C63 AMG (W204) 2008 - 2015
Is this normal?
Old May 12, 2011 | 12:27 AM
vmx128's Avatar
2011 C63 P31
Is this normal?
I got service A done recently, and ever since, (I think) I am noticing a slight high frequency vibration from the engine area (during idle) even after the car is warmed up and operating at 200+ F oil temp. I can feel the vibration it in the cabin through the steering wheel and the gas pedal. The vibration almost feels like something is buzzing/grinding somewhere in the drivetrain. There also seems to be a very faint noise at the same frequency that is usually drowned by the loud engine.
I can only feel this virbration during idle. I can also feel a vibration with the same frequency by touching the area under the front fender. Also, when the engine is idling, it is not rock solid stable. It seems to vibrate slightly.
Since I am very very sensitive to these things, I am wondering if this is really something new or my mind has just latched onto it and I can't stop noticing it. I already checked the oil level and it is not been overfilled.
This is driving me crazy , and since I am embarking on a 800 mile round trip to AZ on Friday, I want to make sure there is nothing wrong with the drivetrain. Maybe I am going crazy!
Any suggestions/feedback on this matter would be appreciated! Should I stop by the dealer to have it checked? I emailed the SA and he was somewhat dismissive and said everything is ok unless some warning light comes on.
The car currently has 3900 miles on it.
Old May 12, 2011 | 12:35 AM
exdes's Avatar
2015 C300 4matic
check engine oil level..
Old May 12, 2011 | 12:37 AM
vmx128's Avatar
2011 C63 P31
I did. This is what the dipstick looks like. One difference from before the service is that the dealer replaced the oil with 5w-40. I assume the car ships with 0w-40.
Old May 12, 2011 | 12:47 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
For your sanity, have it checked out.
Old May 12, 2011 | 12:51 AM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
It is not normal. I think your experiencing with the same problem that I had. I'm %50 sure this is a an idle valve propblem (which the computer wont read until your engine wont start). does your RPM tend to be lowered when this is happening?
Some dealers are not wise enough to identify this.
Old May 12, 2011 | 12:54 AM
vmx128's Avatar
2011 C63 P31
Thanks for the input. The RPM seems to be pretty low when this happens. I think it hovers between 500-600rpm. Can you tell me a bit more about this problem, how serious it is and how you got it fixed? Thanks!
Old May 12, 2011 | 01:49 AM
AMGFTW's Avatar
C63 AMG
They put too much oil into the car. Too much oil will definitely cause the vibrations you are talking about. Take it back to them and have them fix it asap.
Also 5w-40 is fine. AMG changed their recommendation for oil from 0w-40 to 0w-40 or 5w-40. Both of my local dealers only carry 5w-40 now. I have been running it in my car with no issues.
Old May 12, 2011 | 02:01 AM
GHAZAN's Avatar
MBUSA
He posted a pic of his dipstick and said its not overfilled, so why still suggest it. Sounds weird but it could be anything without any more descriptions or codes thrown it's hard to say...
BTW idle RPM at 600 is normal after the initial warm-up above 1k it drops to around 5-600 unless it's really move or bouncing, but it doesn't sound like it
Old May 12, 2011 | 02:20 AM
jacob502's Avatar
No problem. I'm pretty sure it is the idle-to-air control valve. Try to take it to the dealer and replace it through warranty (they propabley wont since they cant identify it). It doent cost much in the gulf, I dont know about the US MB dealers, but I replaced mine and it solved the problem.
Another reason, which I doubt in your case, is a weak throttle, which can be identified instantly through a DAS.
Or it could be a problem with the alternator, which can also be identified through an electric diagnosis.
Anyhow, take it to the dealer, and see what they say about it.
P.s., if thier computer doesnt read anything, then just replace the control valve and hopefully the problem will be solved
Old May 12, 2011 | 02:22 AM
vmx128's Avatar
2011 C63 P31
Yeah, it doesn't look like they overfilled it. I just went for a drive and noticed a couple of things:
The engine idles at 217F when it's 64F outside. Does this sound normal? I let the car sit in idle for 5-10 mins.
Also, the vibrations I mentioned above peak when I rev the engine to around 800 RPM and then either go away or is drowned by the loud engine.
