car idling rough
Subscribe
Jul 27, 2010 | 06:04 PM
Hello everyone, so today i went in at MB of Chi and got a oil change, after 2 hrs of waiting for them to do the OC and tell me they had to replace the trunk luck because there was a recall on it, the car was ready, and my girlfriend gets in the drivers seat, drives it to the suburbs and at the first red-light we stop after we got off the highway the car started idling really bad, it had never done it before, and there is no messages displayed in the cluster or check engine light, has this happened to anybody else? what can it be?
Reply 0
Jul 27, 2010 | 06:14 PM
Quote: Hello everyone, so today i went in at MB of Chi and got a oil change, after 2 hrs of waiting for them to do the OC and tell me they had to replace the trunk luck because there was a recall on it, the car was ready, and my girlfriend gets in the drivers seat, drives it to the suburbs and at the first red-light we stop after we got off the highway the car started idling really bad, it had never done it before, and there is no messages displayed in the cluster or check engine light, has this happened to anybody else? what can it be?
Let it idle badly for as long as you can. It will eventually set a check engine light, and that's certainly good for diagnosis. Otherwise, the car may straighten itself out and you'll have less info for the dealer when you bring it in for the fix.
Reply 0
Jul 27, 2010 | 06:33 PM
Did u check oil filler cap
is on and oil level?
Reply 0
Jul 27, 2010 | 07:38 PM
i let it run for 10 min in P and it was idling fine, but than i started driving it and the first light it started doing i again, i made an appointment with the advisor tomorrow at 11 so i'll let him figure it out
Reply 0
Jul 27, 2010 | 07:47 PM
I always have minor vibrations at idle.. only something you could slightly feel at a stop light. I think some other members have complained about the same issue. I was told this is normal for the motor size.
Reply 0
Jul 28, 2010 | 01:59 AM
Camshaft sensor maybe?? I would drive it around for a couple of days to see if the rough idle goes away. If not then just take it to the dealer.
Reply 0
Quote: I always have minor vibrations at idle.. only something you could slightly feel at a stop light. I think some other members have complained about the same issue. I was told this is normal for the motor size.
+1
Reply 0
Jul 28, 2010 | 03:41 AM
Quote: i let it run for 10 min in P and it was idling fine, but than i started driving it and the first light it started doing i again, i made an appointment with the advisor tomorrow at 11 so i'll let him figure it out
i had the same problem with my ml63. its was the engine mount. tell the dealer to check the engine and transmission mounts
Reply 0
Jul 28, 2010 | 08:55 AM
it also seems to do that if they put too much engine oil..
Reply 0
Jul 28, 2010 | 10:34 AM
Quote: it also seems to do that if they put too much engine oil..
thats the first thing that came to mind,i let the car sit in level surface all night and going to check the oil level now
Reply 0
Jul 28, 2010 | 10:45 AM
i pop'd the hood to check the engine oil level, and no dipstick? i notice the gear box dipstick in the back, but what about the engine?
Reply 0
Jul 28, 2010 | 10:47 AM
There should def be a dipstick. Has the red hoop.
Reply 0
Jul 28, 2010 | 11:16 AM
Quote: There should def be a dipstick. Has the red hoop.
I noticed that had to b engine oil(my c43 has the gear box dipstick there so i thought it would b the same for this, but not) after I pulled it out and the oil is well over the top notch by like an inch, wiped the stick put it in, pulled it out and again well over 1 inch above the top notch, I m taking it in right now to ***** at them! Could this wear the engine? Any effects?
Reply 0
Jul 28, 2010 | 01:54 PM
took the car in, the head technician took a look at it and they took some oil out, and now the car is fine, i can't believe they would over fill it, now it makes me wonder if they even took the old oil completely out
Reply 0
Jul 28, 2010 | 01:59 PM
Find a different mech if possible. If they don't know how much oil to put in your car, how can you trust them to be thorough with something more serious? Its surprising coming from a MB dealer. I change my oil myself so I know it is correct, but I know cars under warranty have to go to the dealer for oil changes. Find a mechanic you can trust.
Reply 0
Jul 28, 2010 | 02:02 PM
Quote: took the car in, the head technician took a look at it and they took some oil out, and now the car is fine, i can't believe they would over fill it, now it makes me wonder if they even took the old oil completely out
The Nissan V8's had the same idling concerns whenever the oil was overfilled, even slighty. They even made some noise from the crankshaft slapping into the oil that should not have been there. Glad it was a simple fix.
Reply 0
Jul 28, 2010 | 03:22 PM
Quote: Find a different mech if possible. If they don't know how much oil to put in your car, how can you trust them to be thorough with something more serious? Its surprising coming from a MB dealer. I change my oil myself so I know it is correct, but I know cars under warranty have to go to the dealer for oil changes. Find a mechanic you can trust.
we got the car there and they gave us 3 free oil changes thats why i took it there, its actually 30 min away from me, but after this i m taking it to my local MB and paying out of pocket for a new oil change
Reply 0
Jul 30, 2010 | 08:35 AM
Man told u to check the oil. Use them but next time check the oil before you leave their workshop - free oil change is free oil change - you can pay and have the same issue
Reply 0
Jul 31, 2010 | 06:54 AM
how much is a oil change on the c63? Just about to hit 1000 miles and want to get an early oil change. Thx
Reply 0
Jul 31, 2010 | 04:27 PM
i was gonna say if it wasnt the oil, then check the o-ring on the top of the dipstick. if they are rolled over or missing, mb vehicles will have idling issues.
Reply 0
Jul 31, 2010 | 10:19 PM
Quote: Man told u to check the oil. Use them but next time check the oil before you leave their workshop - free oil change is free oil change - you can pay and have the same issue
true that, the car still shakes very very very little, u cant almost not feel it or maybe i m just paranoid now
Reply 0
Aug 1, 2010 | 04:13 PM
Quote: true that, the car still shakes very very very little, u cant almost not feel it or maybe i m just paranoid now
Probably paranoia but can u get a second opinion in the shake you still feel us there. In any case tell the dealer in case of any (unlikely) warranty issue
Reply 0
Aug 1, 2010 | 08:28 PM
Mine has a slightly bumpy idle at various times as well. Usually warm. I think it's just the nature of the beast. Most significant misfires will set a check engine light so I think it's just the result of a lean mixture at idle for emissions purposes.
Reply 0
Subscribe
Currently Active Users (1)
