SUPERCHARGED m156, 63 amg !!!!
#201
Seeing as how I surprisingly seem to be the only one here with firsthand experience inside these transmissions, I have two observations:
1) The 722.9 are absolutely gorgeous on the inside. Beautifully machined and obviously quite well thought out. However...
2) Mercedes DID change their design due to a number of failures. Most of them were in the MCT equipped cars (2nd hand information, but from a reliable source) but there were also others, no doubt like me, that just threw caution to the wind and looked for the transmission's limit.
What does this add up to? I don't know. I just like having insider information to post.
Just kidding... What it adds up to is that the torque converter and transmission are a really tightly integrated system. They were designed together and work great, even well outside of their intended operating parameters, but when Mercedes upgraded to the MCT, they learned the hard way that they had to upgrade the internals to match the new power capacity.
One of the things RStevens has right is that Weistec does say they upgraded the transmission. I, for one, am VERY interested in what they came up with as I've done a whole lot of looking into this thing and there really aren't many solutions out there. In fact I only found two: a machined valve body and a billet internal torque converter. (The L10 clutches turned out to be not so great). However, raising the stall too much will trip the ECU-TCU into doing unhappy things, and too high a locking percentage could potentially put excessive shock load into the rest of the driveline. And as Brad correctly pointed out during one of our discussions, machining the valve body without reducing the orifice diameter will actually lower the line pressure. Kind of a conundrum. Never got an answer from the guys that do the machine work what their solution to that is...
I dunno. I'm just excited to to see someone get a blown M156 running. I hope they get it done quickly.
Josh
Josh
Didn't know about the torque converter and stall speed issue.
Mike
#202
In all, we have done some level of work on about 220 CLK63BS worldwide. Very few of the cars we build are posted here. Only those of forum members.
Either way you haven't put nitrous on 220 of them and that's the only mod available so far that adds enough torque to blow a brand new trans in less than a week. Like I said before NA bolt-ons won't do it alone unless the car is raced hardcore for XXXXX miles.
If you then add in other chassis we have likely 80-100 cars that are running with 100whp more than stock. To assume that JRCart is an anomaly is just that, pure assumption. He is just the poster child due to the magazine cover article, the fact that he was first and the fact that he is so active on this site.
Ok, so you seem to know the limits, please educate us. I have cars making into the high 500's and 600's wheel torque that are not breaking tranny's.
Please show me a 600rwtq dyno graph from a 63 AMG, you know because the trans torque limiter(s) don't allow that much twist to be fed through the trans it would be interesting to see.
This is a very condescending comment, but I will reply. First, please don't ask me rhetorical questions (again, they are just condescending and rude).
Second, we, including I, have had ZERO apart as not one 63 we have ever worked on save for Josh has broken. And Josh's broke after he worked here and he took it to the dealer. So in 300+ tuned 63's that have come through here since 2008, we have had ONE fail. And that one admitted to abusing it.
Back at ya, how many have you had apart? I speak from experience, not hearsay.
So you are not speaking of first hand experience? Interesting that you would attempt to minimize my opinion but yours is valid even though it is not first hand? (that is the condescending part that I was referring to).
I have seen very detailed images of the tranny apart after failure and have had long discussions with Josh about his. So it is safe to say, I have as much info at the very least as you have.
Have you ever built or rebuilt a transmission ever? Of any make or model?
Comments like "you will get there too" assume so much and are again so condescending.
Keith had a failure. Others have not, including Jim (who is nearly as fast and has as much HP and has sprayed at least as many times if not more).
So why does that make the part the problem. Maybe Keith was not lucky and had a bad unit, then the aftermarket items he used were not up to snuff.
Truth is that none of us know, and assuming that the tranny is to blame is just that - assumption and speculation at this point. Far more data points of failure need to be found to come to that conclusion. Right now, 2 in 300-400 highly tuned cars that I know of have failed (I am including cars we have built as well as cars from other tuners).
