C63 AMG (W204) 2008 - 2015
Video: C63 OEtuned vs E63 modded
Old Dec 10, 2010 | 09:56 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Originally Posted by AlbertM
Roads are in Mexico, Jon and I had to take sometime off and drive out there for some fun.
God I love Mexico!
Old Dec 10, 2010 | 10:00 PM
AlbertM's Avatar
E63 AMG 2010, Black, Pano, P2
Originally Posted by dodger63
Just throwing it out there for all you dyno boys... As I watch this video in the first before there are only 2 low fans.. In the second part they add a fan and also lift the other fan so it blows air into the intake,.,..
Yep, I see that. Good catch. Well, then who knows what all these mods do.
I am planning to do the last and final dyno run tomorrow. I guess we'll see.
Old Dec 10, 2010 | 10:07 PM
dodger63's Avatar
2013 f250 6.7 diesel
Keep in mind the weather and all I'm not being a spoiler but all these things add up your car looks strong compared to jons.. Good luck keep us in the loop.. Are you going to nrgy or the detail shop?
Old Dec 10, 2010 | 10:10 PM
AlbertM's Avatar
I am going to the shop next to me (Vettech). NRG is too far out. Dyno in this case wont be that important, the real world shows I gained.
Old Dec 10, 2010 | 10:15 PM
That you did!
Old Dec 10, 2010 | 10:17 PM
AlbertM's Avatar
Originally Posted by Jons95c36amg
That you did!
Jon, try taking out your charcoals, you should be able to do this without CEL. That should make a difference uptop.
Old Dec 10, 2010 | 10:18 PM
  #32
dodger63's Avatar
So is this another new place? Last question I no I'm annoying! What is the dyno going to prove your car seems to be performing better is the dyno worth the money.. Only reason I ask is cause I don't use them??
Old Dec 10, 2010 | 10:24 PM
  #33
AlbertM's Avatar
No it is the same one that I used before. That is where I dynoed 424 before and 409 after the Kleemann headers if you recall. I did 3 dynos there already.
Not looking to prove anything, just curiosity, also want to measure AFRs as well. Not worth the money, though, that is why last one and I am done with these dynos.
If I dyno low, I will gut the whole exhaust out and go with LTs (just kidding)
Old Dec 10, 2010 | 10:28 PM
  #34
I tried that before-damn CEL sick of it. Not worth the little gain wayy up top.
Old Dec 10, 2010 | 10:33 PM
  #35
dodger63's Avatar
O ok keep us posted
Old Dec 11, 2010 | 06:12 PM
  #36
AlbertM's Avatar
O ok keep us posted
Latest update:
I removed Kleeman headers and cats and put back stock manifolds + primary cat delete, did the dyno this morning:
435 rwhp SAE, (457 uncorrected), mods: Kleeman ECU, K&N, charcoal delete, ROW airboxes, primary cat delete
409 rwhp SAE, mods: Kleeman headers+hfcats, OEtune, K&N, charcoal delete, TTM airboxes
395 rwhp SAE, modes: Kleeman headers+hfcats, Kleeman ECU, K&N, charcoal delete, stock airboxes
It is over 26hp difference. So after removing Kleemann headers+cats and putting back stock manifolds (with primary cat delete) yielded a gain of ~ 26hp comparing to 409, and ~40hp over 395 run.
It is about ~10hp gain from my baseline (@424 SAE) without Kleemann headers:
OEtune, K&N, charcoal delete, TTM airbox mod: @424 RWHP.
So overall: Kleeman ECU/OEtune, K&N, charcoal delete, ROW airboxes, primary cat delete should yield anywhere from 25-40 rwhp
Old Dec 11, 2010 | 06:15 PM
  #37
GHAZAN's Avatar
MBUSA
nice data
Old Dec 11, 2010 | 06:51 PM
  #38
propain's Avatar
See Sig
Latest update:
Nice Albert. What about the torque? Post up the charts when you can.
Old Dec 11, 2010 | 08:18 PM
  #39
AlbertM's Avatar
Will post charts on Monday when I scan the print outs.
Old Dec 11, 2010 | 11:17 PM
  #40
andy_c63's Avatar
2009 C63 AMG
Was that a K-band alert in the background?
Old Dec 12, 2010 | 05:15 AM
  #41
MB_Forever's Avatar
E63 P30, CL500 Sport
Latest update:
Great data Albert, I'm glad you got this whole mess figured out Your car would be a monster with some long tubes
Old Dec 12, 2010 | 05:33 AM
  #42
AMG-010's Avatar
2017 AMG C43
This may be a silly question. Why does an E63 gain more once it's tuned than a C63?
I know they start with more power initially (386kw compared to 336kw) but aren't they the same engine just the C63 is detuned at the factory.
I would of thought they would be similar in power after tuning.
DMS Automotive claim
C63 tuned 366kw
E63 tuned 411kw
Old Dec 12, 2010 | 06:16 AM
  #43
RNS-11Z's Avatar
09 C63
where did you get those figures from? i believe once exhausts are fitted both cars put out the same hp when tuned aswell
Old Dec 12, 2010 | 06:55 AM
  #44
AMG-010's Avatar
2017 AMG C43
DMS advertised in the latest Motor Magazine.
Check out this link
http://dmsautomotive.com.au/index.ph...&id=4&Itemid=4
Old Dec 12, 2010 | 07:17 AM
  #45
RNS-11Z's Avatar
09 C63
i wonder what software they use. Have a search on here, and you will see many tuners actually make the same power as e63s with the c63s. Interesting why DMS quote such a low figure. It must be a just a slight enhancement then.
Old Dec 12, 2010 | 09:29 AM
  #46
Latest update:
Albert what was your AFR?
Old Dec 12, 2010 | 10:01 AM
  #47
AlbertM's Avatar
Kind of rich, K1 seems to run much richer than oetune. The wot afr topped out at 11.9 vs 12.9 for oetune. Not sure which one is more optimal. Could this be the reason why oetune makes more power than K1? Simply leaner AFR @ WOT?
Old Dec 12, 2010 | 03:14 PM
  #48
SonnyakaPig's Avatar
MB
What's impotrtant to stay mindful is that stock 63 tunes will vary a good deal in the AFR. It depends on many factors and I have been told by competing tuners that stock C63 AFR can even dip as low as into the 10's.
Aftermarket tunes leave a good deal of adaptation capabilities in the ECU. They do, however, set the maps so that ur car advances what has been pre-set (i.e., commanded) on demand.
An example: u have a stock C63. Stock tune. U fill up with crappy gas (91 octane but its poor quality on this day). In addition, its hot outside (100 degrees F). Ur ECU may pull timing and dump some extra fuel. In this case ur AFR may be rich. Ur ECU did this as a precaution.
Contrast above with an aftermarket tuned C63. As stated above, once u get tuned, u have a greater responsibility as a driver than u did when u were stock, because ur ECU's "nanny controls" are no longer functioning at full strength.
That means, u will have less variation in ur AFR, but that's entirely dependent on the quality of gas in ur tank and IAT's. With these aftermarket tunes, ur torque management is reduced and the car is set to run hard, on demand, always.
That's good and bad. Its good because ur carmakes more power more consistently, but if u get hit with bad gas and u don't hear things like knock or detonation, u could be running ur car at an AFR that is too lean for ur quality of octane.
I think data loggers are key once u get tuned.
And of course I'm a little more paranoid than the average person.
Old Dec 13, 2010 | 02:59 PM
  #49
AlbertM's Avatar
Latest update: dyno sheets
https://mbworld.org/forums/4409809-post29.html
