C63 AMG (W204) 2008 - 2015
How to remove OEM trunk spoiler?
Old Aug 19, 2010 | 04:58 PM
_AMG_'s Avatar
C63
Does anyone know how to remove the C63 OEM trunk spoiler?
Old Aug 19, 2010 | 05:12 PM
BAD430BENZ's Avatar
360 Modena TT
heat gun and dental floss . warm up the adhesive and run the dental floss between the trunk and the wing . that's the easy part . then you have to remove the excess adhesive off the trunk..........
that's when the fun begins
Old Aug 19, 2010 | 05:25 PM
PatSC23's Avatar
2009 C63
shouldnt goo gone get that off relatively easily?
Old Aug 19, 2010 | 05:28 PM
BAD430BENZ's Avatar
360 Modena TT
i tried all kinds of stuff , including goo gone , but the best thing was rubbing with my fingers.............and it took forever
Old Aug 19, 2010 | 07:08 PM
AlexCim's Avatar
2011 Ultima GTR
I second rubbing with fingers. That goo stuff works OK, but the fingers are good.
Only problem is you wear out your fingers. Then when you're two thumbs and a few fingers in, you need to stop and let your skin grow again for a few days lol
Old Aug 19, 2010 | 07:18 PM
HBC350's Avatar
'18 C63A Cabriolet
Aren't the Goo and Goof products pretty caustic? I remember I tried to remove a sticker from an NFL signed helmet once and the plastic got burned, in a sense. Lost its lustre. I'd try a hidden area first and see what you get. You don't want to repaint the hood.
Old Aug 19, 2010 | 08:37 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
+1
Old Aug 19, 2010 | 08:42 PM
_AMG_'s Avatar
C63
Thanks alot, This helped me out.
Do you think fishing line will work just as effective as dental floss?
Old Aug 20, 2010 | 01:36 AM
patboyy's Avatar
C63 AMG
they are fine, i think it is even better, but remember to wear a heavy duty gloves, i used 30lbs lines and with those heavy duty gloves, my hands still hurts for two days.
use boiled water pull on top of the gap between trunk and spoiler first, then use the lines, come off easy, but also becareful of the paint, try to avoid scraching the trunk.
then, if the factory double side tape is still hard to clean, use boil water once again, and finger it off.
Old Aug 20, 2010 | 07:51 AM
malooamg
Guest
Posts: n/a
put the car in the sun for a couple of hours then use a plastic aplicator to slide between the spoiler and boot lid ,vistit your local panel shop they have a special rubber wheel for removeing the double sided tape without damaging pait work and it does it in about 30 seconds .
Old Aug 20, 2010 | 12:42 PM
mangoango's Avatar
08 C350
Do a google search for eraser wheel.
Old Aug 31, 2011 | 10:18 AM
Wack's Avatar
C43 AMG CAB & VIPER
I know this is an old post but I found this thread useful and I found the eraser wheel here for $15 so I figured I'd share it with you:
http://www.aircraftspruce.com/catalo...raserwheel.php
Thanks mangoango for the suggestion
Old Aug 31, 2011 | 11:01 AM
jakio's Avatar
C63 2011
I did it with fishing line and finger with goo gone.
Old Aug 31, 2011 | 12:28 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
You forgot to mention, that you also rubbed your finger print off
Try 3M adhesive remover, it's good for this type of thing, and also for tree sap, etc.
Make sure that you use stong dental floss, as you don't want to snap the line.
Old Mar 8, 2014 | 08:07 PM
Jason Anthony's Avatar
2013 C63 AMG Coupe
+1 for 3m adhesive remover
Also used gloves with fishing line. Floss snaps too easy.
Old Mar 8, 2014 | 10:55 PM
sinape62's Avatar
Veteran: Air Force
2013 C63 Coupe
I used the dental (thick + quadruple "twined" it... Is that a word?) use gloves. Saturated the areas by segment with Goo Gone while warming with a heat gun. The residual tape does require extra work and goo gone. My paint is Article white and wasn't damaged by the Goo gone. Thoroughly cleaned the area with alcohol and cotton ***** before installing the new spoiler. The entire removal process took a good 3 hours. 1 to remove the OEM spoiler and 2 hours to clean up the residual. Takes patience. Don't hurry. Good luck.
Old Mar 8, 2014 | 11:54 PM
yzhou's Avatar
2014 C63 AMG
Easy!
1, find a body shop
2, pay one hour labor
3, congratulation, it's gone!
