C63 AMG (W204) 2008 - 2015
The C63 OEM & Aftermarket Parts Weight Thread!
Old 01-16-2013, 08:47 AM
  #51
mvp2765's Avatar
C
Great thread. Seems like the Braille battery, cf Hood and removal of the spare give the
Largest weight saving without too much hassel.. I too would go lighter wheels and 2pc rotors
Old 01-16-2013, 11:18 AM
  #52
Capn's Avatar
03' CL600
Originally Posted by superlubricity
Interior Parts:
  • OEM Passenger Seat = 63.00 lbs
  • OEM Spare Tire, Jack, Styrofoam Pad and First Aid Kit = 39.50 lbs
  • OEM Rear Headrests (All 3 Combined) = 4.51 lbs
  • OEM Floor Mats (Set of 4) = 6.00 lbs
  • OEM Battery = 60.00 lbs
  • Braille B2015 Battery = 15.00 lbs
  • Technocraft C/F Racing Seat & Bracket = 17.79 lbs
How about the rear bench seat? Probably not much of a weight savings there.
Old 02-27-2013, 05:29 PM
  #53
mthis's Avatar
Anything W/4Wheels
Rear bottom seat is only 8-9lbs
The top part is heavy.
Old 03-06-2013, 10:13 AM
  #54
bluejae's Avatar
'10 C63
OEM Exhaust Manifold (Drivers) = 7.16 lbs
OEM Exhaust Manifold (Passenger) = 7.32 lbs
is this from the tips to the resonator?
Old 03-18-2013, 10:08 PM
  #55
Blown63's Avatar
2015 CLS63 S-AMG
Does any one know how to remove our seats? Is it easy? I am thinking I would remove my passenger seat on drag days. Thanks for helps guys!
Old 03-29-2013, 02:23 PM
  #56
bluejae's Avatar
'10 C63
ignore my post above... i just looked at what i copied and pasted when i posted the question and i was mistaken... i was looking for the weight of the oem mufflers NOT manifolds...
Old 04-15-2013, 11:46 PM
  #57
jianglan's Avatar
dabdgbng
I need to drive a ZL1. Only seen a few in person.
Old 04-16-2013, 04:52 AM
  #58
Flori56nda's Avatar
s4
I'll expand the categories once we get more data pooled.
Old 11-28-2013, 02:32 PM
  #59
Footbrawler80's Avatar
2009 Mercedes Benz C63 AMG PP (Weistec S3 Supercharged)
This is an awesome thread, great work. Thanks for the info!
Old 12-01-2013, 10:21 PM
  #60
m5trol's Avatar
C63 AMG Edition 507
What is the stock weight for sedan and coupe?
I was looking at the weight specs from mbusa.com and it claims weight of 3600 lbs for the sedan (3800 for coupe). This sort of flies in the face of seemingly established wisdom that the cars are about 4000lbs. What am I missing? Here is the link by the way: http://www.mbusa.com/mercedes/vehicl...nt=model-specs
Has anyone actually measured the cars on the scales? Coupe or sedan?
Old 12-03-2013, 03:53 PM
  #61
C63Analyst's Avatar
2009 C63
I am assuming that is the "dry" weight, once you add a full tank of fuel, all the fluids, and a driver, you are getting up to 4,000 lbs for even the sedan.
What baffles me is that the sedan weighs less than the coupe. I would assume 2 less doors and a shorter wheelbase would mean less weight?
Old 12-05-2013, 02:12 PM
  #62
MaxRosen's Avatar
c230 & c63
This thread is for tracking the various weights of OEM and aftermarket parts for the C63. I'll continue to update this post as new parts are weighed.
