perfect upshifting points
I am just wondering on this tranny was is the best upshifting point? and what is the best mode to be in.
I mean I have driven my buddies C63 and it seems that off 1st when the dash flashes red its a good time to shift. But when after that it seem different.
can you anyone shed some light on this?
I'm so suprised how well the car shifts in Sport mode under hard acceleration. I did a 0-60 start with my friend (a car buff) and he said to me: "did we just got from 0-60 in 1st gear?!" I mentionned the car shifted but we don't feel the upshifts, that's how great the transmission is...
I don't see how you can be as efficient as the auto transmission in a straight line. However, with road curves and race tracks the paddle shifting can be very useful!
If anyone does have the best shifting points let us know =)
how about when your in a comparo run form 50mph and up ? still the sport mode is the best?
I have heard that if turning off the traction control can be of a great help.
but then again I am not 100% sure.
I have a VW with DSG and is also faster than the C63 AMG. I was honestly hoping for a better transmission(faster shifts). I think the AMG is very smooth and sily and I am sure it can handle a lot of torque but honestly it is slugish.
As per your friend "not feeling" when the car was shifting is just an exageration. I can understand the 0-60 coming fast but not "knowing" when the car is shifting is non sense to me. You can always hear the tone of the engine changing rpms when shifting..
Also, I don't know about the rest of you but with S mode I can definitely feel the hard shift points. Are the rest of you not sensing it that much?
I've had a few rare occasions where I felt I shifted faster in "M"...the problem is that you have to click it a second before you want to shift...while it shifts 30% faster than "S", that isn't from the time you pull the paddle, it's the actual changing of the gears that's faster. For the most part, I use "S" off the line, but "M" if I want to race from a set speed...you don't always get the kick down you want in "S" (ie. it'll only drop to 3rd when it could have gone to 2nd).
On a side note, I punched it the other day in "C" (didn't know I was in comfort), and on the highway, it took FOREVER to shift...I know it is supposed to, but I was like What the HELL!...then I looked down and saw that big "C" staring at me...WHOOPS...you can definitely feel how slow that is compared to S or M.
"M" mode is different than the other modes shifting and sound ... that what I can fell on my car
But I don't know about perfect upshifting ..
True...I used "C" mode today on the way to work just to see...I was on the AMG screen watching the shift numbers...it literally went from 5-6-7 without any feeling of a shift whatsoever...in S-mode, that doesn't always happen.
As far as optimum shifting, "S" is the best..."M" is ok if you time it right, but takes way too much work to drive and make sure you click by 6.4-6.6K RPMs...if you don't hit it then, you'll hit rev limiter...
And even when I've hit rev-limiter in "S", it keeps plowing quickly into the next gear once it shifts.
Now if only I could launch...my best time using the timer in the AMG menu is 4.67s to 60mph...I know the car is capable of much faster...I just can't seem to feather the throttle the right way.
Overall, it is a great tranny.
One thing I don't like is sitting at a stop light and cycling from "M" to "S"..because you have to cross "C" which puts it into 2nd gear and gives a clunky jolt...I wish you could get "C" out of the mix, like in the E where "M" is in the middle of a selector know...not a push button.
