NITROUS OXIDE
you need to find out your timing (depending if you are tune or not) in order to get the correct set up. remenber we got a very high compression so race gas could be requiered.
Depending on your tuner and set up as to the size shot she'll take and what fuel you'll need to run. I am running 100-150 wet shot which will require race fuel above 100 shot. 100 or less should only require 93 or higher octane. I will be running 100 octane with the 100 shot to be safe.
Sorry, Ive always wanted to do that.