Interior Parts:
Exterior Parts:
  • OEM Steel Hood ('08-'11) = 53.00 lbs
  • Dad's C/F Vented Hood ('08-'11) = 21.00 lbs
Engine Parts:
  • OEM Crank Pulley = 6.30 lbs
  • evosport Crank Pulley = 4.30 lbs
Exhaust Parts:
  • OEM Exhaust System (Exhaust Manifolds, Primary/Secondary Cats & Mids) = 59.37 lbs
    • OEM Exhaust Manifold (Drivers) = 7.16 lbs
    • OEM Exhaust Manifold (Passenger) = 7.32 lbs
    • OEM Down-pipe & Cat (Drivers, Cut for GT Pro X-Pipe) = 11.76 lbs
    • OEM Down-pipe & Cat (Passenger) = 13.46 lbs
    • OEM Secondary Cats (Cut for GT Pro X-Pipe) = 19.28 lbs
  • MHP Long-tube Headers & Catless Mid-Pipes = 48.11 lbs
    • Header (Drivers) = 15.68 lbs
    • Header (Passenger) = 15.65 lbs
    • Catless Mid-pipes = 13.50 lbs
    • O2 Extension Harnesses = 0.24 lbs
    • Clamps (Six) = 3.04 lbs
  • OEM Heat Shields = 0.85 lbs
  • OEM Cross Bar & Bolts = 2.12 lbs
  • GT Pro Secondary Cat Delete X-Pipe = 8.50 lbs
  • MBH Secondary Cat Delete X-Pipe = 8.60 lbs
Suspension/Driveline Parts:
  • Front OEM Brake Rotor (1-pc, Non PP) = 35.56 lbs
  • Front OEM Brake Rotor (2-pc, P30) = 29.58 lbs
  • Front evosport Brake Rotor (2-pc) = 23.33 lbs
Wheels:
  • Front Forgestar F14, 1200-lb rating (18x8.5 ET46) w/ TPMS = 18.08 lbs
  • Front HRE M40 (19x8.5 ET35) w/o TPMS = 24.00 lbs
  • Rear OEM Wheel (18x9 ET54) w/ TPMS = 25.79 lbs
  • Rear Forgestar F14, 1200-lb rating (18x9.5 ET55) w/ TPMS = 20.51 lbs
  • Rear Forgestar F14, 1520-lb rating (18x9.5 ET54) = 20.79 lbs
  • Rear HRE M40 (19x9 ET45) w/o TPMS = 26.00 lbs
Tires:
  • Front Nitto NT05 (245/40-18) = 25.09 lbs
  • Front Toyo R888 (245/40-18) = 26.80 lbs
  • Rear OEM Pirelli P Zero (255/35-18) w/ 5,000 miles of use = 22.36 lbs
  • Rear Nitto NT05 (275/35-18) = 27.38 lbs
  • Rear Toyo R888 (275/35-18) = 27.40 lbs
  • Rear Nitto NT555R (285/35-18) w/ about fifty 1/4 mile passes = 24.90 lbs
Wheel & Tire Combos:
  • Front OEM (18x8 ET45) & OEM Pirelli P Zero (235/40-18) w/ TPMS and 5,000 miles of use = 49.75 lbs
  • Front Forgestar F14, 1200-lb rating (18x8.5 ET46) & Nitto NT05 (245/40-18) w/ TPMS and 25 miles of use = 41.52 lbs
  • Rear OEM (18x9 ET54) & Nitto NT555R (285/35-18) w/ TPMS and 400 miles of use = 51.77 lbs
  • Rear Forgestar F14, 1200-lb rating (18x9.5 ET55) & Nitto NT05 (275/35-18) w/ TPMS and 25 miles of use = 48.27 lbs
  • Rear Forgestar F14, 1520-lb rating (18x9.5 ET54) & Michelin PS2 (275/35-18) w/ TPMS and 0 miles of use = 48.04 lbs
Thanks to all that have already contributed and keep it coming!
where can I find the weight of the stock parts, just so I can compare?
thanks
Old 12-08-2013, 04:36 PM
  #63
Rebellious_AMG's Avatar
CLK63BS, 2014 G63
thanks
The parts listed "OEM" are the stock parts.
