C63 AMG (W204) 2008 - 2015
"Bump in the day" - then some temp changes
Old Aug 5, 2010 | 02:02 PM
harrower's Avatar
2009 C63, 2007 GL 450
Need some insight here.
Yesterday while out for a drive I ran over what seen to be some pliers which were on the road. There was lud near the right wheel well. No damage that I could see and no tire/rim damage.
However after the "event" I got some pretty strange temp readings. For background sake, the car has K1 tune and for the last year has been running consistent temps as follows
Oil - 208-212 constant (up to 221 under hard drive)
Coolant - 195F (up to 199 under hard drive)
These seemed a little high to me, but I chalked it up to the tune or just the engine. Anyway after the event mentioned above the temps have been as follows:
Oil 197-200F (then pushed it today and only got it to go to 203F)
Coolant - 197F stable (199 under push)
What has me perplexed is why the drop of almost 9 degrees in oil temp under normal driving and also the temp jumps around in 4 degree increments fairly quickly in the range of 195-200. I looked and there is not oil/coolant leaking that I can see, and there was no CEL. Very strange and am wondering if anyone else has seen this type of temp range swing in ECU tuned engines.
Old Aug 5, 2010 | 02:05 PM
Sincity's Avatar
Can't imagine the plier damaging anything otherwise you will see a puncture in the underbody engine plastic tray.
Old Aug 5, 2010 | 04:19 PM
RAKLAW's Avatar
2012 C63BS 2009 Ferrari 16M 2016 Cayenne turbo S 2019 G63
The only sure way to get peace of mind is get it up on a lift and check for any possible damage
Old Aug 5, 2010 | 04:50 PM
SL63AMG's Avatar
c63 AMG
thats pretty much the same oil temps i get. Is that not normal?
Old Aug 6, 2010 | 04:07 AM
bhamg's Avatar
C63 AMG
I had a similar experience - once. While I no longer remember the specifics it sounds like what happened to you. It was odd, but when I stopped for lunch and restarted, everything was normal again.
Old Aug 6, 2010 | 04:19 AM
harrower's Avatar
Going to have some work done on the car next week at the stealership (love that phrase) and will have them check it out. Car has been running fine and temps are stable at new levels and no CEL.
Old Aug 7, 2010 | 09:39 AM
Mort's Avatar
I believe that there is an oil cooler in the right front bumper behind the fog light. Maybe it got jarred and now it is cooling more. It probably has a bypass and maybe the sensor for it got jarred and now it is opening sooner. Just a guess and maybe something to check.
Good luck getting it figured out.
Old Aug 7, 2010 | 11:03 AM
drawde's Avatar
2009 C63
Not sure if this helps, but your ambient temp sensor is located in the bumper area.. Mine broke and/or got messed up when i hit some debris in the road once.
Old Aug 7, 2010 | 01:14 PM
Mrbig's Avatar
Wen on the amg screen wat should the avg temps be ?
Old Aug 7, 2010 | 08:19 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
i have had those temps before so i think it is normal.
Old Aug 8, 2010 | 12:27 PM
Mort's Avatar
I think I see average temps of :
Oil 99*C - 101*C (210*F - 214*F) normal driving
Coolant 90*C - 92*C (194*F -198*F) normal driving
If you start to push it the Oil temps will go up as the oil will absorb a lot of heat from the heads from higher combustion temperatures.
Old Aug 8, 2010 | 01:17 PM
harrower's Avatar
Thanks for all the input. Will have them check out the sensors and see what the deal might be. I prefer the car to run cooler or at least the accurate temp readings to be lower. Will let you know results just in case someone else runs into this.
Old Aug 11, 2010 | 09:01 AM
harrower's Avatar
Well the car was checked out and they ran tests just to be safe. No damage to underside of the car and no damage issues with oil cooler. Car is running on warmish day (28C) like today at 199-204F oil/ 195-197F collant which is well within normal ranges. All seems well.
Old Aug 11, 2010 | 12:59 PM
Mort's Avatar
Good to hear.
Old Aug 11, 2010 | 11:12 PM
Mrbig's Avatar
New owner car has maybe 400 miles I see my temps go up to like 227 hard drive and 199 temps that ok ???
Old Aug 12, 2010 | 08:58 AM
RAKLAW's Avatar
Not to worry.
Here in the NE the summer has been extremely H&H.
I have seen my oil temps go as high as 252 for a brief second, on hard starts in traffic..normal so far is around 232 in traffic. Water temp constant at 199
