C63 AMG (W204) 2008 - 2015
switching of the check engine light
Old Jul 9, 2010 | 05:37 PM
cls55's Avatar
switching off the check engine light
can we do that with the DAS?which sub menu on the DAS?
any help would be apprciated
Old Jul 9, 2010 | 08:08 PM
HBC350's Avatar
'18 C63A Cabriolet
I don't understand your question. What do you mean by switching of the check engine light?
Old Jul 9, 2010 | 08:32 PM
cls55's Avatar
you know that yellow engine thing in the dashboard,it`s lit,can we turn it off?should`ve added the second f
Old Jul 9, 2010 | 11:20 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I think you need to go to the dealer to have the code pulled... and they can reset it after repair. I doubt you can reset it from your dash. Plus, I don't think it's good to drive with the CEL too long.
Old Jul 10, 2010 | 12:33 AM
HBC350's Avatar
'18 C63A Cabriolet
Yeah, that indicates a malfunction within the emission control system. Take it to the dealer asap. If it blinks while you drive, pull over and have it towed. First check your gas cap, though. If it's loose, tighten it and the light will go away in a few days. If the cap is tight, it's probably a stuck purge valve. Dealer repair if under warranty. Could also be a slew of other things but those are the two most common on the C63.
Old Jul 10, 2010 | 10:07 AM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
By a OBD2 scanner, I just got an Autel AL309 (80$CAD) and you can read detailed error codes and clear them at will, very useful when it's just something minor!
Old Jul 10, 2010 | 10:53 AM
gOt BoOsT's Avatar
‘17 GT F1A E85 Monster ‘16 C63s
you can pull the positive cable off the battery for 1 minute or so and the ecu will reset itself
Old Jul 10, 2010 | 11:09 AM
cls55's Avatar
My problem is that I removed the cats,I need to switch it off from ecu.
Old Jul 10, 2010 | 11:21 AM
gOt BoOsT's Avatar
you can use a "o2 cel eliminator" which is just a spacer that sits between the o2 sensor and the exhaust pipe
Old Jul 10, 2010 | 02:50 PM
Mort's Avatar
I think you need to get a tune with the 02 sensor code(s) set to Not Reported for the rear sensors. Because it is illegal the DAS may not be able to do it or you may have trouble finding someone willing to do it for you.
