C63 AMG (W204) 2008 - 2015
C63 with Oe-tuning 1/4 times
Old 11-23-2010, 01:37 PM
  #51
RStevens63's Avatar
E63
Originally Posted by propain
This is where I come in! My turn next.
The Stig!
Old 11-23-2010, 01:38 PM
  #52
dodger63's Avatar
2013 f250 6.7 diesel
Originally Posted by Staff@RPM
I would say, if you want to really tell what your car runs, eliminate the fastest run and the slowest run and then average the rest of your runs. I would say that would be a good real world outcome to how fast your car was that day. You can't really take your fastest time ever and say this is how fast my car is even though everyone does. The real world is what we live in and I would say that would be a fair indication of what your car does. I know everyone also talks about the altitude and everything else but the bottom line is that the weather is what it is and there is nothing you can do about it. Average all your times, eliminate the fastest and the slowest and let's see what everyone's time is, how does that sound?
To me anything you say about drag racing I take like it's law.. Not sure if people no exactly who you are or you like saying but.. Like I said I take it as law!!
Old 11-23-2010, 01:45 PM
  #53
PetroC63's Avatar
2012 CTS-V
+1
Actually, in my Eurocharged/MBH thread I took the averages of my
runs before and after header install to compare the actual gains
and apparently that didn't make sense to some.
They kept comparing my previous best run to my current best run
which to me doesn't tell the whole story.
..but I do understand why they were doing it.
  #54
propain's Avatar
See Sig
100% correct. But thats no fun!
I would hate to throw away my fastest times! How dare you!
Old 11-23-2010, 01:54 PM
  #55
PetroC63's Avatar
2012 CTS-V
Agreed.
Averaging times are a more accurate assessment of what your car is
really capable of imo.
...but I would never throw out my best time.
Old 11-23-2010, 01:58 PM
  #56
RStevens63's Avatar
E63
That is one thing I would change about this post, you can in fact do something about the weather and by doing so it eliminates another variable. You can't compare -200' DA at ATCO to 9000'+ DA at Bandimere. Correct for weather then average.
Old 11-23-2010, 02:02 PM
  #57
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Originally Posted by RStevens63
He 60' 1.85 on his 11.93@118 pass, so it's going to take a lot more than a 1.8X to do it.
Then I guess he will never make it to mid 11s. The point is that he needs more practice.
Old 11-23-2010, 02:07 PM
  #58
RStevens63's Avatar
E63
I think he needs more than practice. He made 10-15 passes and only 1 was in the 11s and it was an 11.9, DA wasn't bad at all (not great) and with 1.85 he wasn't spinning.
Jon really needs to post the ETs/Traps of all runs. I heard the three DR runs were 12.1@116, 11.9@118, 12.39@115.
Would be nice to see all the data.
Old 11-23-2010, 02:14 PM
  #59
Benz-O-Rama's Avatar
6lb's per gallon. At 60F. The colder, the more weight.
Makes a big difference. I think our tank holds 18 gallons.
Crap, I got it confused with a gallon of milk.
Old 11-23-2010, 02:16 PM
  #60
118E63's Avatar
amg
He needs more power....
Old 11-23-2010, 02:18 PM
  #61
propain's Avatar
See Sig
C63's run good on milk!
Old 11-23-2010, 03:02 PM
  #62
dodger63's Avatar
3 dr runs if I'm correct was more like 7
Old 11-23-2010, 03:07 PM
  #63
SonnyakaPig's Avatar
MB
Originally Posted by MB_Forever
Going by trap speeds alone is not always the best way of comparing horsepower. To do it right would entail factoring in other factors, such as, how much wheel spin was in the 60' for a specific run as well. For example, if someone pulled a 1.6 60' and trapped 120 mph and someone else pulled a 2.1 60' and also trapped 120 mph, those two cars are likely not equal in power. Being on street tires generally helps trap speeds as you've seen today. It would've been nice to see some runs from RalieghC63 with street tires in good weather. And it would've been even nicer if RalieghC63 had ran side by side with you on the same track and same day today This would've provided the ultimate data in my opinion.
