C63 AMG (W204) 2008 - 2015
First dyno for my stock C63 - disappointing result??
Old 12-02-2010, 10:36 PM
  #51
gyrex's Avatar
2010 C63, 2008 Audi TT Roadster (Sold)
Originally Posted by gyrex
Dyno result posted on youtube...
http://www.youtube.com/watch?v=hTZpHRYqUqk
Bugger wrong video. It's uploading at the moment.
Old 12-02-2010, 10:50 PM
  #52
gyrex's Avatar
Correct video of the dyno run here:
http://www.youtube.com/watch?v=KtwZKzzrLWo
Old 12-03-2010, 03:37 AM
  #53
AMG-010's Avatar
2017 AMG C43
Awesome gain.
How do you like the new exhaust? Any drone when cruising?
Old 12-03-2010, 03:45 AM
  #54
gyrex's Avatar
It's insanely loud and I love the incredible sound with the valves open... With the valves closed there is basically no sound at all which is a little weird so I'm hoping that there is an adjustment I can make to give it a little more volume.
I love the fact that you can have the valves completely open and have it sound like a V8 supercar but I couldn't drive around all day like that. As long as I can adjust the valve position when I press the "on" button on the remote I'll be happy because at the moment it's either ALL or NOTHING...
I'm not sold on the auto function. It's weird, at idle the car has the valves open then when the car hits 3000RPM the valves shut and you can't hear anything at all... odd.
I'm sure I can make some adjustments - I've fired off some emails and hopefully on Monday I can get it sorted out.
If the valve in the "on" position can be adjusted I'm going to absolutely LOVE this exhaust...
Did you check out my video of the run down the street?
Old 12-03-2010, 05:24 AM
  #55
Exacc's Avatar
E46 M3, '09 C63
awesome video! Crazy loud! Wow! Car looks good!
Old 12-03-2010, 07:23 AM
  #56
AMG-010's Avatar
2017 AMG C43
That exhaust sounds amazing...
I thought the auto function worked on throttle position. The wider open the throttle the louder it gets.
Is there any drone in the cabin when cruising with valves open?
Old 12-03-2010, 07:34 AM
  #57
gyrex's Avatar
That's what I thought the auto function did. I guess I need a little more info on it... I think the exhaust valves need to be tweaked a little bit - I'll try and sort it out on Monday.
There is a little bit of drone if you put it in Comfort mode with the valves open. To be honest I think if you're driving in comfort mode you're probably going to have the valves closed anyway. When you want to have some fun you press "open" on the remote to open those valves up, press the ESP button, 2 presses on the gearbox button and away you go
The car sounds incredible when you drive it hard. It kind of sounds like a cross between a formula 1 car and a V8 supercar - fantastic note!
I've only just had mine installed but Harun (RNS-11Z) has had his on for quite some time now so he's probably the best source of info...
Old 12-03-2010, 07:38 AM
  #58
gyrex's Avatar
Over the weekend I'll shoot another video from outside the car with the car going to redline so you can get a feel for it.
I'll also get some videos of the car with the valves closed and in auto to give everyone a better idea of the exhaust.
Old 12-03-2010, 08:25 AM
  #59
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Excellent. You car sounds beefy like a lamb shank. Hope you can now sleep better at night.
Old 01-04-2011, 10:58 PM
  #60
AMG-010's Avatar
2017 AMG C43
I am considering putting the same system on my car.
Are you still happy with it? Any regrets?
Old 05-28-2020, 08:20 PM
  #61
Rabih75's Avatar
C32
OK, got the car back....
WOW!!!!! Damn you can feel the difference, it's a completely different animal now!!!
The best stock run was 348HP, with the cargraphic exhaust and ECU tune I'm now getting 430HP at the rears. If my maths is correct, that's 23.5% more power????
That's insane!!!
I'm uploading the dyno results and exhaust runs to youtube now.
very impressive results even for 2020, 10 years following the initial post..
with EC V7 and Kleeman LTH, K&Ns my p31 2013 put down only 389.5 rwhp on a Mainline dyno today. But it managed 571 NM at the wheels.. still looking into it.
Quick Reply: First dyno for my stock C63 - disappointing result??
