Is C63 Really Worth $70k?
#151
96 and 08 911 turbos
I know what I meant, you now know what I meant, if you didn't before.
Just to be clear for the final time:
real sports cars do not have torque converters in their transmissions
#152
lol...no.
Daddy had an M3, a clk550, and now drives an SL55.
I went from an A4, to an E430, to the S500.
yes, I do wear a blazer, tweed, and suits everyday.
I absolutely love my s500. Not to mention, the combination with the more raw 993tt and the comfy quiet s500.
Like I said before. I have the ability to own two cars, so why would I buy a compromise car?
#153
Are we going to continue this? You can call it a ****ing banana transmission if it makes you sleep better at night.
#154
Furthermore, while on average, an S600 is a nicer car than a 500, I don't believe so in my case.
My car has AWD, which is a luxury in and of itself. It also has the full leather interior found on s600s. Its got radar cruise control, a gazillion way adjustable heated and ventilated dynamic seats, rear air conditioning, voice control, power trunk, keyless go, parktronic, reclining head/vented rear seats, etc etc. With the exception of a heated steering wheel and 4 place rear seating, its fully loaded.
Does a 221 offer some benefits, sure. Does it serve as a more luxurious car? No. The 550, which is the only car with awd, cannot be spec'ed with a full leather interior, and aside from some better electronic suites, I don't care for the 550 interior.
Again though, a Ferrari F40 is a pure sports car. Its 20 years old, and newer and better sports cars have been built, but that does not make it a compromise.
A c63 has a powerful engine, but it is wrapped in a sedan body, it has an automatic transmission, and a bunch of electronic stuff that makes it heavy, resulting in a less sporting experience. It tries to be something of a luxury car, but it also rides hard, has a lot of engine and exhaust noise, and hard to the touch plastics. It has a ***** out engine, but the weight, and suspension are not up to sports car standards.
It tries to be everything to everybody, and I don't see a point in that.
#155
Who cares what mechanism the car uses to actually make the car change gears? That is one of the dumbest comments about sports cars I have read. If the car can accomplish the same thing (change gears) as well as another who cares. You could make stupid comments about what makes a real sports car all day with that logic.
A true sports car's sole point is to make the connection with the car and the road as strong as possible. Becoming "one with the car" in the philosophical sense.
A torque converter not only decides when to shift for you, but it also does not always shift when you want it to. For instance, you approach a turn in 4th gear. You need second. In a manual transmission, you select 2nd at once. With a semi-automated non torque converter car, you hit the paddle twice, and you are nearly instantaneously in 2nd. With a torque converter, you either wait for the car to shift itself, which could take god knows how long, or even worse occur on corner exit when you are least expecting it, or be delayed if you use the "manu-matic" function.
That of course ignores the interaction of man and machine that occurs with a manual.
#156
While not the most luxurious it does a fine job of doing it all. It looks classy, it sounds mean and it can back up its bark tearing the a$$ of many "REAL" 2 door sports cars on the road.
Your 2005 S500 on the other hand is outdated and was overpriced in 2005. It has nice luxury options but its nothing amazingly special at all and for its price completely not worth its cost for what it gives.
Cars like the S500 are not meant to be owned. You lease them and give it back in 3 years and get another one. The C63 is a car you keep.
#157
You said you work at the NYSE. Right? Maybe you should pay more attention to actually making money for you and your clients, instead of hanging out here making people feel bad who worked hard to obtain either a used or a brand new C63.
BTW, a little fashion advice as well: Loose the tweed jackets ..... if you ever want to get laid. Speaking of getting laid, it might put you in a better mood
#158
Backpeddling? ..... since I had to explain to you the definition of automatic/automated, may I suggest something else?
BTW, a little fashion advise as well: Loose the tweed jackets ..... if you ever want to get laid. Speaking of getting laid, it might put you in a better mood
For someone who works on the NYSE he sure does have some interesting post time stamps. I know many people who work on the exchange and they sure aren't making posts on MBW during trading hours.
#159
Absolutely not. The S500 was designed for one purpose...to be a luxurious full sized sedan. Yes, there are more luxurious full size sedans that have been built in the mean time. That doesn't change the level of luxury in my car.
#160
I do.
#161
1 Post
'11 C63, '22 GLS 63, Porsches, M3, M4
First of all, the S500 is a fine luxury car. No point denying that.
