Next Mod: Cams
Hopefully some time this week. Then everyone else can benefit from the R&D.
Quick question and i apologize in advanced if i missed the answers.
How much HP increase did you get after the cams were installed? Delta? Was it you or someone else who mentioned you can get an additional 100rwhp increase with just these?
We do not have any numbers for the cams yet. I am hoping for approximately 50rwhp (+/- 20). I think thats a strong possibility. The big difference is that the power with the stock sticks lays over, goes flat, or drops off after 6,000 or so rpms in most cases. We are hoping that these will continue to climb to 7,000rpms. We may know as early as later this week. Thank you for your patience.
Quick VERY BIG NEWS update!!
The MHP cams are back in my car, running like a cheetah and making numbers like we anticipated!!!!!!!! Their tuner has been able to crack the challenges and make them work.
I won't give you exact numbers yet because there is more tuning in the works. However, in Florida hot and humid conditions (78 degrees and over 70% humidity) the 500rwhp number is no longer good enough N/A!!
More to come next week so stay tuned.
All I can say is that I have been smiling since about 10:30am this morning when we made the first pull. This is going to change the game. YEEHAW!!
Boys, save your pennies!!
cant wait to see the numbers
Your patience and persistence has finally paid off. Can't wait to see the numbers.
Can't wait to see what she pulls in better conditions.
Man I am STOKED!!!
Time to go road racing!!
Whats the specs on these cams? Higher lift more duration for top end? Stock valve springs?
Whats the lift on the stock cams??
Sorry for all the Qs.. Good work guys.
I have very recent dyno numbers with all the current mods except the cams to compare. I did it when we completed the ram air set up/hood just a couple of weeks ago.
The springs are stock springs. Germans use very good quality springs.
All the specs of these cams are proprietary. Probably less than five people know the specs and it will probably stay that way. I know Andy spent a LOT of $$$ getting the stock cams identified and then specing out these new cams. I don't even know the specs and I don't care. All I know is the dyno numbers are bigger all across the graph!!
Will have a new file soon and then I'll advise.
No lift details on the stock cams??