I can google or look at pictures and count as well as anyone, but speculating that something will not work is again, just that. More assumption and speculation. You may be correct, you may not be. But to make authoritative statements of fact that are just guesses is a real pet peeve of mine.
Actually, they can be broken by either. I have seen high HP cars with low torque (BMW Forced Induction M3's) rip apart transmissions way faster then AMG high TQ cars. It is all about the package, the way power is delivered, etc.
However, you are on to a very good point. In another thread, we are talking about headers. 4-1 v 4-2-1. We tried both, use the Try-y. The 4-1 produced more torque down low, but far too much. Why would you add more tq to a tq heavy car.
FWIW, I would love to see pictures of your 4 into 1s, surely you must have some laying around.
That is counter-intuitive. To cars with low tq, you tune more tq in. To cars with low hp (relative to tq), you tune more hp in (at least we do). It is possible that Keith is breaking his trans/converter due to the package he has. We found all kinds of issues with the 4-1 as far as the torque limitations, the drive line shock, the erratic nature of acceleration as the electronics fought the car. Overall, the car was faster and better/smoother to drive with the try-y. So, yes, there is one very fundamental difference between a Keith's and Jim's cars - the header design.
So instead of thinking along the lines of a larger shot making more torque because that's what nitrous does better than anything (make torque) you want to blame header design.
That is yet another assumption and is the most unfounded one yet.
You must be joking, you have to be???
Your questions might or might not be valid, that is up to Weistec to decide. It is their product and they can decide that for themselves. And again, the info you are questioning is based on one drag racer, correct? There are not multiple people out there with this failure that I have missed, are there?
If Weistec doesn't do what they said they would with the trans, I wish them the best of luck.
No, Keith isn't a drag racer, he is a Racer. Open track, drag, whatever, he is a true performance enthusiast.
Do you think that future Weistec owners (if the product is released as planned) won't drag race their cars? You don't think they will go WOT through the gears a few times even if they don't?
Again, give them a chance. I don't know them more than a 5 minute phone conversation, but they are not sponsors, they did not start the thread and they have professionally agreed not to post till they are paying sponsors. How is that the same as ignoring questions? Are we really so impatient?
Brad
Brad
Overall I think you need to get your hands dirty and spend less time posting.
Robert
#204
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
#205
Disagreeing and correcting the site admin? If so that makes for a sad site.
I would prefer a technical discussion with additional questions and answers, but if I get banned for posting what I just did, so be it, that would mean this is not the kind of forum I want to be associated with anyway.
I didn't break any rules, violate the tou, etc so it would be a purely personal ban.
#206
Well in the interest of full disclosure, why don't you give us all a bit more info on your background? You seem to know the aftermarket game pretty well, have contact with former Kleemann employees in Europe and apparently know quite a bit about exactly what Brad does, etc...So, who are you - really? Do you work for another tuner? Is Robert your real name? If you know so much about AMG's, why not give us a bit more info about who you really are so that we can draw our own conclusions about your technical knowledge.
#207
Yep I know a lot of people in the aftermarket, not just MB & AMG, it's nice to have friends.
I don't know Brad from Adam, but when you work in this business (actually building hardware) you can tell from reading someone's posts if they are on the same level or even close to it.
#208
Brad,
My "package" is the same package that just ran the 10.8 at over 131mph. Its a great package and it runs those numbers because of the torque and HP it puts out. I don't really understand why you would want someone to make headers that produce less torque on a car that you call "torquey" when these cars are heavy and need torque to get moving. Thats some of the difference in the performance of the different packages that don't run the numbers. Don't see how we can complain about having too much torque??
Can I ask a logical question? JRCart has talked about his 10 second passes over and over and never posted a single time slip or video that I know of? He always says he has nothing to prove but I am asking. Where are the videos and time slips?
