C63 AMG (W204) 2008 - 2015
CHEAP WEIGHT SAVINGS!!!!
Old 02-09-2011, 12:23 PM
Former Vendor of MBWorld
Staff@RPM's Avatar
LIGHTWEIGHT BATTERY
We are putting together an order for some Braille lightweight battery's right now. We put one of these in Dodgers car the end of last year and we saved over 45lbs. by just doing this. You will not find an easier, cheaper and less invasive way to shave off that kind of weight. If your car was going 11.2 in the quarter you can change the battery and you should go 11.15 (equals about a half a car length in the 1/4) after you install this lightweight unit. Is there a cheaper and easier way to shave 1/2 a tenth of your time?
The Braille battery that we use easily fits in the car, the positive and negative terminals are in the correct locations and you don't need to modify anything with the factory parts to make it work. It is easily installed with basic tools and we can offer it with a mount kit if you like and we can also offer you a nice little trickle charger to keep your battery happy and ready to go during downtime.
Braille Mercedes lightweight battery - $168.00 on sale for $159.00
Billet aluminum mount kit - 98.00
2 amp trickle charger - $88.00
10 amp rapid charger - $129.00
We have this unit in Dodgers car with the mount kit at all, it was a very simple solution to secure the battery without any special mounts. If you are going to the Maryland race on February 18th I can bring the battery and anything else you need with me.
If you have any questions or you just want to place an order, please feel free to PM me or give me a call.
-Craig
Old 02-09-2011, 12:29 PM
Super Moderator Alumni
superlubricity's Avatar
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
What is the Model # of the battery?
Old 02-09-2011, 02:13 PM
SonnyakaPig's Avatar
MB
I've been meaning to get one of these. It's such a no-brainer weight savings mod, and yet I keep forgetting to get one.
RPM, the battery mounts fine in the car without your billet mount, or is the billet mount necessary for proper fitment.
Thank you for this thread.
Old 02-09-2011, 02:21 PM
PetroC63's Avatar
2012 CTS-V
Wow! 45lbs is a huge savings.
I'm assuming this battery is not recommended for a daily driver?
How easy is it to swap in and out for track days?
dodger63's Avatar
2013 f250 6.7 diesel
I have mine just sitting in there it's like the perfect size were the terminal wires hold it tight.. I am going to get the bracket though it makes a nice finished look and adds nothing to the weight maybe a pound and u need it for a tech inspection anyway
Old 02-09-2011, 02:23 PM
dodger63's Avatar
I've had it in my car for about 6 months leaving it in the garage for a week or more at a time with no problems even with this bitter cold winter
Old 02-09-2011, 02:25 PM
MB
Have you needed to use the trickle or rapid charger? I remember you said not to run electronics with the car off for very long.
Old 02-09-2011, 02:28 PM
Staff@RPM's Avatar
HUGE!!! Especially for such a simple mod. I would not recommend it for a daily driver because it just does have the reserve needed if you leave a light on or something like that. It is extremely easy to swap out, the same basic tools that you need if you were to just change your stock battery.
The billet mount or some type of similar mount is needed to really securely fit the battery. We made a basic mount to hold Mikes in the car but I don't think he even uses that now. It doesn't require you to change battery cables or anything like that, it's a very simple and easy install.
I think I will work on a mount specifically for the Benz in a couple of weeks, the key for me making it will be to keep the weight of the mount to a minimum.
Now's your chance to not keep forgetting about ordering one. Just give me your info. and I will get one ordered and to you.
Thanks-
Old 02-09-2011, 02:29 PM
RPM?
Old 02-09-2011, 02:30 PM
Staff@RPM's Avatar
If you are going to let it site for a long period I would get the trickle charger. The battery has a sitting shelf life of 6 months until it needs a charge.
Old 02-09-2011, 02:31 PM
dodger63's Avatar
I did charge 2 times at rpm while it was sitting there reason being I was working on it and left the trunk open on 2 separate occasions my mistake but other then that I haven't had a problem
Old 02-09-2011, 02:34 PM
MB
Makes sense. Sounds really good.
Old 02-09-2011, 02:35 PM
MB
Thanks.
My car's a DD, but I still want the weight savings.
PM sent, btw.
Old 02-09-2011, 03:02 PM
dodger63's Avatar
You can swap out the batteries in about 3 min might hurt your back though..
Old 02-09-2011, 03:16 PM
mthis's Avatar
Anything W/4Wheels
After seeing the results 1st hand I want 1 Craig.
I'll be there to pick mine up soon tnx.
Old 02-09-2011, 03:43 PM
Even Money's Avatar
'15 VW GTI
Model #? Thanks!
Old 02-09-2011, 04:12 PM
mthis's Avatar
Anything W/4Wheels
Originally Posted by Even Money
Model #? Thanks!
I saw couple ppl asking for this. If u don't mind me asking why do u need model number?
Old 02-09-2011, 04:30 PM
Even Money's Avatar
'15 VW GTI
There are so many options on their website, I was just curious of the tech specs..I could probably figure out based on the price, but I would like to use as my daily driver, so concerned about the amp/hr rating, CCA, etc..
Old 02-09-2011, 04:39 PM
Staff@RPM's Avatar
I will be honest with you. If you are going to use any of these as a battery for your daily driver be prepared to jump your car at some point (probably at an inconvenient time) because the reserve capacity is low on these battery's. It will easily start the car, easily run all the electronics but leave your interior light on by accident, your toast.
Old 02-09-2011, 04:40 PM
mthis's Avatar
Anything W/4Wheels
Kk. When I get mine I'll post it up Btw I dont think it's a good idea to run this battery for DD unless you do alot of street racing then you should get the lithium ones they like 4-5 lbs but 1500 smackaronies.
Old 02-09-2011, 04:54 PM
Even Money's Avatar
'15 VW GTI
^ Makes sense..I'll probably get one for the strip..I'm not ready to spend the 2K on the lithium versions...
Old 02-09-2011, 05:00 PM
dodger63's Avatar
Lithium is not necc. This battery is great weighs 45lbs less starts it in 0 degree weather perfect., drop the extra 1200 on a carbon hood it'll look better and save more weigh the the difference.. There are many other good ways to spend that 1200 then the battery. You could almost have evo rotors or forgestar wheels!!
Old 02-09-2011, 05:07 PM
GHAZAN's Avatar
MBUSA
http://www.braillebattery.com/index....teries/b2015/#
im guessing its that one...now which bracket?
B2015 - 15lb, same price,
Old 02-09-2011, 05:28 PM
propain's Avatar
See Sig
Great weight savings for track days or a day at the autobahn. This and the spare removal can save you about 100lb's. Thats huge.
Old 02-09-2011, 05:30 PM
Close but not quite 100.
Spare tire, Jack, Styrofoam Pad and First Aid Kit = 39.50 lbs.
Rear Headrests (All 3 Combined) = 4.51 lbs.
Quick Reply: CHEAP WEIGHT SAVINGS!!!!
