The correct camber bolt for a C63
I was at the dealer today getting some camber bolts. I told them to get me part # 000-333-09-71 and double check if this would work for a C63. However, base on their system, the correct bolt part is now 000-333-10-71. Does anyone know the difference?
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Mercedes has 2 sets of bolts for the C63, probably why. You can reduce a fixed amount of camber, good if you have an aftermarket suspension... I had to install some with my KW V3.
Correct part number is 000-333-09-71.
1 Post
The later bolt I mentionned gives about 0.5 of positive camber compared to stock (2 bolts needed per front wheel). There is no adjustment, just a fixed amount added.
I just installed H & R coilovers and dealer installed 2 x MBA0003331071.
I was the first car they have wheel aligned with lowered suspension and I don't think they really know what to do as it still has a lot of negative camber front and rear.
1 Post
For the install you need to go to alignment expert. There are a couple of things to play with, including the alignement with the strut tower... I got -0.7 camber in the end, pretty good.
Base on my conversation with one of the dealer, the new parts allow for more flexible camber (meaning you could correct more than 0.5), and I was told you only need 2 more the front axle like AMG-10.
Final reading of mine was
Camber Left -1 49'
Right -1 38'
Cross Camber -0 10'
Still searching for a wheel alignment specialist here in Australia.
I noticed on the invoice they only used 2 camber bolts in total
Camber Left -1 49'
Right -1 38'
Cross Camber -0 10'
