C63 AMG (W204) 2008 - 2015
c63 chugging violently
Old 10-21-2010, 03:43 PM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
My car started chugging today with no CEL. if anyone has any tech input it would be appreciated. Here is what I told the dealer.
Outside temps are getting cold
Oil temp was 71 F (22 C) upon cold start and car Chugged HARD when accelerating
Oil temp was hot and still had mild chugs accelerating under freeway speeds
I just did A service last week, oil was changed 0w-40 mobil 1
I put BMC filters in a week a go.
Use Petro Canada Ultra 94 gas.
Dropped the car at the dealer today they look at it tomorrow.
Update:
Dealer told me they found no codes or errors via testing but knew something was wrong after they drove it and it started chugging. I mentioned about the upstream O2 sensors, MAF, and my air filters. They still couldnt find the cause, the data they pulled was sent to Mercedes techs to see if they can figure it out.
Old 10-21-2010, 04:08 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Good thing you sent it to dealer ASAP. Some of us would procrastinate and probably do more damage to it. Hope your engine is fine, keep us updated.
Old 10-21-2010, 04:15 PM
LZH
LZH's Avatar
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Have them check the cam position sensor.
Old 10-21-2010, 04:52 PM
97W202's Avatar
2006 C230 6speed/14 C63
^ what he said
Old 10-21-2010, 05:01 PM
_AMG_'s Avatar
C63
+1
Old 10-21-2010, 05:10 PM
BEEPbeepZIPtang's Avatar
w204
CAM sensor OR MAF.
if you JUST installed new filters and any residue contaminated the MAF that would/could screw with the A/F compensation from the ECU.
or bad gas? its never bad gas but it would be great if it was!
Old 10-21-2010, 05:21 PM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
i noticed you installed BMC filters.a lot of times people soak the filter with too much oil.that will kill your MAF.
Old 10-21-2010, 06:20 PM
sighting's Avatar
e63s edition 1
.5 + bad gas
..I always blow out new filters with air when i just get them. Most people add to much oil WHEN THEY recharge them. Not really when they just bought. make sure your MAF's a re plugged in tightly and clamps closed.
Old 10-22-2010, 07:49 AM
hhughes1's Avatar
2013 Chevy 427 Torch Red
If a cam and the crank go out of sync you should be getting a "flashing" cel and be able to smell unburned fuel.
Old 10-22-2010, 08:03 AM
Former Vendor of MBWorld
Sonny@Marranos's Avatar
E55,S500,C200 KOMP,SV300 ,LANDCRUISER SAHARA
As others have said if your filters had too much oil,or were over oiled,it could have contanimated your maf sensor,Though i have had 2 c63's in with similar issues thru the shop,it turned out to be the up stream o2 sensors.
regards sonny
Old 10-22-2010, 08:43 AM
ATL_MB's Avatar
2010 C63
I thought that chugging was normal. I am getting less than 10 MPG around town and around 19 on the highway.
Old 10-22-2010, 08:54 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I hope you removed your BMC filters before bringing it to the dealership? They might not honor the warranty work due to the aftermarket filter. (if the problem is caused by it)
Old 10-22-2010, 05:34 PM
Update:
Old 10-22-2010, 11:36 PM
Roswell's Avatar
Sorry to hear they didn't find the problem... is your car driveable though? Are you taking it to Mt-Tremblant?
Old 10-22-2010, 11:42 PM
Not sure yet, they are looking at it tomorrow, It would be frustrating because I just rushed to buy a set of Michelin PS2's for tremblant. Tires came in today.
Old 10-22-2010, 11:44 PM
sighting's Avatar
e63s edition 1
Go to the hardware store and buy three bottles/ cans of Touline and pour it into your tank. I bet you $50 problem solved
ps if you rank is full 3 cans if it's half 1-2 cans
Old 10-23-2010, 01:23 AM
Update:
Thats ridicolous,its easy to log upstream o2 activity and easy to tell if they are functioning correctly,if they cant do that as a merc dealership,they might as well shut shop ,get someone independant that knows how to use a logger and log o2 activity when it chugs & you will know right way which o2 sensor it is.
regards sonny
Old 10-23-2010, 12:01 PM
Roswell's Avatar
My dealership took 2 times before they found out which 02 sensors was defective... it was starting to make me worry. I'm glad they resolved my issue, hope you will have better chance today blackbenzo!
Old 10-23-2010, 11:35 PM
regards sonny
Today the dealer mentioned it may be a cam position sensor. Will find out more Monday. I emptied my gas tank and filled up again... no chugging. Maybe condensation leading to water in gas? Still bringing it back to the shop on Monday.
Old 10-24-2010, 12:02 AM
Can you do me a favour,it seems as though this dealer is full of morons who dont know their product,i,ll give you some instructions you can follow urself to see if it has faulty o2 sensors.
- Jack the vehicle up and remove the lower plastic tray.
- Under the transmission bellhousing you will see the o2 sensors plugs.
- Follow the upstream sensors to the connector and unplug them both.
- Then take the car for the drive to see if the issue is still there.
- If the issue is gone,then you have faulty o2 sensors,if its still there,then its not the o2sensors,Just a note,you will get a check engine light,but dont panic,its becuase the o2 sensors are unplugged,let us know how you go
regards sonny
Old 10-24-2010, 12:35 AM
Roswell's Avatar
I'm glad the chugging is gone. I don't think it's a bad cam sensor 'cuz you would get a CEL & the car would probably be on limp mode. Maybe you fixed your problem. So you're leaving your car at the dealer until Monday?
Old 10-24-2010, 01:43 AM
mthis's Avatar
Anything W/4Wheels
regards sonny
Sonny can you provide us with the part numbers for the O2's i had mine replaced bc of this problem and it starting to come back so i might as well just keep them in stock just incase, BTW my teck told me its from running race gas is that possible?
Old 10-24-2010, 02:00 AM
regards sonny
Thanks Sonny, I will try this on monday. I think some of the people at this dealership are just collecting a paycheck whereas you obviously have a real passion for cars. Too bad you are so far away!
Old 10-24-2010, 03:22 AM
I will get the part numbers for you tomorrow as we have replaced quite a few o2 sensors on c63's,& yes race gas doesnt help either,its shortens their life span quite quickly,Contanimation is another killer for 02 sensors,ppl put all sorts of home remedy solutions down their tanks,that was oki in 70 80's,these days alot of the modern cars have wide band sensors for precise fuel control at 0 to 90% throttle conditions.
regards sonny
Old 10-24-2010, 08:13 AM
Roswell's Avatar
I agree with you blackbenzo, after the warranty expires I'm taking my car to Young's garage on Preston... I heard great reviews about them on the net. I also talk to the owner, he is very knowledgeable about AMG cars... their price is at least 25% cheaper too. They specialized in Benz & Volvo.
Quick Reply: c63 chugging violently