Old May 12, 2011 | 02:26 AM
vmx128's Avatar
2011 C63 P31
Thanks a lot for the detailed info. I'll take the car to the dealer tomorrow.
Old May 12, 2011 | 02:52 AM
AMGFTW's Avatar
C63 AMG
Listen dickweed there is no need to cop an attitude to look cool on here.
I read his topic from my phone, didn't see the picture since it was not in the original post, and replied with a suggestion based on my previous experience working on cars over the years.
Old May 12, 2011 | 08:24 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Vmx, idling too long at a time is not good for any vehicle. Most recommend not more than 5mins at a time. Good luck fixing the problem.
Old May 12, 2011 | 09:41 AM
Mort's Avatar
I think my car runs oil temperatures of ~ 102*C when idled for a while. I warmed mine up during the winter to keep the engine lubricated and that is the oil temp I saw. 102*C = 215.6*F. So I would say 217*F is a normal operating oil temperature for our cars.
Old May 12, 2011 | 11:31 AM
MB-BOB's Avatar
Admin Alumni
See Garage
Check your PMs for your infraction, please
Old May 12, 2011 | 05:12 PM
vmx128's Avatar
2011 C63 P31
Went to the dealer to have the car checked out, and as expected, everything is normal according to them. I was told that the vibrations change as the engine breaks in. He even told me that my engine vibrates less than some other 63's he has seen.
I wish my mind had not latched onto this slight grinding/vibration at around 800rpm. Now I can't help but notice it every time I get in the car!
Old May 12, 2011 | 07:30 PM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
For real?
Or are you kidding?
Old May 12, 2011 | 09:57 PM
SonnyakaPig's Avatar
MB
I don't understand the infraction. I think this particular issue could easily have been self-moderated.
It was a misunderstanding and an incorrect assumption on AMGFTW's part.
IMO, GHAZAN made a valid point--I thought the same thing. Of course, from AMGFTW's perspective, whether GHAZAN made a good point was moot, because without him having seen the picture, he figured GHAZAN was being abrasive, which he wasn't, IMO.
Mods, please give us some credit. Of course, if these are the rules, then my opinion is moot.
Old May 12, 2011 | 09:59 PM
GHAZAN's Avatar
MBUSA
point was he didn't need to say "d**kweed" but he could've still been abrasive...fine with me
Old May 12, 2011 | 10:03 PM
MB
And my point was that you or someone else would have likely said what you said directly above. I agree with your point.
Old May 12, 2011 | 10:13 PM
This is the grade school stuff that I referenced in another thread.
Calling someone d,ckweed is not that offensive IMO.
This just reminds me of a teacher stepping in when to little boys have wrds.
C'mon mods we're all grown men here, I think this could have been handled between them, no need to step in.
So touchy here, jeez--time to go drink some boost
Old May 13, 2011 | 12:38 AM
AMGFTW's Avatar
C63 AMG
Just remember kiddies its easy to act cool on the internet lol
We are all grown men here. I made a mistake and didn't need some e-warrior looking to boost his online ego by trying to make me look like a fool.
And Ghazan no need to PM me after reporting my post getting me an infraction rubbing it in my face. Just so everyone can see how idiotic you are this is the exact PM I got from him:
Title: sucka
maybe you have an app for that haha
Old May 13, 2011 | 12:40 AM
GHAZAN's Avatar
MBUSA
hahaha god i crack myself up no hard feelings AMGFTL?
Sorry OP, Im out of this one
Old May 13, 2011 | 01:25 AM
VCA_AMG's Avatar
2018 E63S Wagon
Geez, it's a bit too tense in here. AMGFTW, take a breath man. We are all here to relax...hair-trigger defense mode not required for the interwebz.
Old May 13, 2011 | 01:34 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
Just so you guys know, the 5w40 Mobil 1 Formula M is less rich in additives than the Mobil 1 0w40. I've ran oil analysis to see this.
The M1 0w40 is what the factory uses for AMGs (regular Mercedes get a Shell believe it or not).
Every Porsche leaves factory with 0w40 Mobil 1 even most race Porsches.
0w40 Mobil 1 goes BEYOND Mercedes requirements because it meets so many major manufacturer specs. The 5w40 Formula M is more tailored to just squeak by the Mercedes specs.
I take in the 0w40 myself. Probably more significant to do so if you take your oil to the full 10,000 a year.
