Check Engine light at full throttle. WTF.
First of all, my apologies if this topic has been discussed in previous posts but I felt it was something urgent that I had to post right away. My car was tuned by Upsolute recently and I wanted to check the power on a straight line. I was on S mode, with ESP sport on and cruising at 40mph. I stepped on the gas, full throttle until I reached about 150mph. During this time, the yellow check engine warning light suddenly appeared. WHAT JUST HAPPENED??? I hope it was nothing serious, I switched off the engine and switched it on again and the warning light is still there. Hope you guys can shed light on this problem before I bring it to the shop. Thank you in advance.
Either way, no one can give you much insight without knowing what the "catch-all" CEL trouble light is on for. Best of luck; keep us posted.
Hi, my apologies for the late response. Just brought my car to the shop again and these are the findings: error code 1085, major leak in purge system/ hose in system not connected or filler cap open (0455). We checked hoses and filler cap and after a few days recurred. What could be the cause? What is purge valve? Thanks.