EDIT: RalieghC63 beat me to it.
First, Jon, I wanted to say congratulations on your runs. They are very impressive. You obviously have a strong car.
MB_Forever, I agree with your post. I just wanted to point out another factor that sometimes plays into the 60'/trap mph equation.
Sometimes, the 60' can be bad on C63's if they are running on street tires and they don't have an LSD and they wheelhop at launch. This slows the car down for the 60' time, and effectively places the car further down the track, leaving it less room to build maximum speed.
So, sometimes, 60' can be high and mph can drop.
Old 11-23-2010, 03:14 PM
  #64
MB
Originally Posted by Jons95c36amg
Oh here we go with the lbs issue. I'm 140 but I had more than 1/2 tank of gas.
I understand that extra gas increases the cars' weight but I believe it's better to have at least a 1/4 tank of gas, probably between 1/4 and 1/2 in the tank when you're going to push the car. I have found that my car is very sensitive to gas level and when it starts dropping below 1/8 of a tank I never let the rpms get too high (short shift).
Sorry, kinda off topic.
Old 11-23-2010, 03:20 PM
  #65
MB
Generally speaking, for every 100lbs you shed, you pickup ~.10 in the 1/4. Also keep in mind that a gallon of fuel weighs ~8 lbs.
Do you have any idea of how the .10/100lbs ratio factors into 1/8 mile tracks?
Old 11-23-2010, 03:30 PM
  #66
MB
Originally Posted by dodger63
At the end of the day we should all agree that these cars are fast tune only into the 11s!! You all should be happy!
I completely agree.
I came to the C63 platform from the 5th gen Camaro platform. When you look at the 1/4 times for the Camaro's with blowers you find that it isn't very easy for those cars to get into the 11's. The car can do it obviously, but it definitely isn't being done with anything near 415-430 rwhp.
It's really amazing actually that the C63 performs how it does. Your car for example would destroy most blown 5th gen Camaros, and I'm talking cars with 550-600 rwhp, cars with centrifugal blowers, which are great for 1/4 mile racing.
Old 11-23-2010, 03:33 PM
  #67
dodger63's Avatar
Multiple runs in same car with differnt weight not an exact science but seems close to reality same car same day??
Old 11-23-2010, 03:43 PM
  #68
MB
I hear you, it's not an exact science. But I'm trying to find out if the same ratio -- 100 lbs weight savings = (approximatly) .10 lower ET -- applies to 1/8 mile tracks.
Old 11-23-2010, 03:45 PM
  #69
MB_Forever's Avatar
E63 P30, CL500 Sport
Originally Posted by PetroC55
+1
He was talking about averaging the runs for that specific day, which would essentially give you an idea of how fast your car really was specifically on that day and on that specific track. You can not, however, take the average runs from a different day, different track, different weather conditions and compare them because the numbers would be skewed depending on which track you made more runs on. And things would get even worse if you would take the average of those runs and compare them to yet another average after certain mods from another track. I think the average suggestion works best for comparing runs made on a certain day.
Old 11-23-2010, 03:58 PM
  #70
MB_Forever's Avatar
I understand and agree that on a few occasions that may happen, but I would think the difference would not be that dramatic. Also note that the C63 is not a naturally "hopping" car. They are engineered extremely well for street launching. In fact, it would be very hard to get the C63 to actually hop on street tires. In the past 3 years, I've been to the track countless times and seen many C63 and even drove a couple and I've never seen ONE hop ever. The Cadillac CTS-V (previous generation), however, was famous for hopping no matter what we did to it. Also the 1998 to 2004 Mustangs were hoppers as well. I can only see the C63 hopping once in a while and mainly due to maybe bad burnout or track conditions or some other external condition
Old 11-23-2010, 04:13 PM
  #71
Former Vendor of MBWorld
Staff@RPM's Avatar
The reality is that drag racing is done with another car in the lane next to you. If that car beats you, guess what, you lose. You cant use any excuses when you lose the round, if it's eliminations you're going home early. As for the numbers, the track should have a scale at the end and you should be putting your car on it and recording the weight after your pass with you in the car. With that information you can calculate the horsepower fairly accurately on the pass.
