The C63 OEM & Aftermarket Parts Weight Thread!
#77
As most have talked about, the big gains are on the exhaust side of the vehicle. Not the intake side, unless you are doing forced induction. Most people just go with a set of ROW airbox covers & a set of performance air filters. Give you maybe 5hp. Costs about $300. If you don't have the PP, then a tune should grab you about 50hp, headers tuned would get you another 50hp.
djr48312 (02-28-2021)
#81
2012 C63 Coupe AMG Edition 1
Got the weights for Mikes Pipes. This is for the straight pipes (no cross over) to replace the secondary cats
The OEM cats with attached pipes: 18.2 lbs.
Mikes pipes: 9.6 lbs
#84
This is good chit main, grade-A good chit.
#85
Is there a noticeable difference in performance and handling in swapping to a light weight 2pc rotors and light weight aftermarket wheels and tires?
#86
Received 2,828 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
#87
This Braille B2015 Battery thats 15 lbs can be used in a daily driver? It's not going to have longevity issues compared to stock?
#88
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/1125x1405/9fe5c1cd_1821_4599_84b9_732c16ab9e99_4547453f60dc57c3558b155393e5814fb9cacddc.jpeg)
Probably useless but it’s 20+ grams saved.
#90
Does anyone know the exact weight of the standard 19” OEM C63 Wheels?
I can only find one person that posted weights but they were with tyres.
