C63 AMG (W204) 2008 - 2015
Michelin Super Sport review.
Old Mar 13, 2012 | 12:29 AM
  #51
Strafe1's Avatar
2021 E63 S Sedan
Originally Posted by Pit-Pony
What do you guys think for 18s. Stock is 235/40 18 & 255/35 18.
I'm buying PSS 235/40 & 265/35 (instead of stock 255/35)
The rears are only 1.11% larger. Fronts are the same.
Will this throw off the traction electronics or TPMS?
The answer is no, it won't throw anything off. You will have much better traction though! I ran 235's on the front and 275's on rears of the OEM 18's with ZERO issues.
Old Mar 13, 2012 | 02:33 AM
  #52
-=Hot|Ice=-'s Avatar
Cars.
Do they have them in all seasons? The Conti ExtremeContacts are pretty good tires as well.
Old Mar 13, 2012 | 03:15 AM
  #53
_AMG_'s Avatar
C63
Never tried them but I've heard great things about the Conti Extreme Contact's.
Michelin does carry all season's, but the Super Sports are summer tires.
Old Mar 13, 2012 | 05:00 AM
  #54
Jycke's Avatar
2024 EQE 43 AMG SUV
Originally Posted by gthal
I'm running 245/265 PSS.
A given rim width can accommodate a wide range of tires. Two things to consider... too wide of a tire on a rim will result in the sidewall getting less support and you will get more of a more sloppy feeling and more tire roll in aggressive driving. I find that running a tire that technically fits a rim but is at the outside limits (either on the small or large size) impacts the feel of the car. Too skinny = harsh and an overly darty feeling. Too wide = sloppiness and tire roll. The other issue is aesthetics.
My personal concern with going 275 (especially in a PSS which runs wide) is that it may be a little balloony as the 265 "looks" to be about as wide as I would want to go to avoid tire bulge. Having said that, I personally don't like the balloon look so I'm biased... also, with only a 30 profile, there isn't much tire sidewall anyway. I find the 245 fronts actually balloon noticeably more... not bad necessarily, just more.
IMO only, 245/275 work fine on the OEM wheels as long as you don't mind a little bit of tire bulge. On the 18" wheels I wouldn't like the look personally (too much sidewall and bulge is not appealing to me) but on the 19" wheels with such little sidewall it is fine.
Thank you. But the 265 according to the spec sheet support same rim size 9-11 ". Will it not then also look as "bulgy" as the 275's? Help a noob :P
Old Apr 10, 2012 | 09:11 PM
  #55
hhughes1's Avatar
2013 Chevy 427 Torch Red
Just made the switch today 245/40 and 265/35. The Star Spec's were great tires and I even got 9,000 miles on the rears although they howled the last 1,000 miles or so and wheelspin was horrible. The PSS is a great looking tire once it's mounted and I will report back down the road once I have the opportunity to put them through the paces both dry and wet.
Old Apr 10, 2012 | 11:38 PM
  #56
JamE55's Avatar
Out Of Control!
Pilot Super Sport 285/30/19
Anyone know when Michelin will get their head out if their a***s and make a 285/30/19 size?
Old Apr 11, 2012 | 09:44 AM
  #57
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
Any reason why you didn't go with the 275 rears?
Old Apr 11, 2012 | 10:09 AM
  #58
hhughes1's Avatar
Tread width for the 265 is actually listed as wider than that for the 275. Mounted on 9" wheels will likely yield a larger contact patch with the 265. Additionally any decrease in sidewall height looks better in my point of view especially with the drop from the H&R springs. I have run the 265/245 combination for several years now and just feel comfortable with it on the stock wheels.
Old Apr 11, 2012 | 10:18 AM
  #59
VaclavSV's Avatar
2012 C63 AMG Black Series
This is what I ordered. PSS on 18's 245 and 265. Ill post pictures when they're on the car.
Old Apr 11, 2012 | 11:36 AM
  #60
PatSC23's Avatar
2009 C63
What have people paid?
I would be interested in 245/275 setup on 19's
Old Apr 11, 2012 | 11:47 AM
  #61
Chocofishez's Avatar
2014 E63 S
I just bought two rears from tirerack for 288 each... much cheaper than when I bought my first set last year.
Old Apr 11, 2012 | 11:55 AM
  #62
SSSSE YA's Avatar
2007 CLS 63 030 package 2011 C63 1997 Dodge Viper GTS
Everyone is very happy with the SS on the Viper Club forums also.
OE Michelin's in-house testing, performed at the Michelin Technology Center, helped identify six key areas in which the Michelin Pilot Super Sport outperforms its predecessor, the Michelin Pilot Sport PS2:
Road-holding on dry surfaces: Tests showed a 1.5-second gain on a 2,700-meter closed-circuit track.