My car has grown up 1/4 mile at a time and when it was allowed to stretch its legs it was road racing. Neither of which are really good on a tranny. Hundreds of burn outs, launches, and runs. I admit it got abused and never said it wasn't. It was absolutely flawless until we installed the nitrous. Not a single hick up or miss shift until the first night we took it out on the nitrous. The car was making incredible torque and HP and the tranny was tired and worn out. Its as simple as that. We replaced the internals with L10 parts and returned to the track with the nitrous and destroyed it again. Doesn't matter how or even why, it didn't survive.
We have since put a newer design tranny in like Josh's and will run it N/A for now. I may use the nitrous for the mile runs so we can get over the 200mph mark. Other than that the Nitrous set up is good for car shows.
I don't understand why you guys need to argue about the tranny and its potential. In "MY" case it didn't survive. Maybe there are others like JRCarts that have have managed to survive. Maybe the black series is lighter and therefore doesn't put the same amount of strain on the drive train. I don't have an answer and it doesn't matter. Mine is fixed and ready to go.
#209
Luke, stop wasting your time. I have.
He has no clue who I am or what I have or haven't done. RStevens, for the record I have built and rebuilt my own track record holding and wining road race cars for many years before founding evosport (Yes, including transmissions, diffs, valve jobs, etc). I am not a certified trained tech by a long shot, but mechanical work is not rocket science. With logic and experience or good instructions, many of us on this forum could rebuild nearly anything mechanical on a MBZ.
Further, I think our 12 year record of pushing the performance envelope gives me some ability to have this discussion. RStevens has an agenda and I am done debating people who cannot discuss things without being rude and condescending!
Let it go! As my mentor always said, to fight a gutter war, you have to be in the gutter!
brad
brad
#210
He has no clue who I am or what I have or haven't done. Not only do I have a JD/MBA, I also built and rebuilt my own track record holding and wining road race cars for many years before founding evosport (Yes, including transmissions, diffs, valve jobs, etc). Further, I think our 12 year record of pushing the performance envelope gives me some ability to have this discussion. RStevens has an agenda and I am done debating people who cannot discuss things without being rude and condescending!
brad
brad
Valve jobs? What kind of machine, what valve angles, what heads? That is my forte so I'll be glad to listen to whatever you have to say.
Be proud that you own the company but don't take credit for the work of your staff/techs. That's only fair.
This is a technical discussion, and I'm sorry you've found certain comments to be condescending, I felt the same regarding some of yours but am still here to amicably discuss tech.
My agenda is to seek the truth and ultimately learn and help others, hopefully that is within the guidelines of this site's membership.
Thank You
#211
Brad
#212
That is the exact point Keith. In YOUR case it failed. In MANY other cases it has not failed. Yet RStevens wants to push the agenda that your failure means it will fail for anyone. THAT is the point. I have a problem with people preaching FEAR in order to push an agenda.
Brad
Brad
With all due respect, how many other cars are at Keith's level? How many have sprayed 160+HP worth of nitrous (and torque) on top of a full bolt-on M156? 2 (Keith and JL)? How many have done it as many times as he has on sticky DRs on a prepped surface? 0. Even JR hasn't sprayed a 160 shot.
I have nothing to gain by putting "fear" into anyone's mind, however the trans hardware & software issues do need to be addressed. This is not just my opinion as Weistec even admitted to making changes there to accomodate the supercharger.
Thank You
#213
My last reply to you on this topic, period is this:
HOW IN THE WORLD DO YOU KNOW WHAT JRCART (JIM) HAS OR HAS NOT DONE? HOW DO YOU KNOW WHAT PEOPLE IN DUBAI, AUSTRALIA, JAPAN, CHINA, QATAR, KUWAIT, ETC HAVE OR ARE DOING?
Things exist and happen that are not reported on this site or on drag times. I would say only about 5-10% of Mercedes modifying customers even know what those sites are based on the fact that less than 5% of our AMG business comes from this site.
