Anyone using sway bars?
I'm thinking of putting sway bars on my C63 and I'm wondering if anyone else has them, where they purchased them, and how much they spent? Also, I don't feel much body roll put at times our cars are prone to a bit of understeer. For those that installed them, was there a big difference?
09 c63 blk/blk H&R Springs & 08 e 63 blk/blk
was thinkin about this mod aswell, but i couldnt find any available for our cars. considering the replies on my thread, and your one here, it doesnt seem like anyone has them or even wants them lol.
1 Post
C300 4MATIC (w204)
SinCity has a SMERC Engineering brace on his ride. SMERC's Brace. They're currently testing their prototype C300 4Matic Sway Bars. If there's enough interest, I'm sure they will look into the C63 next.
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
I have a brace from MBarts. Difference from stock is minor but I have only tracked the car with it (and never without it).
Did not find any sway bars...
Audi's, a whole bunch of them
sway bars are under the car, strut bars go across the top of the engine attached to the strut mounts... i think there is some confusion with some of the replys
A sway bar reduces the amount of body roll by a bar that connects the two front or two rear tires together.
A strut bar only reduces body flex by connecting the top of the struts together.
Thank you for explanation
2014 Ghibli S Q4 & 2008 C350
Different car, but FWIW I recently put the Eibach front and rear swaybars on my C350 and the different is night-n-day. The limits have been raised on what the car can now do, but I haven't tried hard to find them yet.
I also got set of new Goodyear Eagle F1 Asymmetric tires this spring. That was certainly a noticeable difference. Then I bought the MB Arts Strut Brace. No difference under normal driving but noticeable when pushing the car. Stability is increased when flicking it into turns. I find fun to wait till the last instant to enter the turn, the chassis stays smooth and stable with less flexing and therefore doesn't un-flex once you've found your line and the cars turning. (I may not be describing this very well....)
But the most noiticable change has been the swaybars. By far. Body roll is dramatically reduced (I'd say 'all but eliminated' but the front is adjustable and I have it in the medium position so I could get even more out of it if needed) and the car just turns and the tires stay flat and don't lean or roll as much. It's the best performance mod I've done yet and I wish I would of done it sooner!
But the most noiticable change has been the swaybars. By far. Body roll is dramatically reduced (I'd say 'all but eliminated' but the front is adjustable and I have it in the medium position so I could get even more out of it if needed) and the car just turns and the tires stay flat and don't lean or roll as much. It's the best performance mod I've done yet and I wish I would of done it sooner!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Not sure, if I had to guess I'd say no. I just checked Eibach's site they still don't list the C63... At best they may bolt up but not provide as noticeable a difference. I would tend to think that your OE sway bars might be thicker than my OE sway bars were since you need to control a bit more weight up front plus yours is designed for higher performance than my non-AMG car.