Braking on dry surfaces: When decelerating from 100 km/h to a full stop, braking distance was shortened by 1.5 meters.
Road-holding on wet surfaces: Time was reduced by 2.5 seconds on a 4,100-meter closed-circuit track.
Braking on wet roads: When decelerating from 80 to 10 km/h, braking distance was shortened by 3 meters.
Total mileage on the track: 50% more laps.
Total mileage on the road: 10% greater distance.
but, there is no head to head testing between the Pilot Super Sport and the OE Pilot Sport PS2 C1 Viper tire
Old Apr 11, 2012 | 12:45 PM
  #63
hhughes1's Avatar
$1,105 out the door including tax, mount and balance at local Discount Tire
Old Apr 11, 2012 | 03:14 PM
  #64
lunarx's Avatar
07 M6 | 09 RX-8 | 07 LGT Wagon | 17 Bolt
How would you say they compare to RE11?
Old Apr 11, 2012 | 04:04 PM
  #65
PatSC23's Avatar
2009 C63
Are these sizes for 18 or 19"? Does that mean I could run 245/35/19 and 265/30/19?
Old Apr 11, 2012 | 06:00 PM
  #66
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
So if my rear wheels are 20x9.5 and I currently have Vred 285s on there right now, should I go with 275s with the Michelins in the rear?
Old Apr 11, 2012 | 11:42 PM
  #67
gthal's Avatar
2012 C63 coupe
RE-11 has better dry grip and a firmer sidewall which makes the tire feel sharper with less perceived tire rollover. PSS is better in the wet and has a quieter and softer ride. Also, the RE-11 held up better for me at track events.
IMO... PSS is for the street with light track duty. RE-11 is you spend more time on the track or prefer a firmer and sharper performing tire. PSS is the best overall tire (all things considered) on the market at the moment IMO.
Old Apr 12, 2012 | 04:23 AM
  #68
lunarx's Avatar
gthal - Thanks for the comparison.
I would agree that the PSS is the best performing street tire that remains civilzed enough for daily driving.
PS2 was my favorite street tire before.
Did you find the noise on the RE11 objectionable for daily driving?
  #69
lunarx's Avatar
Do the new AMG's come with the ContiSportContact 5P?
Anybody running the 5P?
According to this review, the 5P is very good.
http://www.tyrereviews.co.uk/Article/2011-Autoreview-Max-Performance-Summer-Tyre-Test.htm
However, the review clearly states the PSS beat the other tires in dry performance, so it's the one to get if thats the priority.
Old Apr 12, 2012 | 06:37 AM
  #70
gthal's Avatar
2012 C63 coupe
Noise level was fine for me. Others have experienced something different.
Old Apr 12, 2012 | 06:38 AM
  #71
gthal's Avatar
2012 C63 coupe
I find this test interesting. If you look at Tirerack's test, the PSS was by far the best tire in the wet and clearly better than, say, the Pzero. Also, subjectively, everyone seems to LOVE the PSS over anything else yet in this test it finishes 6th?
Old Apr 12, 2012 | 01:44 PM
  #72
derspi's Avatar
2009 C63
I would definitely place more confidence in TireRack's comprehensive tests over a website that lifted that piece from another website (AutoReview, I believe). That whole review is a bit retarded if you ask me - why would you place the majority of the scoring on wet performance for a "max summer"?! I didn't bother to check out the full review but it could be location & climate related for the unusual scoring criteria (say, if it's UK based) but either way, it doesn't seem like a fair and objective test when the criteria doesn't suit the intended purpose of the tires being tested.
Old Apr 13, 2012 | 12:58 AM
  #73
lunarx's Avatar
Clearly the scoring criteria was not dry performance focused.
I'm just wondering if maybe the Conti 5P is a decent runner up.
I would early retire my PZero for PSS in a heartbeat if they made the rear size I need.
I thought new AMG might be getting Conti 5P and some might have opinions to share.
For instance, I cant say anything bad about PZero except that I'd much rather have PSS.
I was actually surprized how well PZero perform and wear as I would never consider buying them willingly.
Old Jun 18, 2012 | 02:19 PM
  #74
WEBSRFR's Avatar
Tesla Model S P100D
Any word on how these perform in rain/wet conditions?
Old Jun 18, 2012 | 06:46 PM
  #75
gthal's Avatar
2012 C63 coupe
IMO, they are the best Max performance summer tire in rain/wet available compared to what I have owned (Hankook V12, Potenza RE11, Potenza RE050 PP, Conti 5P, Michelin PS2, Pirelli Pzero). In addition to their wet/dry ability, my PSS now have 5,000 kms and 2 track days on them and they look hardly worn at all. They hold up VERY well.