You should REALLY think about that question. You continue to post things as if you KNOW when you really just have opinions and assumptions.
Have a nice weekend!
Brad
Brad
#214
2007 E63 w/P30 and Eurotech CF Diffuser
Someone clarify for me.
There has been no success in developing a useable supercharger aftermarket product for the M156.
Instead everyone is argueing about what would break if you had the product.
"Force it, and if it breaks, it needed replacing anyway."
#215
JR's accomplishments have been well documented on this forum. I read everything about his car I could. It was never claimed he went over a 100 shot.
I have as many connections to racers in those countries as I do in the U.S. Do I know it all, no, but word travels incredibly fast when someone has a car worth noting.
Sorry but there are no cars in Japan comparable to Keith's or JRs. I wouldn't have even listed that one
Anyway, that door swings both ways, how do you know that Keith is the only one aside from Josh to have blown his trans? A: You don't either.
I highly doubt only 5% of your business comes from MBW, if that were truly the case I don't think you'd stil be running it (wasting the time online). I could be wrong, but MBW seems like a cash cow to me?
Brad
Brad
Please enjoy your weekend as well. Hopefully we can have a civilized discussion next week.
#216
Problem is no one can upgrade the parts necessary to do so.
#217
It is because of the very reasons you cite (driveline breakage) that no FI kit exists. Others have gotten as far as Weistec aka Brabus, MKB and others, however they couldn't get past the trans and converter issues.
Anything can be done - it just takes money. As evidenced by this thread:
https://mbworld.org/forums/w211-amg/...?highlight=pos
If that guy who spent $31k for a crankshaft had put his money towards building a new 722.9, I'm sure it would be unbreakable. But, some people are very misguided...and while the build was unreal and the car is very very fast, it's still a POS IMO.
#218
2008 A8L, 2002 996TT X50, 2009 X5
I'm a firm believer that damn-near anything is possible if you throw enough money at the issue.
Why can't the 7G be upgraded to withstand the higher limits? Couldn't the stock metal parts be cryo-treated for greater strength? Couldn't grippier friction surfaces be spec'd to hold greater TQ?
While debating the cost/benefit is another issue, I have a hard time believing you couldn't call up AMG, Brabus, RENNtech, or maybe a trans specialist like Southern Hot Rod, and say "hey, here's $20k - build me a bullet-proof (hardware) 7G trans." It literally can't be done?
#220
Brad
Brad
I made this EXACT argument not long ago on this forum...
otherwise I haven't been keeping up with this thread so I have no clue what you guys are debating.
#221
Problem is the trans software. Unless you can account for the upgraded hardware via software, the hardware is useless; again as we saw in Keith's case, even with L10 internals BAM 6 passes and 50 miles later another trans died.
Then there is the 3 clutch converter. Just never going to hold the tq, it physically can't.
#222
AFAIK, there are 4 factory trans tools that can remap a 722.9 TCU including all the relevant maps that would need to be modified based on hardware changes live on the fly. 3 are in Europe, 1 is in NJ USA, and they are guarded like gold.
Unless Weistec has one of those, well, I just don't see good things happening.
#223
Check out the valve guides, mowed down to the roofs of the ports, that means those valves when going up and down at 11,000rpm are going to be beating those beautiful seats to death. Mowing the guides down eliminates all stability in the valve.
Also speaking of the seats, where's the blend on the VJ? Head looks like it came right out of a valve cutter.
Rods are overkill, you want components to be light to live at those rpm. Ken Duckworth (one of the founding partners of Cosworth) was once quoted as saying "if after a race a motor is torn down and a part is found to be in one piece, it is immediately redesigned and made lighter." LOL. Love that one.
Anyway, yes it proves the point that anything is possible with hardware. Again though beating the encryption on the TCU software, not going to happen.
#225
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Do you think the trans of an SL63 is a different kettle of fish in terms of accomodating supercharger, or is it even more delicate?
