C63 AMG (W204) 2008 - 2015
Wheel spacer and lug bolt special
Old Aug 23, 2010 | 06:17 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
Hub Centric Mercedes wheel spacers
5 on 112 Mercedes Benz 66.56mm Center Bore
Available in-
13mm thickness -$28.00 each
17mm thickness- $30.00 each
20mm thickness- $32.00 each
Conical seat lug nuts available in different lengths for-
-$3.00 each
This pricing is incredible, compare to everyone else and you will find no comparison from the competition.
Old Aug 23, 2010 | 06:24 PM
BAD430BENZ's Avatar
360 Modena TT
the best thing about you guys is that you are not hiding the price like most others vendors do . i don't know why the price of things is under national security . you get a big .
Old Aug 23, 2010 | 06:59 PM
Sincity's Avatar
Can I still PM you for pricing?
Old Aug 23, 2010 | 07:00 PM
_AMG_'s Avatar
C63
Are they hubcentric spacers?
Old Aug 23, 2010 | 07:02 PM
Staff@RPM's Avatar
YES, they are Hub Centric.
Old Aug 23, 2010 | 07:09 PM
1Lop2K5C's Avatar
C63
what would one need to push out the stock wheels a little bit?
Old Aug 23, 2010 | 11:31 PM
Staff@RPM's Avatar
Hopefully you like the prices too!!!!
Old Aug 23, 2010 | 11:33 PM
Staff@RPM's Avatar
A 13mm thick spacer is 1/2"
Old Sep 2, 2010 | 12:23 PM
Staff@RPM's Avatar
Here are some photos-
Old Dec 6, 2010 | 04:27 PM
olszowa12's Avatar
'08 C63 Estate
Has anyone installed spacers on their C63?
I'm installing my H&R Springs next week and am considering spacers, as well. Any pics? Or recomendations?
Old Dec 6, 2010 | 07:47 PM
dodger63's Avatar
2013 f250 6.7 diesel
No but if you want I'll be at rpm tomorrow and we can test fit take pictures and post the different sizes if you guys would like!
Old Dec 6, 2010 | 10:28 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Same here.. Did H&R coilovers, and think it would look much more aggressive with spacers..
This still available?
Old Dec 6, 2010 | 10:53 PM
avengerboater's Avatar
C63 AMG
I have 5mm spacers on my rears. They're fine.
Old Dec 6, 2010 | 11:01 PM
So 13mm is going to be too much? Especially on lowered cars?
Old Dec 6, 2010 | 11:57 PM
bli8's Avatar
C63 Seal Gray
Did you continue to use the stock bolts? If so, how many turns can you turn the bolts before they are to torque spec?
Old Dec 7, 2010 | 12:26 AM
Faris63's Avatar
'13 CLS63 PP
Can you please pm price of 4 spacers with bolts to for stock set-up to push it little bit
Old Dec 7, 2010 | 01:48 AM
C63 AMG
No. I had to order longer bolts that were 5mm longer than the stock bolts. The thing with the Merc is that the bolt lengths need to be pretty exact, otherwise it may hit and damage the ABS.
Old Dec 7, 2010 | 01:51 AM
C63 AMG
I would think so. I'd worry about rubbing issues, especially with fatter tires. But I don't know, there are a couple people on here running 10mm spacers and they seem to be fine.
Old Dec 7, 2010 | 04:24 AM
olszowa12's Avatar
'08 C63 Estate
Dodger that would be great could you test the 13mm and 20mm ones and take pics?
Do you have lowering springs or coilovers on your C63 ?
Old Aug 24, 2011 | 04:02 PM
RPM, still have these?
Old Aug 31, 2011 | 10:56 AM
Staff@RPM's Avatar
Did you get your spacers today?
Old Aug 31, 2011 | 11:03 AM
I dont know. I'm at the office. Hope they're at the house.
Thanks Craig!
Old Aug 31, 2011 | 05:53 PM
Got the spacers. Only installed the rears. Looks great! Rubs under full compression, probly shouldve went with 5-8mm. The fronts I think are gonna be a problem, but didnt try them yet.
Here is the rear. 19x9.5 ET50, 10mm spacer..ET40 now..
Old Nov 28, 2011 | 07:01 PM
Mort's Avatar
Are these spacers still available?
Old Nov 28, 2011 | 07:45 PM
BK63amg's Avatar
'16 GTS Solar
FWIW I'm running 12mm in the front and 8mm in the rear...perfectly flush with slight rubbing in rear under full compression.
