C63 AMG (W204) 2008 - 2015
WTF, my throttle died on the highway!
Old May 20, 2010 | 10:46 AM
Mperor's Avatar
12/2012 Build 911 (991) C2S; 2011 Acura ZDX
This mornig I was driving to work, getting on the I287 ramp, a EVO8 was right behind me and no car was on the highway so I downshift to 4 WOT from 40 - 60mph up shift to 5, then to 6 around 80... try to upshift around 90, BAM! My ESP light went on, and RPM dropped... I stepped on the throttle... NOTHING!!! The EVO behind me almost kissed my ***!!! He shook his head as he blew pass me. I pull to the service lane quickly before the semis ran me over! Put the gear in Park, a warning message displayed saying that my ESP is unavailable. I had to restart the car.
I think I have read here someone had the similar issue... so WTF? This is so dangerous, luckily the EVO behind me wasn't really on my tail when I took off from the ramp.
Does anyone know what happened? Should I take it to service? Or perhaps it has something to do with my ECU flash?
Old May 20, 2010 | 10:50 AM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Sounds just like this -> https://mbworld.org/forums/c63-amg-w...what-hell.html
Old May 20, 2010 | 11:04 AM
Mperor's Avatar
Originally Posted by superlubricity
Thanks, so I see it's the 'accelerator pedal' issue... will call MB ASAP!
Old May 20, 2010 | 03:54 PM
Jae Duk's Avatar
'09 C63
Did you get an ECU tune?
Old May 20, 2010 | 05:17 PM
Mperor's Avatar
Yes, got it from Eurocharged a few months ago but from I have read, this issue has nothing to do with the tune - it's the accelerator pedal issue.
Old May 20, 2010 | 05:33 PM
AMMO1000hp's Avatar
C63
Pretty scary stuff. Hmm I wonder if this only affects 09 cars. ?
Old May 20, 2010 | 05:39 PM
Jae Duk's Avatar
'09 C63
For the op of that thread, Artichaze, his was a pedeal sensor problem. But if you got the ECU tune recently it could be a possibility like Josh, C63guy, posted about hittin the torque limit. RPI is currently trying to come out with a ECU for the car so when I test drove it I got that as well while driving on the road.
Old May 20, 2010 | 06:04 PM
blindfold's Avatar
C63
hitting the torque limit? Is there g sensor for accerlation or ECU calculating the load limit?
Old May 20, 2010 | 08:15 PM
SMP's Avatar
SMP
CLK63 Black Series
I had the same problem, although with my CLK63 BS, and it was caused by flashing the ECU with a different program from a tuner. Hitting the torque limit is triggered by the yaw sensors.......
Old May 20, 2010 | 08:17 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
My money says it's the aftermarket ECU tune...certainly a good place to start would be to reflash to stock and see...
-Rob
Old May 21, 2010 | 02:17 AM
Jae Duk's Avatar
'09 C63
Could someone explain more in detail about this? Although I was told this was the case on my car, I have no idea what it means.
Old May 21, 2010 | 03:12 AM
Faris63's Avatar
'13 CLS63 PP
I had this problem last week when I took the charcoal out of my car.Also it happened to me while I was in freeway it was really bad to MB with died throttle
Old May 21, 2010 | 10:11 AM
drawde's Avatar
2009 C63
Same thing happened to me once.. Was in sport, held the shifter to the left, WOT, ESP died and gas pedal wasn't working. Turned car off and back on, no issues. I have not been able to duplicate it since.
Old May 21, 2010 | 10:25 AM
emericr's Avatar
2021 Porsche TTS
This is a bit scary as it seems to have happened to mostly owners with Eurocharged tune.
Any of you guys have emailed Jerry and ask him about this?
Old May 21, 2010 | 10:57 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Not yet.
Old May 21, 2010 | 11:05 AM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
I have the EC tune. Have roughly 4K miles since the tune, and never experienced this.
Old May 21, 2010 | 11:09 AM
mrc63jg's Avatar
C63
I also have a Eurocharged tune and this has happened to me on one occasion... Definitely some scary stuff. It was after some pretty high speed runs with lots of up/down shifting. Judging by the other thread on this topic though, it seems like people who have other tunes have experienced this too. Hopefully the kinks have been ironed out by now and all that's needed is a reflash.
Old May 21, 2010 | 01:53 PM
2010c63amg's Avatar
2010 C63 amg
This seems to have happened to a lot of people on here. Is this only happening to tuned c63's, or stock ones also?
Old May 21, 2010 | 01:54 PM
Even Money's Avatar
'15 VW GTI
Never any issues stock or with my Kleeman K1.
Old May 21, 2010 | 02:15 PM
PetroC63's Avatar
2012 CTS-V
I have a Eurocharged tune and this has never happened
to me.
Old May 21, 2010 | 03:04 PM
Mperor's Avatar
From what I have read, it seems to me that this issue occurs when using the shifters...
I drove this car for a long and never had any problem... this happened when I f'd around with the shifters at high speed... maybe it does has something to do with the tune and the torque limiter
Old May 21, 2010 | 03:34 PM
SMP's Avatar
SMP
CLK63 Black Series
I don't want to elaborate on the topic................you are actually half way there of figuring out how to trigger it.............next time try it coming out of a turn and see what happens. Just make sure there is no car behind you......
Old May 21, 2010 | 04:16 PM
I always drive in M and use the paddles. HOpe this dont happen to me.
Old May 21, 2010 | 06:42 PM
Hans Delbruck's Avatar
What I like!
Spin FTW?
What tune were you running?
Old May 21, 2010 | 07:04 PM
arctichaze's Avatar
C63
Makes me wonder if this is an actual issue with the car or the aftermarket tune.
Just FYI when I got the car back from the dealer after they replaced the pedal I immediately had the car reflashed again. I've been trying very hard to trigger it again but so far so good. I actually called MBUSA about this issue and started complaining and they said I'm a unique issue. They make thousands of X63 AMG cars and I'm one of the very few with the throttle issue. It seems like its more wide spread than I thought of.
