C63 AMG (W204) 2008 - 2015
Is stock P31 actually 500+hp?
Old Apr 5, 2011 | 07:51 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Bottomline the C63 is a pig! Not a big car but why so heavy?
Old Apr 5, 2011 | 08:12 PM
propain's Avatar
See Sig
Originally Posted by Mort
I just checked out the C63 Curb Weight in several places.
MBUSA AMG site: Curb Weight = 3924 lbs.
Canadian 2010 C-Class brochure = 3916 lbs.
GVWR on B pillar of my car = 4862 lbs. (2210 kG) Less Max Load 847 lbs (385 kG) = 4015 lbs.
I am not sure where MB says the curb weight is 36xx lbs. but that is not what the above sources indicate. Perhaps that is the dry weight of the car without fluids.
http://www.mbusa.com/mercedes/vehicl...-C63/year-2011
Check the dimensions tab. 3649.
Lets see...
17 gallons gas = 136
Oil 17.5lbs
Coolant? No clue... 24lbs?
3826, not including diff and break and tranny fluid..
Yeah I guess 39XX without driver. They are just listing without any fluids... now I know.
Old Apr 5, 2011 | 10:58 PM
Hans Delbruck's Avatar
What I like!
My stock 2008 C63 on the scales, with a completely FULL GAS TANK = 4000 lbs
Old Apr 5, 2011 | 11:07 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
I'm guessing that's why it's 2 tons. Makes sense. My Red Queen is a fat *****, but I still love her.
Old Apr 5, 2011 | 11:11 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Sans driver? Pretty good fore/aft distribution, and excellent corner weighting.
Invested many an hour in a C32 to get anywhere close to those figures...with my 220-pound carcass aboard.
Old Apr 5, 2011 | 11:48 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
c32amg-dtm is correct, he showed the proper way to calculate it.
If you look at it from Mercedes perspective, Its much easier for them to probably just use an existing tune they have so It wouldn't be shocking if they just slapped a black series tune one the car because they probably knew aftermarket companies would figure it out soon enough. In doing so, they could retain some of the potential revenue that would have otherwise just gone to aftermarket tuners. its probably somewhere 500+.
For the record, Dyno dynamics is almost always 22% drivetrain loss on 2WD Benz AMGs (auto). Every AMG I have dynoed stock on DD has come back within 0.1% of 22% drivetrain loss so its pretty damn accurate/consistent. Dynojets are all over the place so its harder to tell but 18-19% is probably around the right number.
Old Apr 5, 2011 | 11:50 PM
  #32
AMG
Benz sandbagged the car in order to prevent it from competing with the higher end AMGs. They just added ton of weight, and pulled out lots of tuning and voila.
annoying ... yet effective way of detuning a car.
Old Apr 6, 2011 | 12:21 AM
  #33
What I like!
Yep! Sans driver. Just car + all fluids + one CD in the changer
Old Apr 6, 2011 | 12:36 AM
  #34
Dark_Knight's Avatar
GT2 C63 and yo sister
the weight makes it feel solid, liked carved from a block of steel
Old Apr 6, 2011 | 11:08 AM
  #35
rage2's Avatar
C63 BS, GLA45
Originally Posted by Chocofishez
Been seeing a lot of threads regarding tunes and wicked times at the dragstrip.
A couple people have commented that the P31 actually has more than the advertised 481 hp... that it's closer to the #s on the E63 or S63.
Is this true? Any way to know for sure? I'd love to tell my M3 driving buddy that I have 100hp more than him.
I've run with 2 different P31 cars, and they're dead even with mine from 100-200ish. I've got the ECU as my only mod on my P30.
So either the P31's are pushing 500hp from the factory, or the ecu tunes only put out 481hp. Either way, they're equal.
I'd be more than happy to go for a run with ya since we're in the same city. Bring your M3 buddy out too.
Old Apr 6, 2011 | 11:31 AM
  #36
propain's Avatar
See Sig
Not equal until you run the 1/4. The P31 might be able to keep up up top but the 1/4 will give more details.
Old Apr 6, 2011 | 01:08 PM
  #37
khmergod's Avatar
More like Adamantium.
Old Apr 6, 2011 | 02:25 PM
  #38
Chocofishez's Avatar
2014 E63 S
once i get my summers on we should definitely get together. My M3 friend is a bit of a puss so I doubt he'll come out.
