C63 AMG (W204) 2008 - 2015
tires, not what you think
Old Mar 26, 2010 | 03:40 PM
W204 C63's Avatar
C63
ive been thinking about running either the nitto invos or nitto nt05 and was wondering whether i could run 285/35/18 i know 275's are the biggest recommended on a 9 inch rim but nittos run very slim and i think i read a while back that some c63 drivers have run nitto 285 rears. anyone have any input on this?
also do any of you guys have first hand experience with either the nitto invo's or nt05s that can give me advice?
Old Mar 26, 2010 | 03:57 PM
alqamzi's Avatar
2009 c63, 2011 GT500
I wouldn't risk it and u don't need 285's u will be fine with 275's.I would go with the nitto nt05, I used to have the invo's they are good but they wear very fast.
Old Mar 26, 2010 | 05:39 PM
Even Money's Avatar
'15 VW GTI
You could always try, and let us know how it works out!
Old Mar 26, 2010 | 05:57 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
NT05's are great for the track-going larger-you could run into some fitment issues (rolling is an easy fix)-the biggest thing I would see is that your simply running a tire thats too large for the rim-so you'll get more sidewall roll on turns-just for a little more contact patch for launchs-
if you're looking for a wider look-spacers make all the diff.....
Old Mar 26, 2010 | 11:33 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
i don't think 285 will fit on the C63 without some major fender work.
Old Mar 26, 2010 | 11:45 PM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
The Nitto NT555R Drag Radial will fit in a 285/35-18. It does run narrow for it's width.
For all other tires, stick with a max of 275/35-18. The NT05 is an excellent choice.
Old Mar 27, 2010 | 02:28 AM
NickZag's Avatar
no more AMG
+1
Old Mar 27, 2010 | 02:36 AM
e1000's Avatar
a quarter mile at a time
285/35/18 would be 3.3% too tall, which maybe ok, but the wider and taller you go, the greater the chance you'll start tearing up something.
If you want a 285 tire, you should go with 285/30/18
Old Mar 27, 2010 | 07:06 PM
W204 C63's Avatar
C63
yea i just did some research. the nt555r which have fit on a c63 in 285/35/18 are 11.22 inches in width. that means most likely a tire of the same width would fit. the manufacturer may claim a tire to be 275's or 285's but each brand vastly differs. For instance...
265 pilot sport cups = 10.9 inches wide
265 bridgestone re-11 = 10.7 inches
275 nitto nt05 = 10.7
275 hankook v12 evo = 10.9
275 dunlop direzza star spec = 11
i know that .2 inches may not seem like alot but as you can see the 265 pilot sport cups are the same exact size as the 275 hankooks. so there can be some 285's that run small that would be able to fit on our rim. im not exactly sure about height though, thats a whole different story