As far as the C63, yes, it's a compromise car. Neither pure sports car nor pure luxury car, and I've driven plenty of examples of each. But would you concede that if someone needs or wants a sedan, the C63 is among the sportiest options available?
#162
The C63 beats many of what you consider "real sports cars" on the road course and in the 1/4 mile.
You are free to your opinion on my car. It doesn't bother me. It does everything I need it to and more, and was one of the most luxurious cars available for sale when it was produced.
MBs are not cars you keep, period. There will always be something better along the pike.
Further, perhaps you don't quite understand what the nyse is. The exchange is platform for trading. I'm not a specialist or floor broker, neither of which are exchange employees anyway.
And lastly, I will not be taking any fashion advice from you. Thanks however.
Since this crazy thread won't fizzle, what the heck, I'll stay involved.
Take the C63 motor, pair it with a manual transmission, and stick it in the M3 chassis, and I'd think it was the best compromise car out there for a sporty sedan.
#163
1 Post
I would put the M3 ahead of it. Yes, its gotten far more porky than the original E30, and the 95 E36, which I loved. However, I feel it puts a finer point on the sports car feel to me. I don't love the v8, it lacks torque.
#164
#165
1 Post
Nothing inherently wrong with compromises though. Sometimes they make sense, or are necessary.
#166
The S500 has only one purpose...to make its occupants as comfortable as possible. The car (500 anyway) is slow, handles like dog****, and isn't particularly fun to drive. Obviously its not a bentley or a maybach, but it gives me the most luxury in its price range.
The C63 tries to be practical, sporty, comfortable, good handling, luxurious, good sounding, etc. the compromise is inherent in its design.
#167
What you are saying is the S500 isn't a compromise because it has what you want. A 7 year old entry level S500 would be considered a compromise car using the same logic you assign to any car that doesn't fit your definition. It isn't class leading in any way. There are far better and nicer luxury cars on the market. Better fit and finish, engines, transmissions, performance, features etc. But you don't think you compromised because you got what you wanted. The same goes for everyone else.
#168
Its [C63] a compromise by design, and it achieves it's target.
#169
Where do you mention anything about a TORQUE CONVERTER in your original post that I replied to?
Keep on digging that hole deeper and deeper and deeper ..... .... let's face it, you're not the smartest guy, just a guy with a BIG mouth on the keyboard. My guess, you're someones b!tch at the NYSE, hence your negative attitude.
#170
Mercedes C63 amg, Bmw X5,
I also wonder, is the porsche already considered antique?
#171
LOL @ the s500 guy saying his car is better than a C63?
Its rare to see that much ignorance, even on the net.
The s500 is obv a compromise with the main reason being its almost a decade behind in technology.
#172
The thread started off as strange, then fun, and now...sad.
There is nothing wrong with saying some cars are compromise cars by design, sure there are plenty of them now. Nothing wrong with defining what a sports car is either, but this pi$$ing contest needs to end.
Perhaps we all need to go get laid.
#173
1 Post
Getting back to the OP's question, yes, the C63 is easily worth $70K and is a great choice if a sports sedan is what's desired.
#174
Like I said, a BACKPEDDLE not to be confused with backpedaling ..... for definition, look up "urban dictionary": A pathetic attempt to save your butt from a stupid statement made earlier
The rest I'll let you work up with your imagination to whatever you wish.
Is a 15 year old porsche an antique? I'm not sure...my state doesn't think so, but thats your call.
You seem to share flash's lack of understanding of a compromise.
A Shelby 429 cobra has technology that is 40 years behind in technology. Does that make it a compromise?
#175
An austin healy 3000 is a real sports car. A minivan could beat it on the track. Track figures are not the defining factor of what or what is not a sports car.
Ahh, so because it has a manual gearbox its a sports car.
There is always something better yet you own a 15 year old 993 (I do also) and a 7 year old MB. Why did you keep them? The GT2 or GT3 is a much better. The current S550 is leaps above your 2005 in luxury.
So the SL is a car you dont keep? The SLS? Very silly arguement. There is nothing special at all about the S500 or S550. There is no reason to keep them at all. You lease and trade them back in and get another one.
The C63 will be an historic car. Limited production and the biggest NA engine in a MB. If and when they change over to the 5.5 and dump the 6.2l it will gain even more value.
