C63 AMG (W204) 2008 - 2015
new cf interior :)
Old Feb 2, 2011 | 01:09 AM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
did you use a blade or a scalpel tool?
Old Feb 2, 2011 | 01:16 AM
skokkosis's Avatar
2014 E63-S, 1987 190E 2.3-16, 1985 325E
btw sincity waterfall is what many out here call the area that flows throughout your temperate controls and radio.. "waterfall" idk.. many people i've heard refer that area in the term, but the shifter, ash tray, and temp. controls is what i meant
sb.legacy thank you
Old Feb 2, 2011 | 01:20 AM
efx1's Avatar
C350
i got mine done by mike_benz 300 for $200.
He actually drove to my house and did it.
Old Feb 2, 2011 | 01:21 AM
skokkosis's Avatar
spec_davis.. when i make the diy i'll show you the tool, but i got it ina tinting kit from home depot since i need a new "card" the tool to push out the bubbles and it came w. this little handle thing that had a blade barely sticking out.. helped a lot so you arent working with a big blade when u are slicing through the areas u need to cut (prevents you cutting through and then when the blade falls through nipping on your leather or the wood)
did not use the spray bottle or that rag (you are not meant to wet this vinyl unlike traditional types) you simply tack down and push bubbles out.. card helped me not for the bubbles, but for pushing in the vinyl between the leather and wood to make the full wrap w.o removing the door + it helps run along the chrome trim under the wood to make a clean edge along both (when i make the diy ill show how)
as for the blade i use the one in the picture, in green.. it comes out barely a mm