Old 11-23-2010, 04:15 PM
  #72
PetroC63's Avatar
2012 CTS-V
I understood exactly what he meant and I agree with you.
So, it's incomprehensible to compare the average of my runs from
October 29th.
Island Dragway - October 29th 2010 - RENNtech Air Box**
Run 1: 12.151 @ 116.29 (DA: -37)
Run 2: 11.972 @ 117.39 (DA: -123)
Run 3: 11.850 @ 118.37 (DA: -194)
Run 4: 11.933 @ 117.89 (DA: -194)
Which average to 11.976 @ 117.485
...to the runs post header/tune installation on November 21st
and get an idea what the car really gained?
Which average to 11.62 @ 120.236
Now, I understand it was a different day with different weather
and the times should be adjusted accordingly based on the
differences in DA. Imo, taking the averages is the proper way
of coming to an informed conclusion.
I'm not being argumentative in any way just trying to get
clarification. Am I off base for looking at it this way?
Old 11-23-2010, 04:29 PM
  #73
RStevens63's Avatar
E63
October 29th.
No, you can compare that data, as seen below. You have to because you didn't bolt your headers on at the track the same night you tested the RENNtech airbox
Average from one night vs Average from another using the same track. We can correct for weather so that helps eliminate another variable:
Originally Posted by Petroc55
If you look at my October 29th runs with the RENNtech air box which
are my last runs prior to the headers/retune the average of those
runs are 11.976 @ 117.485.
And yesterdays runs averaged: 11.62 @ 120.236
That's a .35 seconds and 2.75mph gain on average despite the DA being -500' better for the headers and mids.
Best run to best run (both were single runs not backed by another 11.8@118+ with airbox or 11.5@120.5+ with all 3 mods) we are looking at a 11.85@118.37 vs 11.58@120.66 or a difference of: .27 seconds and 2.29mph using average runs before vs after at the same track correcting for weather
Correcting the 11.85@118.37 to -700' (as the headers were run) assuming -200' for the RENNtech airbox and tune pass to start, we get 11.78@119.012 for tune & airboxes. Now compare that to the best + header pass of the night 11.58@120.66 and we see a .2 second and 1.65mph gain in the same air, same track, all things equal.
Respectable for sure, but not .4 and 4mph.
Old 11-23-2010, 04:31 PM
  #74
dodger63's Avatar
Ok I averaged my day at atco out... Took out my best and worst..
I came up with 11.327!!! That's a good true average of my day I'll list all my times average 60' was1.698
Run #:
1: 11.291 @123.25 1.706
2: 11.317 @125.29 1.641
3: 11.361 @124.80 1.700
4: 11.291 @125.37 1.629
5: 11.291 @124.76 1.692
6: 11.363 @125.60 1.727
7: 11.372 @124.67 1.741
8: 11.304 @125.19 1.718
9: 11.374 @124.80 1.714
10: 11.219 @122.17 1.663
11: 11.337 @121.64 1.686
12: 11.335 @121.74 1.693
13: 11.330 @122.29 1.688
14: 11.330 @125.09 1.713
15: 11.386 @121.69 1.728
16: 11.305 @123.96 1.693
17: 11.305 @121.89 1.687
Those are all my runs
Old 11-23-2010, 04:36 PM
  #75
RStevens63's Avatar
E63
Run #:
1: 11.291 @123.25
2: 11.317 @125.29
3: 11.361 @124.80
4: 11.291 @125.37
5: 11.291 @124.76
6: 11.363 @125.60
7: 11.372 @124.67
8: 11.304 @125.19
9: 11.374 @124.80
10: 11.219 @122.17
11: 11.337 @121.64
12: 11.335 @121.74
13: 11.330 @122.29
14: 11.330 @125.09
15: 11.386 @121.69
16: 11.305 @123.96
17: 11.305 @121.89
Very consistant and Very impressive! Great work per usual.
Is Jon going to post all his runs?
Quick Reply: C63 with Oe-tuning 1/4 times
