The C63 OEM & Aftermarket Parts Weight Thread!
Interior Parts:
- OEM Passenger Seat = 63.00 lbs
- OEM Spare Tire, Jack, Styrofoam Pad and First Aid Kit = 39.50 lbs
- OEM Rear Headrests (All 3 Combined) = 4.51 lbs
- OEM Floor Mats (Set of 4) = 6.00 lbs
- OEM Battery = 60.00 lbs
- Braille B2015 Battery = 15.00 lbs
- Technocraft C/F Racing Seat & Bracket = 17.79 lbs
- OEM Steel Hood ('08-'11) = 53.00 lbs
- Dad's C/F Vented Hood ('08-'11) = 21.00 lbs
- OEM Crank Pulley = 6.30 lbs
- evosport Crank Pulley = 4.30 lbs
- OEM Exhaust System (Exhaust Manifolds, Primary/Secondary Cats & Mids) = 59.37 lbs
- OEM Exhaust Manifold (Drivers) = 7.16 lbs
- OEM Exhaust Manifold (Passenger) = 7.32 lbs
- OEM Down-pipe & Cat (Drivers, Cut for GT Pro X-Pipe) = 11.76 lbs
- OEM Down-pipe & Cat (Passenger) = 13.46 lbs
- OEM Secondary Cats (Cut for GT Pro X-Pipe) = 19.28 lbs
- MHP Long-tube Headers & Catless Mid-Pipes = 48.11 lbs
- Header (Drivers) = 15.68 lbs
- Header (Passenger) = 15.65 lbs
- Catless Mid-pipes = 13.50 lbs
- O2 Extension Harnesses = 0.24 lbs
- Clamps (Six) = 3.04 lbs
- OEM Heat Shields = 0.85 lbs
- OEM Cross Bar & Bolts = 2.12 lbs
- GT Pro Secondary Cat Delete X-Pipe = 8.50 lbs
- MBH Secondary Cat Delete X-Pipe = 8.60 lbs
- Front OEM Brake Rotor (1-pc, Non PP) = 35.56 lbs
- Front OEM Brake Rotor (2-pc, P30) = 29.58 lbs
- Front evosport Brake Rotor (2-pc) = 23.33 lbs
- Front Forgestar F14, 1200-lb rating (18x8.5 ET46) w/ TPMS = 18.08 lbs
- Front HRE M40 (19x8.5 ET35) w/o TPMS = 24.00 lbs
- Rear OEM Wheel (18x9 ET54) w/ TPMS = 25.79 lbs
- Rear Forgestar F14, 1200-lb rating (18x9.5 ET55) w/ TPMS = 20.51 lbs
- Rear Forgestar F14, 1520-lb rating (18x9.5 ET54) = 20.79 lbs
- Rear HRE M40 (19x9 ET45) w/o TPMS = 26.00 lbs
- Front Nitto NT05 (245/40-18) = 25.09 lbs
- Front Toyo R888 (245/40-18) = 26.80 lbs
- Rear OEM Pirelli P Zero (255/35-18) w/ 5,000 miles of use = 22.36 lbs
- Rear Nitto NT05 (275/35-18) = 27.38 lbs
- Rear Toyo R888 (275/35-18) = 27.40 lbs
- Rear Nitto NT555R (285/35-18) w/ about fifty 1/4 mile passes = 24.90 lbs
- Front OEM (18x8 ET45) & OEM Pirelli P Zero (235/40-18) w/ TPMS and 5,000 miles of use = 49.75 lbs
- Front Forgestar F14, 1200-lb rating (18x8.5 ET46) & Nitto NT05 (245/40-18) w/ TPMS and 25 miles of use = 41.52 lbs
- Rear OEM (18x9 ET54) & Nitto NT555R (285/35-18) w/ TPMS and 400 miles of use = 51.77 lbs
- Rear Forgestar F14, 1200-lb rating (18x9.5 ET55) & Nitto NT05 (275/35-18) w/ TPMS and 25 miles of use = 48.27 lbs
- Rear Forgestar F14, 1520-lb rating (18x9.5 ET54) & Michelin PS2 (275/35-18) w/ TPMS and 0 miles of use = 48.04 lbs
Wheel companies often weigh their wheels "bare" to show the lowest possible weight. I know the TPMS, hub-centering ring and center cap for each of my Forgestar Wheels weighed 0.175 lbs. combined. That's more than a 1/2 a pound for all 4 wheels (0.7 lbs to be exact). Every little bit counts. Look at all the guys that run titanium bolts on their 3-piece wheels.
- OEM Exhaust System (Manifolds, Primary Cats & Mids) = 59.37 lbs
- OEM Manifold (Drivers) = 7.16 lbs
- OEM Manifold (Passenger) = 7.32 lbs
Again, I apologize if this is not strictly a OEM vs aftermarket but I know for sure that a lot of people would like to remove the floormats for weight savings.
