KW V3's or Clubsports
http://www.kw-suspensions.eu/int/kw_productrange.php
Price difference is about 25% more for the Clubsports. But that's not my concern really. I am worried about harshness. I mean, I can handle harsh but I don't want to get angry with my choice later.
Based on my previous posted videos, I guess you guys know what kind of driving I love/do.
So anyone with V3's wish it was a bit more agressive?
Anyone with Clubsports wish it was a bit softer?
I'd love to hear everyones opinions. Thanks
thanks
I think you can lower it quite a bit, like 30mm-40mm or something.
It seems as if that's what people are saying about the Clubsports. I wonder though how much improved performance I would get on the road over V3's. I am sure I could also dial in softer settings on the Clubsports for daily driving?
For v3 I never tried it so dont know how it handles.
One bad part is that when you do set up for C63 for rear you have to take off the whole suspension to able to do set up so you cant do quick set up at the track. I dont know if its out for C63 but for new clubsport it will have dial like Blistein has so it will be much easy for you to do set up. Since it will have number on the dial you will know exactly what set up you are in. Hope that it will come out for C63 like this.
For newer car clubsport will make huge changes.
1. With dial to easy set ups.
2. Suspention will be the same as Competition.
I do track mine, although its been so hot here I havent gone. Goes goes into limp mode to often.
Is this a common problem with our C63s? I can't even complete a few rounds without hitting limp mode.
my car went into limp mode each session about laps in at Buttonwillow, would do a cool down lap then get in 2 laps and it would happen again.
at Willow Springs Big Track it never happened once, was near the same temp outside but its a a wide open track with lots of cooling
Also, keep in mind that the warranty on the V3's is better due to the fact that the CS are considered a "Motorsport Product". I believe the Clubsports also need to be re-valved on a regular yearly basis.
I had KW's for my old C55 and they were great.
Seeing that I never track my C63 and I just wanted a nice stance and softer ride ( P30 ) I went with HR and I can tell you that the service and support for the coil over are great.
Is dampening the only thing remotely adjusted, or height can also be controlled?
