C63 AMG (W204) 2008 - 2015
Oil Cooler Fan
Old Aug 19, 2011 | 10:32 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Oil Cooler Fan
Does anyone happen to know at what temperature does the oil have to be, before the oil cooler's fan kick on? Also, does it run quiet?, I ask these questions, because I have never heard it run even when the temperature was 102F not counting the heat index, here is the DC area. Maybe just maybe mine, might be broken, I don't know And I pride myself on knowing everything about my cars.
Old Aug 19, 2011 | 01:31 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Not sure about the oil cooler fan.. but I cannot hear anything over the radiator fan.. which sounds like a freaking jet turbine... Everyday for me.
Old Aug 19, 2011 | 01:38 PM
Yuille36's Avatar
I called my indy, and texted my AMG tech at ASC, currently awaiting an answer from either of them.
Old Aug 19, 2011 | 01:41 PM
JeffDL's Avatar
C63
no dedicated oil cooler fan.
Old Aug 19, 2011 | 01:44 PM
Yuille36's Avatar
Maybe the fan does work, but is very quiet.
Hell, I don't know....that is why I'm seeking answers.
Old Aug 19, 2011 | 02:00 PM
mthis's Avatar
Anything W/4Wheels
250F+ on AMG menu
Then you can hear it for sure.
Old Aug 19, 2011 | 02:05 PM
Yuille36's Avatar
JeffDL,
There is a fan mounted on the oil cooler that is mounted on the passenger side, just behind the bumper. I just talked to my indy, and he said the fan is very quiet, so you might not heat it. And that he will look up the technical spec in ALLDATA, and let me know. I'm still awaiting a text from my AMG Master Tech. But the fan is there, take a look for yourself.
Old Aug 19, 2011 | 02:16 PM
Yuille36's Avatar
Originally Posted by mthis
250F+ on AMG menu
mthis,
You would know this how? As my oil has never gotten that hot. Correction, this is fahrenheit not celsius got it.
So, my oil has probably been this hot, just couldn't hear the dam fan running
Old Aug 19, 2011 | 02:22 PM
mthis's Avatar
Anything W/4Wheels
I have gotten by car to the point where it went into limp mode.
Plus I went to AMG academy and drove a c63 P31 like it was stollen and when I stopped the car everything was on at 264F
Old Aug 19, 2011 | 02:36 PM
Yuille36's Avatar
Dam, you drove it like you stole it for real.
So 250F+ is the answer then....got it.
And thank you.
Old Aug 19, 2011 | 02:45 PM
GMW's Avatar
GMW
2013 ML63 AMG PP
If you drive hard for a bit and the temp goes above 107 degrees Celcius then the extra oil cooling fan kicks in until the engine oil temp falls below 107 C. However you won't hear it from inside but if you stop the car and leave the engine running you can step out towards the right side front bumper vents and hear it for yourself. It's fairly noticeable from the outside. Plus if you move closer to the vents you'll feel the heat being blown out of those side vents! It's quite a cool thing and makes those vents actually functional and not just a stylish addition. :-))
Old Aug 19, 2011 | 02:48 PM
mthis's Avatar
Anything W/4Wheels
What u hearing on the right side front bumper is trans cooler.
That's louder then the fan. When both are on at the same time u will only hear the trans cooler bc it's so loud.
Old Aug 19, 2011 | 02:57 PM
JeffDL's Avatar
C63
Originally Posted by Yuille36
JeffDL,
wow that's pretty cool actually. thanks for the info.
Old Aug 19, 2011 | 03:01 PM
mthis's Avatar
Anything W/4Wheels
IF u haven't noticed ther are no holes on the left side only right side has them
(I wounder if we can put one in that side, trans overheat problem solver rite there)
Old Aug 19, 2011 | 03:08 PM
Yuille36's Avatar
I knew about the oil cooler, trans cooler, and power steering coolers.
Well, I learned something new today about the car, that I didn't know an hour ago.
I don't think that, I'll ever drive the car that hard to hear the oil cooler fan kick on.
Now that reminds me, when I was at the AMG Performance Drive in Monticello, you could hear all the fans going, because we literally drove the cars like we stole them.
Old Aug 19, 2011 | 03:11 PM
Yuille36's Avatar
The AMG Black Series cars, (SL65, CLK63) etc.. utilized that space for additional coolers. Now the C63 Black Series Coupe as well.
Old Aug 19, 2011 | 03:14 PM
mthis's Avatar
Anything W/4Wheels
Try to get some details about The c63 Blk. Maybe it has a cooler on the left (from pic it looks like a nono)
Ask u friend if he can get any info.
Old Aug 19, 2011 | 03:24 PM
Yuille36's Avatar
Their is a cooler on the left side, just like my friend Steve, he has a CLK63 Black Series. And their is an additional cooler their. I'm sure the C63 Black Series is the same, also they have a rear differential cooler as well. My E63 just has cooling fins mounted on the rear diff, and my C63 doesn't have any cooling fins.
There isn't a whole lot of data on this car actually, besides from what Mercedes-AMG has already released.
Old Oct 10, 2016 | 06:08 PM
d7om63's Avatar
2012 C63 P31
