C63 with Oe-tuning 1/4 times
02 CLK 55 AMG,09 C63 loaded with P30
Ok today at Atco was track rental. Temp was almost 65F. I didnt break any records but I'm happy. Here are my slips.. One slip was with DR. I borrowed Dodgers63 DR so couldnt really get the burnouts quite right. So with lower DA I should trap 120+ and better E.T.
Nice job out there today..
Temps posts on drag times:
8:35 AM 50.0 F 94 % 30.36 in
8:46 AM 50.0 F 94 % 30.36 in
8:54 AM 50.0 F 96 % 30.36 in
8:59 AM 50.0 F 94 % 30.36 in
9:17 AM 50.0 F 94 % 30.35 in
9:24 AM 51.8 F 94 % 30.35 in
9:54 AM 53.1 F 89 % 30.34 in
10:17 AM 55.4 F 82 % 30.33 in
10:54 AM 57.9 F 72 % 30.32 in
11:54 AM 62.1 F 60 % 30.28 in
12:54 PM 64.0 F 56 % 30.25 in
1:54 PM 64.9 F 50 % 30.23 in
2:54 PM 63.0 F 54 % 30.21 in
3:54 PM 61.0 F 62 % 30.20 in
4:54 PM 59.0 F 67 % 30.19 in
What time was your run? How far is the Airport from ATCO anyhow?
I'll say it again good job!! But do everyone a favor and stop making excuses and get out there and do the work to get the numbers. Watch people.. See how they do things.. Proper burnout, staging, driving in s instead of pretending you are faster and can figure out how to shift better then the cars ecu that's taking more than looking at a wrong tach into consideration!! There will be 2 more rentals at least so get yourself a pair of drags an open mind and do some work!
Originally Posted by Jons95c36amg;4365365R
I ran around the warmest time-64F.
Honestly today was ideal conditions can't ask for much better than 65 degrees for good traction.
If I can get my car set up by this weekend, I will be running in 40 degree temps; sucks for traction, great for traps. We'll see.
Today was a good day! There were zero traction issues.. I'm honestly going to try to run on streets I think they trap better?? Trickier to launch but better results!!!!
E63 P30, CL500 Sport
First, congrats on your runs.... I'm sure you'll continue to get better
Second, notice that Mike ran almost identical times in the -296 DA conditions as he did today in the +90 conditions you mentioned. In fact, he ran better ET in +90 DA and almost matched his highest trap speed. This suggests that the difference in conditions was very similar between the two days and/or the difference did not affect times significantly as Mike did NOT change anything on his car. Applying this to ReilghC63's car, I would think he would have run very similar times as he did at MIR.
Third, if you look at oldgixxer's old run.... you will see that he actually pulled a better 60' time on stock continental tires (terrible in terms of traction) than your 60' on drag radials! I know you still think you can beat his stock time but in my opinion, had he been there today, I think he would've edged out the C63 a little.
Ok it's time for me to ring the bell on this since I have sat idle for a while.
You had some great runs and you do have a fast tune only car. No questions. However the DA that was posted on dragtimes was actually not accurate. The DA on my 11.64 run was actually -192 DA according to www.smokemup.com. The DA calc on dragtimes isn't accurate and this is what I was using.
Below are the corrected and uncorrected times of both our Tune Only cars.
Jons95c36amg
Un-Corrected ET:
11.935 (sec) @ 118.56 (MPH)
Corrected ET to Sea Level:
11.908 (sec) @ 118.837 (MPH)
Raleighc63
Un-Corrected ET:
11.64 (sec) @ 120.18 (MPH)
11.664 (sec) @ 119.931 (MPH)
** With DR's when you don't spin (and you normally don't spin on DRs in these cars with tune only) trap goes down when ET goes down.
Jons95c36amg
The closest weather results for 11/22/2010 at 01:33 pm
Time recorded 1:54 PM
Temperature °F 64.9
Dew Point °F 46.0
Altimeter Setting 30.23 Inches Mercury
Absolute Pressure: 30.2 Inches
Density Altitude: 217 feet
Track Elelvation: 33 feet
Raleighc63
The closest weather results for 10/22/2010 at 04:25 pm
Time recorded 4:52 PM
Temperature °F 57.0
Dew Point °F 30.0
Altimeter Setting 30.13 Inches Mercury
Absolute Pressure: 30.05 Inches
Density Altitude: -192.3 feet
Track Elelvation: 80 feet
Jons95c36amg
Un-Corrected ET:
Raleighc63
Un-Corrected ET:
Jons95c36amg
Temperature °F 64.9
Dew Point °F 46.0
Raleighc63
Temperature °F 57.0
Dew Point °F 30.0
