OEM tire sidewall height questions
In any given tire size, there are 3 measurements given, tire section width in MM, the aspect ratio, and then the wheel diameter in inches. So for example: 235/35/19. The example tire is 235mm wide, has a tire sidewall height that is 35% of 235mm, and goes on a 19" wheel.
The reason the aspect ratio's are different front and rear on a C63 is because it has a staggered setup. The front and rear wheels are the same size (18"). The front tires are narrower than the rear tires however. Due to the added width of the rear tire, the ratio of that width must be smaller to maintain the same overall sidewall height.
Ex: 255 X 0.35 = 89.25mm sidewall
235 X 0.40 = 94mm sidewall
in this example a 265/35/18 tire would have been closer to the 235/40/18 front tire, with a 92.75mm sidewall.
And if you want to stay true to the design and engineering of the car, find the detailed specs of the OE tires and then find tires that best resemble these specs.
For example, regardless of any of these numbers, you must match tire circumference to that of the OE. Every tire has a different value for revs per mile. OE for C63 is 827 front and 826 rear. If your replacement tire is a higher number for the drive (rear) tires, your car accelerates slightly faster, but your speedo and odo will read faster than your actual and vice versa.
I am often baffled by how people just change their tires to a wider one without considering the side effects. There is actually an aerodynamic disadvantage in going with wider tires while the actual traction does not improve based of the laws of physics.
Round up to the nearest hundred..sometire have more tread and some are wider than other.
Exemple size; 235/40/18
25.4mm=1"
235x.40x2/25.4+18=25.40"
Time to bust out the physics book...your traction argument may hold true only if you are comparing identical materials. Different tires have different friction coefficients. Wider doesn't automatically mean better traction.
My only valid reason for going wider is the looks...I have to be honest!
