty dark and in my opinion, needed to be done now (which set me back just $60). Cheap insurance.
I did take a sample and am sending it to Blackstone Labs for testing.
Old Feb 10, 2017 | 01:09 PM
  #177
AMG3.2's Avatar
C63 AMG, P30
But anyway, thats a good question. Assuming the previous owner did the service A at 10k miles, I would just reset it and maybe go in early for the next service. Best bet though is call the service center and ask a technician.
Cause no one touches my cars besides me...
Old Feb 10, 2017 | 01:36 PM
  #178
skratch77's Avatar
2005 E55
would it be better to suck the old oil out with the engine cold and sitting over night? if you start up the car you will get oil circulating everywhere and not get all the old crap out.
only issue is that first dry start up with new oil.maybe let the car warm up and then wait 45 min after to suck it out?
Old Feb 10, 2017 | 01:42 PM
  #179
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Honestly it's super cheap and easy insurance to lower that change interval to 5k miles IMO. Blackstone analysis is fine to do, but 15k can't be good regardless of the results.
This. After a drive, let the car sit for 30min, then do it. Warm oil is easier to pump out.
Old Feb 10, 2017 | 02:22 PM
  #180
604 C63's Avatar
2012 E550 Cabrio
"Super regular" oil change will save you multiples of whatever it may cost you, even if for no other reason than catching any issues earlier.
Old May 5, 2018 | 12:55 PM
  #181
Steiner's Avatar
'15 AMG GLA45
Just ordered mine. Last oil change they left the hood unlatched and the filler cap on the strut tower. Never again!
Old May 5, 2018 | 02:43 PM
  #182
El_Panteras's Avatar
2011 C63 AMG
This is fantastic, I am about to perform the oil change for firts time on my own.
the dealership told me the C63 AMG takes 10 quarts, but you use 9.
I'm not sure if I should use 9 or 10 based on the dealership recommendation.
also, can I use Royal Purple 0w-40 or should I stay with the mobil synthetic oil?
does the Mityvac will drain the oil cooler as well?
thansk
Old May 5, 2018 | 02:47 PM
  #183
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
thansk
Don't listen to the dealer, read the manual: 9 Quarts including 0.5 Q for the oil coolers.
Old May 5, 2018 | 03:11 PM
  #184
2011 C63 AMG
Hey Critter, after you performed an oil change, how do you reset the service board or messege in the dash?
do I have to take it back to the dealership for that?
Old May 5, 2018 | 03:13 PM
  #185
2011 C63 AMG
thank you surge,
what about the service messege, how do i reset it?
do I have to take it to the dealership for that?
Old May 5, 2018 | 03:17 PM
  #186
Surge's Avatar
thank you surge,
You reset it yourself. I don’t remember the exact key presses, but it’s on YouTube or this forum.
Old May 5, 2018 | 03:25 PM
  #187
2011 C63 AMG
Thank you,
I will look it up on youtube.
regarding the oil amoun, I figured the dealership charge 10 quarts when they only used 9....
Old May 5, 2018 | 03:34 PM
  #188
Surge's Avatar
Probably. Most dealers will rip you off any way they can. If you don’t drain the oil coolers, it’s 8.5Q.
Just put back what you took out. Then check the oil level and add more if necessary. Unless you took out more than 8.5, in which case you had too much.
Old May 9, 2018 | 09:40 AM
  #189
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Keep in mind that the oil cooler holds just less than a quart of oil, that can't be removed by using any suction device.
Old May 9, 2018 | 09:44 AM
  #190
Surge's Avatar
Oil cooler holds 0.5 quarts, as per my last post.
I don't worry about - the car burns enough oil during the year that you are effectively replacing it with new oil. I easily put in 2 quarts a year during the year. Per the owners' manual, it can burn a lot more than that.
Mercedes HQ in Canada has a dealership in their lobby. The AMG techs suck the oil out there as well. They don't drain it from the bottom, and they don't drain the oil coolers.
Old May 9, 2018 | 09:51 AM
  #191
BLKROKT's Avatar
A half quart of old oil mixed with 9 quarts of new is 100% totally fine. Zero need to drain the cooler manually, that’s just over the top OCD. I like all those plugs factory tight and intend to keep them that way.
Old May 9, 2018 | 09:56 AM
  #192
Surge's Avatar
Agreed! When the head office AMG certified tech doesn't drain from the bottom, that totally convinced me.
Old May 9, 2018 | 10:29 AM
  #193
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I drain almost 1L out of my cooler and the pan almost 8L. That's a lot of used dirty oil to mix with fresh new stuff. AMG certified techs are allowed to be lazy...
Maybe this is a reason why some owners are having bucket wear issues?
Old May 9, 2018 | 11:55 AM
  #194
Yuille36's Avatar
I totally agree, and maybe I have OCD. This is the way I've always done and will continue to do it.
I've never had any issues with bucket wear issues, as confirmed by the recent valve cover gasket replacement.
People are free to do what ever they choose to do, it's a free country.
Old May 9, 2018 | 09:59 PM
  #195
FactoryFast's Avatar
2014 C63
I have the dealership do the oil changes every 10,000 miles to keep it dealer documented and serviced. In addition, I do the oil changes every 5,000 and send that sample out to Blackstone. Im using the pump and the method. Easy. I bought the car with 2700 miles on it so im keeping a fairly comprehensive record of the engines metallurgy.
I bought this vacuum pump and donated it to my local shop which is also where I bring my used oil to. They use that thing all the time and 1.5 years in, its still going strong. I highly recommend the pump. Im doing the Blackstone thing but really thats just gonna tell me if I need to trade the car in so I dont have to deal with the drama.