Old 01-04-2014, 03:08 PM
  #64
fsmtnbiker's Avatar
09 C63
2009 C63
5/8 tank of fuel
Spare Tire, Jack, Tools removed
Old 03-01-2014, 08:07 AM
  #65
AMG893's Avatar
2010 C63 Estate
Factory HK Subwoofer from 2010 Estate- 6lbs/ 2.72 Kgs
Old 03-01-2014, 08:15 AM
  #66
AMG893's Avatar
2010 C63 Estate
Factory Space Saver Spare wheel (Rim & Tyre) from Estate 2010 (should be same as Sedan)- 30lbs
Factory Jack/ Tools/ Gloves (the things found in that plastic circle thing inside the space saver spare) Including the black plastic round thing- 10lbs
In estate cars, when you lift the rear floor up to access the spare tyres, there is a grey foam holder there, which holds a collapsible storage crate, and the warning triangle.
This altogether with the crate & triangle, weighs- 6lbs
Old 07-30-2014, 01:57 AM
  #67
freefall's Avatar
2012 C63 Purpose built race car, 2015 CLS 63 S, 2016 GLA45, 2017 GTS
Pano roof weight
Pano roof weight....
Old 11-02-2014, 10:42 PM
  #68
AMG893's Avatar
2010 C63 Estate
PAIR OEM Mufflers & tips including about 50cm of piping on each
27.5KG (60.4lbs)
PAIR OEM Headers
6.4KG (14.1lbs)
PAIR Factory primary cats including about 1metre of piping.
11.2Kg (24.6lbs)
Old 03-02-2015, 02:18 AM
  #69
C63TSgt's Avatar
2009 C63
17x8 ET45 TSW Nurburgring rears for drag racing = 18.2lbs no valve stem
[URL=http://s182.photobucket.com/user/01blueandwhite/media/Mobile%20Uploads/20150301_230606.jpg.html]The C63 OEM & Aftermarket Parts Weight Thread!-20150301_230606.jpg
Old 03-02-2015, 04:25 PM
  #70
C63TSgt's Avatar
2009 C63
Hoosier DOT in 275/40/17
22.6lbs
The C63 OEM & Aftermarket Parts Weight Thread!-20150302_130842.jpg[/URL]
Old 04-22-2015, 10:30 PM
  #71
Tinbucket's Avatar
C63
i don't know the structure on our C63s.
On a previous car, in the eighties-nities, drag racers were removing the heavy steel bumper behind the plastic facias at each end or substituting aluminum and later a hard foam. I don't remember specifics
A car this small weighing near four thousand pounds with an aluminum motor and trans light flywheel and drive shaft seems high compared to my 69 Mustang which was larger I believe.
I would not remove the steel beams, if it they're, there ever for normal driving. If a titanium one was in budget and available maybe.
With carbon ceramic rotors and carbon fiber hood, and me losing a hundred pounds or letting wife race it, there would be a two hundred fifty pound savings.
Sixty four pounds, carbon ceramic rotors and guesstimate 80 lbs for hood. That would be 3840 lbs minus 144 lbs or 3696 lbs weight empty.
I don't like real light wheels on higher hp cars. Ruin your day if one breaks or bends.
djr48312 (02-15-2021)
Old 04-23-2015, 01:31 AM
  #72
bhamg's Avatar
C63 AMG
Forgestar 19x10 CF5V rear wheel (no TPMS or hubcentric ring installed) - 21.0 lbs
Old 06-28-2015, 05:44 PM
  #73
c63er's Avatar
09 C63 AMG
It kind of sucks that the real heavy items and potential for weight savings are in the rear of the car (battery, spare tire, trunk, rear mufflers, etc). This would only affect the traction and handling of the car negatively as it is already hard to get any traction in low gears and the weight distribution is already front-biased to begin with. Weight savings are good if you are building a drag strip car but if you actually want improved handling sometimes less weight makes things worse. There is a reason why people who are serious about getting the best out of their car actually put ballasts in some corners or sides of the car. Just a note. Don't get too obsessed with shaving the most weight off your car. Sometimes it's not a good thing.
djr48312 (02-20-2021)
Old 11-24-2015, 05:34 PM
  #74
asoria2016's Avatar
2008 c63 AMG
W204 air intake
What do you guys think of this air intake seller claims it can give 20 hp is it recommended??
Old 11-26-2015, 05:55 PM
  #75
GRP
GRP's Avatar
2010 C63
Looks like a great way to suck in the hottest possible air - perhaps they meant lose 20HP.
