First Service
Oil & filter change and differential oil change.
Service advisor pointed out did not need oil change but I wanted it anyway.
Has not burned one drop since new. Took a while as draining oil cooler oil not a quick thing. Rep says they never change oil in AMG by siphoning from dip stick.
All in all for $375.00 not bad.
At 3,000 Kilometers - Rear axle differential fluid replaced (AMG Performance Package vehicle only). Also applies to AMG LSD option for 2010 models.
Service 1/A at 15000 Kilometers or 1 Year: then every 30000 Kilometers or 2 Years (engines 113, 156, 275, 642).
Just make sure you find out exactly what oil weight and formulation they used so you can top it off yourself and not have to run to the dealer. It's easy to do, but it was a pain in the butt to find out right when it needed topping off.
Norm for rear diff, if you have it. Not at all norm for engine oil. They actually fought me on this the first time I went in. Almost had to argue with them to get them to do it.
1st service: Service 1/A 15000 Km or 1 year
2nd service: Service 2/B at 30000 total Km or end of 2nd year
and then,
3rd service: Service 1/A at 45000 total Km or end of 3rd year.
There are some other service items that are due at different times as well, such as brake fluid change.
