C63 AMG (W204) 2008 - 2015
Lug nut torque?
Old Mar 23, 2010 | 10:41 AM
peh-amg's Avatar
'13 Audi RS5
Lug nut torque?
Does anyone know what the torque spec is for our lug nuts?
Old Mar 23, 2010 | 10:48 AM
benyl's Avatar
'10 F150 FX4 SCrew. '14 S212S
96 lbft
Old Mar 23, 2010 | 10:50 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
I believe OEM Spec is 96 lbs as per the Lug Torque chart in the spare box that came with the car.
I twist mine to 130.
Old Mar 23, 2010 | 11:12 AM
peh-amg's Avatar
'13 Audi RS5
Thanks guys.
Old Mar 23, 2010 | 12:16 PM
lebreeze's Avatar
2014 991s, 2015 macan turbo, 2018 c63s
Great timing I'm putting my summers back on tonight and I wasn't sure.
thanks
Old Mar 23, 2010 | 02:04 PM
peh-amg's Avatar
'13 Audi RS5
thanks
Yeah, I just finished putting my summers on this morning. Good to back on summer tires finally!
Old Mar 24, 2010 | 04:00 PM
PatSC23's Avatar
2009 C63
I wish...the roads near me are still crap
Old May 19, 2010 | 06:30 PM
wuyichao's Avatar
C63
sorry for ressurecting this thread.
I tried to search for the socket size for C63 lug nut and socket size for engine oil cap, but I couldn't find any. So does anybody know?
Thanks in advance!
Old May 19, 2010 | 07:19 PM
x838nwy's Avatar
n/a
Is there a reason why you tighten it to 130lb-ft rather than the recommended value? It is a common (and very dangerous) misconception that the tighter the better. This is entirely untrue.
The recommended value is there to achieve the correct amount of grip/stiffness/life on the nuts and studs. Over-tightening can cause stud breakage. As an engineer, I am quite sure the m-b value is there for a reason and has taken into account load cycles, part life and of course safety.
Most of the time, however, the recommended torque can seem a little low. This is mainly because if the threads are not clean then the recommended torque is sometimes barely more than the resistance of the (dirty) bolt/nut thread interface.
I strongly recommend removing the nuts, cleaning the threads (on both male and female parts) thoroughly and tighten them to the recommended value. Needless to say, please follow the correct sequence when doing so.
I have actually witnessed three different occasions where wheels have come off a car (twice on-track) because of some enthusiastic nut-tightener.
Old May 19, 2010 | 07:28 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Thanks in advance!
It would probably be faster to go through your socket set and do trial and error.
Old May 19, 2010 | 07:35 PM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Thanks in advance!
Here -> https://mbworld.org/forums/3967467-post52.html
Old May 19, 2010 | 08:02 PM
avengerboater's Avatar
C63 AMG
Thanks in advance!
The lug bolts are 17mm.
Old May 19, 2010 | 08:39 PM
Yes there is. The higher recommendation came from my AMG Shop foreman and backed by a contact in the Performance Studio in Affalterbach. This was in reference to the 19" 16 Spoke wheels I had ordered from Germany pre delivery...as well as the stock 18" 5 spokes.
Bolts are cleaned with ethanol and wire brush at every change
Old May 19, 2010 | 09:14 PM
bhamg's Avatar
C63 AMG
To each their own, I guess. I take the mfr's recommended torque, undertorque by 2lb/ft, drive 50 miles and retorque to the recommended value. In 250k miles of doing this over the past 10 years I've never had a lug nut or bolt loosen. One thing I also do is apply a superthin layer of anti-sieze to the tapered face of the nut or bolt - it helps to save the finish on the mating surface of the wheel IMO.
Old May 20, 2010 | 08:55 AM
x838nwy's Avatar
n/a
That is really quite strange. I would have thought that the recommended torque (the published figures) would be the safest for the particular thread size and (mostly) road application. I would be very interested to know why they'd recommend owners to torque to under what they think works best. Humm...
Anyway, thank you for sharing
Old May 20, 2010 | 09:43 AM
I will be seeing the Shop Foreman next week and will ask for a more definitive on the 130 and let you know. One thing they both stressed was that this was a clean and dry application. NO anti seize or lube of any kind.
Old May 20, 2010 | 10:28 PM
bhamg's Avatar
C63 AMG
I assume you mean threads only because that is not the place I am talking about and the threads are the only thing that matters, so no lube on the threads is correct. That said, IMHO 130 lb/ft is just plain crazy, it runs counter to EVERYTHING I've ever heard or read about torquing lug nuts/bolts.
Old May 20, 2010 | 10:45 PM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Hey Barry,
I tracked the car at 96lbs and the bolts did slightly loosen up, however 130 seems a lot! I'll try 100 next time and go from there.
Old May 20, 2010 | 10:48 PM
wuyichao's Avatar
C63
Originally Posted by chief63
Hey Barry,
its normal, i had to tight my bolts after every track session, every 30min of tracking my car.
Old May 21, 2010 | 12:29 AM
x838nwy's Avatar
n/a
There is the possibility of the bolts/stud being hotter during track sessions than in road use. Obviously this would cause a number of items to expand and perhaps the bolts to lengthen slightly.
I look forward to hearing from you guys!
Thank you NORTH 44 C63
Old May 25, 2010 | 02:56 PM
chief63's Avatar
Ok good too know. They weren't that loose but did require tightening about twice a day, which isn't that much for track use. However it was extremely cold so I can imagine it will be much worst under hot weather.
Old Sep 26, 2010 | 12:30 AM
yooker's Avatar
a durr
so 96 or 130?
Old Sep 26, 2010 | 08:05 AM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
Originally Posted by yooker
so 96 or 130?
96 ft lb = 130 nm
I think that was what was going on here.
Here inthe US "we" use ft lbs and in most of Europe they use nm for torque numbers
If you compare the two values they are the same and MB lists both figures as correct.
I would guess that the MB techs in NA use nm and the metric system in general when working on our cars, so that is my guess.
Just make sure you know which one you're using and you should be okay
96 ft lbs is correct
130 nm is also correct
Old Sep 26, 2010 | 12:16 PM
e1000's Avatar
a quarter mile at a time
Originally Posted by black-clk500
96 ft lb = 130 nm
I think we have a winner!
Old Sep 26, 2010 | 12:26 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is funny, because my AMG Tech told me to torque the lugbolts to 110 ft lbs. And he's the Master AMG Tech at Amercian Service Center.
