C63 with Oe-tuning 1/4 times
My Top 16 Times - They are all under 12 seconds and two different tracts on diff days..
Sorted by MPH..
Time MPH 60' Date Time Track
11.896 116.91 1.891 10/22/2010 11:39am MIR
11.808 116.98 1.819 10/22/2010 3:17pm MIR
11.901 117.09 1.866 10/22/2010 10:21am MIR
11.891 117.27 1.862 10/22/2010 9:53am MIR
11.997 117.92 1.91 2/20/2010 2:34pm ROCK
11.818 118.23 1.866 10/22/2010 2:14pm MIR
11.893 118.27 1.795 10/22/2010 2.00pm MIR
11.806 118.55 1.881 10/22/2010 3:22pm MIR
11.962 118.73 1.868 2/20/2010 2:27pm ROCK
11.946 118.80 1.886 2/20/2010 1:09pm ROCK
11.975 119.01 1.867 2/20/2010 4:25pm ROCK
11.756 119.14 1.828 10/22/2010 2:06pm MIR
11.78 119.44 1.84 10/22/2010 4:19pm MIR
11.647 120.10 1.751 10/22/2010 4:25pm MIR
11.729 120.34 1.832 10/22/2010 4:22pm MIR
Sorted by 1/4 time:
Sorted by MPH..
Sorted by 1/4 time:
02 CLK 55 AMG,09 C63 loaded with P30
Yes sir. I was using DR's... I may be wrong but I don't think you can go by the trap speed alone because that just means that you were spinning more than I without drags so your trap was higher...
Not much to drags, just a little heat in them first and then mash the go pedal. I do understand that it takes some time to get used to anything when it's new.
You need to get some drags.. You won't do much better without them.
You had some great times... Just wanted to post my **** as well.
We really need to get a tune only drag day going before they close the tracks.
Boy that would sure fire up this forum wouldn't it????
Can you hear the post already????
Good job and keep it up....
E63 P30, CL500 Sport
EDIT: RalieghC63 beat me to it.
#33
Going by trap speeds alone is not a good idea. To do it right would entail factoring in how much spin was in the 60' for a specific run as well. For example, if someone pulled a 1.6 60' and trapped 120 mph and someone else pulled a 2.1 60' and also trapped 120 mph, those two cars are not likely not equal in power. Being on street tires generally helps trap speeds as you've seen today. It would've been nice to see some runs from RalieghC63 with street tires in good weather. And it would've been even nicer if RalieghC63 had ran side by side with you on the same track and same day today This would've provided the ultimate data.
#34
So Jim out weighs u by 70#s + your factory breaks are allot lighter in the rotational mass. Say on the low side = to 50#s physical mass brings u to aporoxiamatly 120# lighter and I do not no how much gas he had but say it was a1/4 your talking approx. 35 lbs extra in fuel you still are 85lbs lighter! I no you will come back with something else but... These numbers don't lie
#37
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
I was at the track watching Jon (we all tried to help him) and I'm sure that with more practice his times will get better. Especially his 60'. Until he gets into 1.8x range, he will not see mid 11s.
#41
Generally speaking, for every 100lbs you shed, you pickup ~.10 in the 1/4. Also keep in mind that a gallon of fuel weighs ~8 lbs.
#42
He 60' 1.85 on his 11.93@118 pass, so it's going to take a lot more than a 1.8X to do it.
#44
Jon, did you only run 3 times the whole day? I was under the impression you guys can get at least 10 passes in private rental events If not, it'd be nice to see all of your time slips so we have more data to compare just like how Petro and RelighC63 posted all of their runs. I could've swore reading somewhere that you ran a 12.3 @ 115 on DR as well
#49
Former Vendor of MBWorld
I would say, if you want to really tell what your car runs, eliminate the fastest run and the slowest run and then average the rest of your runs. I would say that would be a good real world outcome to how fast your car was that day. You can't really take your fastest time ever and say this is how fast my car is even though everyone does. The real world is what we live in and I would say that would be a fair indication of what your car does. I know everyone also talks about the altitude and everything else but the bottom line is that the weather is what it is and there is nothing you can do about it. Average all your times, eliminate the fastest and the slowest and let's see what everyone's time is, how does that sound?
#50
