Why WAS THE FLUID MOTOR UNION THREAD CLOSED.
#51
You cannot have this much bad attention without most of it being true in my opinion based on a google search of older reviews. Good thing I never dealt with them and never will...
#52
2004 W211 E55K, GL550
Thank you ur one of the few that get the point of thos thread i didnt out this thread up here to bash fmu i put it up cause of the bad experiance i gpt from them and would hate to see someone else fall in same situation i did
#53
Super Moderator
#54
09 c63 p30 mars red
I find it interesting that the last three guys claiming to have been abused by FMU have not chimed in to support the other two.
So far none have produced a receipt or any pics of the damages. Very strange?? What is obivious FMU needs to do some self reflection ---- seem to have pissed off some people.
#56
If so, that thing is f***ing SICK!!
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
#59
GT3
Straps break, whats your point.... I have seen multiple strap failures in my day. To think you can strap a 4000 pound vehicle to the ground that makes 400-500-plus whp and then go WOT throttle with never ever encountering an issue is an idiot.... Your latest rant is ridiculous and still waiting for the other info...
#61
As for the idiot comment, I'm not going to let that get to me either, you're the idiot.
For the record, I am not bashing MHP. They are doing a good enough job of that on their own.
#62
![](http://i93.photobucket.com/albums/l49/Alkan1380/headers2.jpg)
![](http://i93.photobucket.com/albums/l49/Alkan1380/headers.jpg)
its obvious the secondary pipes were heated and hammered back because they were rubbing up against my steering knuckle. And For those who think i should have keep this private and confidential i did for a year up until i saw a thread with f.m.u and mention of my situation in it, and if im lying about that as well you can ask F.M.U about that as well.
#70
And if saltydizzle who is a forum member on here who purchased E55 has the car would be willing to take pics of the steering knuckle from underneath the vehicle you could clearly see the knuckle had been grinded down. But unfortunately i never took pictures of that at the time.
#72
Just a FYI F.M.U bought back the headers only after i blew my motor and noticed the header was mangled like this and again i have never posted pics of this till today. But my question is why were these ever put on my vehicle at any point in time, is what i never understood.
#73
What caused it, etc...
#74
Hey,
I have been reading this forum for a while now, as I’m interested in purchasing a C63. I thought I would look into reliability issues before I took the plunge. For this reason I have not had a reason to sign up, but after reading this thread I thought it would be a good idea for me to sign up, chime in, perhaps offer some advise and point a few things out to the OP.
Bnzuovr, firstly I would like to say I’m sorry to hear about the troubles you have had with your motor. I read your original thread from the link above and it seems that you are perhaps thinking the O2 sensor mix up may have caused damage to your engine. I was quite shocked to see that there was no one either qualified or knowledgeable that chimed in and stated the obvious. O2 sensors on nearly all factory vehicles are only used to regulate a Lambda 1, which is an air fuel ratio of 14.7 (stoichiometric). This is purely for emissions purposes. O2 sensors on factory vehicles are mostly used to control fuel trims at idle and part throttle driving. This is known as “Closed Loop” control. Once the vehicle is at full throttle and high load, it will then switch to “Open Loop,” which in simple terms means the engine management control unit no longer uses O2 sensor signals to control fuel.
So, the first point I am trying to make is that engines will very rarely go wrong at part throttle driving. Damage is almost always likely to happen in full throttle, high load situations. At that point, the O2 sensors may as well not be there, because they play no part in fuel control. So you can most definitely cross this one off your list of potential culprits.
I was trying to find a very good write up by Toyota that I once found on the web, but cannot seem to find it. However, I did find a site that is talking about a Motronic control unit found on a Porsche. You will clearly see that these also do not use lambda values to correct fuel at WOT: www.motronic.ws/lambda.htm
I can find some more if you like. But generally, if you google open loop/closed loop control, you will quickly see for yourself.
Now I am no expert, I certainly do not know exactly what went wrong, but let’s just say that hypothetically it was a bad “tune” (I prefer Engine Calibration) according to this post: https://mbworld.org/forums/4409695-post10.html You have said that the tuning was NOT done by Fluid Motor Union but by another tuner. So if this is the case, and let’s again say it was a bad calibration, then how are they to be blamed if they did not do the tuning?
Please forgive me if it seems that I am siding with one party, I am only telling you how I see it.
Lastly, I have always wondered why people are very surprised when a engine fails due to tuning and pushing the vehicle further than the manufacturers intended. Like dude come on? Especially when the engine is old, in an old car, most likely with a couple of owners previous to your self. Who’s to know what kind of life the engine has had, what kind of driving it has done and what care was taken… Engines can go bad in stock form, I should know as I see them all the time at my work. And some of these engines go bad with no explanation as to why?
Anyhow, I hope you have better luck with the new motor…
#75
Here are some pics of the headers steering knuckle i don't have a picture of cause you know i lied about that one to. Or maybe we can get fluid on here to question about that and i will have a invoice of my recipt on the 2nd hand motor that was put in my car as well as the invoice for the work that was performed at f.m.u.
Thanks for the heads up.
Although I have not dealt with them... From all the posts and bad press I see just Google searching (real or fake) I know I for one will not be a purchaser of FMU products.
