C63 AMG (W204) 2008 - 2015
I put in WORK
Old May 15, 2010 | 03:13 AM
  #101
avengerboater's Avatar
C63 AMG
Originally Posted by Jae Duk
No that was not me I had the Gnosis GS-4. My fronts were 20x8.5 ET 47 and my rear was 20x10 ET 51
Que? I thought you said that Jim may have been referring to your numbers when he looked it up in the computer? Haha. Either way, I'm thinking the 20x10 ET51 will fit our car because Jim had mentioned that they "re-designed" these wheels in the 20" sizes, whereas the 19" are based off of the 18" and are really just "stretched" out to 19".
Originally Posted by dacatz
what is the different between "A disk", "O disk", and "R disk"?
also what is that mean "rim depth" from the vsxx pdf chart?
If i want to order this rim for the rear.....is that mean i have to order 19 x 10 et 48 "O Disk"
http://www.workwheelsusa.com/media/w...5/VSXX_PDF.pdf
A-disk is the standard disk for most regular calipers. R-disk is the lip that goes on wheels with big brake calipers, like our fronts. O-disk is really not applicable to us because those are the lips that give you the most lip.
Rim depth is how deep the rim is. For instance, my rear lip is 59mm, which is a little over 2.3 inches.
As for clearance for the rear, you'd have to go with A-disk and ask Jim about a proper offset (now that we know how close my ET51 is for our car). Or, you can choose to go with the R-disk in the rear, but have practically no lip.
Old May 15, 2010 | 03:48 PM
  #102
Jae Duk's Avatar
'09 C63
Sorry I didn't make it clear. If you look at my sig it says Venaci 20" wheels, but Venaci wheels ARE work wheels. It's made by works and it says Works on the wheels itself. The guy I ordered it from took all the measurement for brake clearence and everything after I gave him the offsets and the wheel size. He most likely called Japan to order the wheel, so I just thought that Jim's computer would be connected to Work's computer in Japan.
Old May 15, 2010 | 04:45 PM
  #103
C63 AMG
Aaaah...I see, I see.
Old May 15, 2010 | 06:25 PM
  #104
RLx02's Avatar
C55
Originally Posted by superlubricity
EM/AVB, you guys down for Pacfic Raceways Test in Tune on the 14th or 19th? The 19th (Wednesday) is a better day for me.
PM me if you want to go.
Are you guys going to go back down again? I just came back from yakima for 2 weeks annual training. I need to hit the strip now that I have my headers on!
Old May 15, 2010 | 06:30 PM
  #105
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
I am going to meet EM at Fry's in Renton @ 3:00pm on the 19th. You in?
Old May 26, 2010 | 10:16 PM
  #106
avb, what is the latest?
Old May 31, 2010 | 05:09 AM
  #107
C63 AMG
Sorry, I've been on vacation for the last 7 days. Just got back.
The H&R spacers fit perfectly and without a hitch. The clearance between the rear calipers and the wheels is now much more comforting. No scrapes. The tires stick out a tiny bit more, but it's not bad. There are no rubbing going over bumps, drive ways, or heavy acceleration with me and a passenger in the car. There was a slight rubbing when I made a very sharp turn at about 35mph--the rear outer tire rubbed against the rear fenders a bit, but not much. I haven't tried driving with 3 passengers in the rear, yet...nor do I really want to.
I did manage to snap some pics and I'll post them later.
Old May 31, 2010 | 05:16 AM
  #108
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Glad to hear the spacers more than less did the trick.
Old May 31, 2010 | 05:59 AM
  #109
RLx02's Avatar
C55
Argh I missed this post. Weather has been crappy as of late but check your PM
Old May 31, 2010 | 11:40 AM
  #110
Mort's Avatar
Good to hear the spacers are giving you some room to move.
Are you thinking of rolling the rear fender lips for the last bit of clearance?
Great job making the best of this mod and working through the process required to get it done. Worth it!
Old May 31, 2010 | 01:02 PM
  #111
BenzoBoi's Avatar
Super Moderator
W221
I bought these same wheels for my dad in bronze when he picked up his GS430 a few years back. Great wheels IMHO.
Sorry to hear of all the trouble your going through. I'm sure the wheels will look SOLID on your car once everything is up and running!
Good luck!
Old May 31, 2010 | 04:06 PM
  #112
C63 AMG
I likely won't be rolling any fenders or messing with the body work. I tried to recreate the rubbing a few times with just myself in the car, and it seemed fine.
Good luck!
Yea, it was quite a process to go through. haha. But they do look nice in the end. I'll post some pics later tonight if I have time.
Old Jun 1, 2010 | 05:53 AM
  #113
C63 AMG
Pics are up:
https://mbworld.org/forums/c63-amg-w...ml#post4098694
