CHEAP WEIGHT SAVINGS!!!!
Yup. So...
Battery 45lb saved.
Spare Tire about 40lb saved.
Headrests 4.5lb saved.
CF hood and trunk: 75lb's saved
Passenger Seat: 50lbs???
Lug nuts: (Please fill in if you know)
Skinnys: (please fill in if you know)
Smaller Rim size: (Please fill in if you know)
All adds up quite fast..
Yup. So...
Battery 45lb saved.
Battery 45lb saved.
It does add up.
Seats are 63lbs
Lug nuts I don't think u can save on those unless u don't use any..
Skinnies the best we could figure out is albs per side
Depends on the rim itself and the tire explain more maybe I can help!
Yup. So...
Battery 45lb saved.
Battery 45lb saved.
#33
If you guys are doing that, you might as well just pull up the rear seat cushions. I'm sure they'll be another 20 pounds. They pull right up and snap right back in when done.
#34
#35
#36
I thought I read somewhere the Titanium ones saved 1lb per tire. That might have been for the whole setup though... they are cool though.
I just mean using a smaller rim like a 17 or 16.
63 nice...
Battery 45lb saved.
Passenger Seat: 63lbs
Rotors: 40lb's saved.
Rear seat cushions: 10lb's probably at most. Still good.
202lb's with the rotors...
Let Jon drive:
270lb's of weight savings...
#37
63 nice...
Battery 45lb saved.
Let Jon drive:
63 nice...
Battery 45lb saved.
Let Jon drive:
#38
63 nice...
Battery 45lb saved.
Let Jon drive:
63 nice...
Battery 45lb saved.
Let Jon drive:
#39
Depends on the wheel if you get 17" say volks u prob save 7lbs per wheel and tires also vary in weight but not much maybe 2-5lbs
63 nice...
Battery 45lb saved.
Let Jon drive:
63 nice...
Battery 45lb saved.
Let Jon drive:
#44
#45
But, I will have the hood and eventually the battery, plus all the other free weight reduction mods.
Total diet should yield 230+ lbs reduction.
#49
#50
