C63 AMG (W204) 2008 - 2015
Few questions??
Old May 13, 2010 | 12:51 PM
tasho3's Avatar
2014 C63 Sedan
Few questions??
Hello guys, i had a couple questions for my gf's car, any input would be greatly appreciated. The hard drive wont record the CD's in its memory, it'll like skip thru the option to record, has this happened to anybody? and what should i look for? i tried resetting it but it still does it?
And my second question is about the tires, it has been rainy out here the past week and the car feels like its hydro planning when its doing over 50mph, it only has 6500 miles and i don't think they tires need to be replaced yet, are this tires not meant to be used on rain at all?
Old May 13, 2010 | 12:57 PM
BerBer63's Avatar
2009 C63
Music has to be in mp3 format.
Check the tread. Tires can be used in the rain.
Old May 13, 2010 | 01:02 PM
tasho3's Avatar
2014 C63 Sedan
Thanks mate. But its CD's that i have recorded on the car's HDD before and now it wont even rec the same CD's and i stopped at MB of Naperville yesterday to ask them and they told me to make an appointment and bring the car in.
Old May 13, 2010 | 02:34 PM
lomita's Avatar
C63AMG
Hydroplaining
Hydroplaining equation speed: 9 X square root of tire pressure psi
ie 9 x square root of 40 psi = 9 x 6.32 = 57 mph
What tire pressure are you running?
Old May 13, 2010 | 02:48 PM
e1000's Avatar
a quarter mile at a time
wow that's a pretty general equation, and it totally leaves out surface area of the tire and tread depth. Might work in a general sense but I could see how it can be WAYY off.
Old May 13, 2010 | 03:49 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Lets start by the type of tire you are using?
Old May 13, 2010 | 06:07 PM
Jae Duk's Avatar
'09 C63
If you have a regular CD say a bought CD from your retail store or whatever you could record those onto the HD. However, mp3 burned data cd will not be able to be recorded.
You also have 6500 miles on your tires. Check the tire tread. Many people have already changed a set of tires by then.
Old May 14, 2010 | 12:38 AM
tasho3's Avatar
2014 C63 Sedan
the CD issue looks like it solved it self, and is working properly now.
The tires are the stock tires and i actually got under the car and looked and they are completely bold on the inside, what do you guys recommend i should get next? I have Yokohama S drive 255 35 18 on the rear of my C43 and i really like them and i wonder if they would work on the C63? i actually surprised the 63 has 245's
Old May 14, 2010 | 09:34 AM
Mort's Avatar
C63 should have 235 front 255 rear. Not sure the tire to use but think you should match it to the capabilities of the car at least.
Good to hear the CD is working.
Old May 14, 2010 | 12:41 PM
tasho3's Avatar
2014 C63 Sedan
thank you, and i checked today the car does have 235 front 255 rear, i don't know why i thought it had 245's. although the 355's on the C43 look lot wider than the ones on the C63, i wonder if i can put 265's lol
Old May 14, 2010 | 02:27 PM
exdes's Avatar
2015 C300 4matic
you can put up to 275 on the rear.
Old May 14, 2010 | 02:42 PM
MB_Forever's Avatar
+1 I've seen a couple at the track
Old May 14, 2010 | 03:56 PM
tasho3's Avatar
2014 C63 Sedan
thank you, so 235 40 18 front and 275 35 18 rear and it wouldn't bug the ECU, last time i tried that on the C43 it would shut off the ECU after a mile
Old May 14, 2010 | 08:19 PM
Jae Duk's Avatar
'09 C63
You can fit 245 on the front if you want.
