KW Clubsport Suspension - Review
I have not seen anyone posted on this suspension before, although I know many friends here are on KW V3.
I installed KW Clubsport 3 days ago and had a track session immediately after the installation. Good thing is I get to test the new suspension immediately after installation on track. Bad thing is I had minimal chance to give my workshop the feedback on road use so that they could further 'tune' or adjust it before wacking the car hard on track.
I used to fret a bit during hard corners on stock suspension due to quite a bit of roll. Although the stock suspension is relatively firm vis a vis most road cars, but I tend to lose a bit of confidence at corners. KW Clubsport definitely gave me back my confidence. Now, the car WILL point at where u steer and you can easily power out from the corner without losing control or oversteering or having the ESP cutting the power. There is also very minimal, if not, NO roll at all during high speed or hard corners!
I am sure most of you would have also experience this on the straights. That is when you gun at full throttle, you tend to feel the weight of the car being thrown to the back as the car tilts backwards. KW Clubsport totally eliminate that as well. Car is entirely planted on straight line dash.
This car is firmer on daily drive definitely, inching towards being a bit too bouncy on uneven roads. This is where I would most likely have the workshop adjust for the damper or rebound and hopefully make the ride more comfortable without throwing your passengers up and down too much.
All in all, this is one of the best mod I had. Bearing in mind that when I ordered this via an authorised dealer from my country, KW was said to do a set just for me, as there hasn't been any request made so far. So I would assume it's a make to order, doesnt' seem like they will make a lot of these and wait for buyers. Took me a 1 month wait.
The quality and finishing is fantastic as well. Look really really good. I guess if you are not as hardcore, KW V3 should do the job very well (I have not tried V3 though). But I felt like going hardcore, and KW Clubsport really didnt' disappoint!
Former Vendor of MBWorld
C63 AMG Arctic w/ Stage 1 Tune, DoubleXX pipe, MCD-631X coming soon
You arr right the CS is special build only for C63. What country are you in and what track did you use? How was bump steer? also do you know the compression and rebound settings your workshop gave you? Sounds like you might need a bit more pressure in your rebound setting based on the limited info you gave here.
Hi Brian!
I am based in Singapore and I was tracking in Sepang, a F1 track in Malaysia.
I am not sure what was the setting. I will go to the workshop either today or tomorrow to get the rebound fixed :-)
Hi there, I am not sure what you mean by not corner balanced. I didnt' lower the ride of my height as I am using a 19inch DPE rims, which visually makes the car lower without lowering the car.
The only catch I have is that because the construct of the front KW Clubsport is differnet from the stock ones, I have problems fitting back the front DPE rims (as the orignial offset I had didn't take into aco**** that I would change suspension), without having the tires rum a little against the suspension. This will most likely result in a twin bolt spacers, unless I opt to change rims![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
![action](https://mbworld.org/forums/images/smilies/action1.gif)
why garmen tax so much
bro but your road tax killer leh
almost 6k USD a year before insurance....
kao
now with COE up your C63 from C&C is close to 300k USD
On my car I have CS also but never tried on the track but I really like it.
The only problem that I have is that I want to lower my car more but it does not go lower. But on some other car that has CS is lower than mine for sure. If you can take some pictures I want to see how low you went specially the rear.
Plus if you can let me know what set up you did will be a great help also that you used at the track.
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Can't find any info on it on KW website. I have a KW V3 and what you mention is exactly what I feel, I guess everything must be a bit better!
1 Post
2011 Ultima GTR
I am getting pricing now locally for these. I'd probably get the CS's over the V3's.
More info on CS: http://www.evlmotorsports.com.au/kw-.../kw-clubsport/
The CS seem to be made specifically for the Nordschleife, so really good for track days/mountain driving.
I am thinking to pair these with some 2-peice rotors, braided lines, upgraded brake pads and larger oil/transmission cooler. Then I think the car will be a lot more fun.
1 Post
1 Post
2011 Ultima GTR
I've done brake lines before and I've seen good benefits them. Just more linear on the peddle feel, got rid of that "squish" at the bottom.
I think the key though is also good fluid at the same time. High temp and low compression, like Motul or Brembo fluid.
Also, I am looking into pads. Will see what I come up with. Might end up getting something custom made (here, place just put their compound on genuine backing plates)
