K&N or not.
Subscribe
Dec 12, 2011 | 09:16 PM
I spoke with one of the vendors here who did all the work on my car. I ask him about putting K&N's in it. I've had them in every hot rod I've ever owned. He told me not to do it, something about the oil from the K&N's messing up two senors, one on each bank of the engine that run about $400 ea. Anyone familiar with this? Any and all help will be appreciated.
Erich
Reply 0
Dec 12, 2011 | 09:48 PM
You are posting on the C63 subforum, are you talking about your C300 or a C63?. I had a set of K&Ns and did the job for me. What you are refering to is the oil from the air filter messing the air flow sensors but it is a bit exagerated. In the worst case scenarios there is a spray cleaner specifically for the sensors.
You should be OK with the K&N filters. Lets us know if this is for your C300 or for a C63. Do a search in my name, I did reported great gas mileage adter installing the K&n but I also hada CEL that caused my engine to have vibrations. Dealer reflashed back to stock and put paper filters and problem dissapeared.
Reply 0
Dec 12, 2011 | 10:06 PM
It wouldn't be the first time its happened. But you should be fine. The sensors can be cleaned off too.
Reply 0
Dec 12, 2011 | 10:19 PM
It seems the to K&N or not to K&N (that is the question) threads will never end. Stock paper filters flow good, have no oil. K&N's flow slightly better, but have oil and risk messing up sensors if not cleaned properly etc. I would personally suggest AEM Dry Flow which in opinion will flow slightly better then stock, but has no oil and no chance of messing up a sensor.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Reply 0
Dec 12, 2011 | 11:30 PM
+1 on KN filter. It's one of the best filters out there. Enough said.
Reply 0
Dec 13, 2011 | 12:13 AM
AFE Pro Dry Filters are oilless filters....
Use those if you're scared.
Reply 0
Dec 13, 2011 | 12:43 AM
Been using K&N's for more then a year in my car.
No problems at all.
Reply 0
Dec 13, 2011 | 03:47 AM
This is a better option combined with ROW air boxes. K&N oil coated filters will foul your MAF(s) and I've had them come apart at the rubber edges.
Reply 0
Explore
Dec 13, 2011 | 06:04 AM
have had afe dry filters in my c55 for 6 months/ 10,000 Km. no problems.
Reply 0
Dec 13, 2011 | 09:18 AM
Quote: You are posting on the C63 subforum, are you talking about your C300 or a C63?. I had a set of K&Ns and did the job for me. What you are refering to is the oil from the air filter messing the air flow sensors but it is a bit exagerated. In the worst case scenarios there is a spray cleaner specifically for the sensors.
It's a C63
Reply 0
Dec 13, 2011 | 11:20 AM
Have K&Ns on my car and no issues after 7,000 miles.
Reply 0
Dec 13, 2011 | 11:31 AM
i used k&n's on my '09 and then again on my '10... no issues... i've now changed to bmc filters only because i got them with my ROW boxes...
i still have my k&n's slightly used from my 2010... the k&n's on my '09 went with the car... i forgot about them before i traded
Reply 0
Dec 13, 2011 | 12:10 PM
I have ran K&Ns in nearly all of the 49 cars I have had. Never once have I had a MAF fail because of them. This includes 4 Mercedes-Benz powered cars as well.
2004 Crossfire
2005 Crossfire SRT-6
2001 CLK55
2005 CLK55
I just recently switched to AFE Dry Flows in the CLK55 to try them out. The quality of the filter is great. However the fitment was not as good as the K&Ns. But reoiling is a PITA, so it is a compromise I am willing to accept.
I really wouldn't worry about new K&N's, it's when they are over reoiled that they may become problematic. If you are still worried about it though, buy the AFE Dry Flows.
Reply 0
Dec 13, 2011 | 12:53 PM
I have K&N's, at first I was getting CEL every 100-200 miles, after a month, I sent my ECU back to eurocharged and informed them I had K&N's, they integrated it into the tune, and I haven't had any problems since.
Reply 0
Dec 13, 2011 | 01:36 PM
Quote: This is a better option combined with ROW air boxes. K&N oil coated filters will foul your MAF(s) and I've had them come apart at the rubber edges.
I've had Mann paper filters come apart at the edges. Just adding this. Really annoying, but what should I expect for $15.00?
Reply 0
Dec 13, 2011 | 01:38 PM
Fitment is good?
Reply 0
Dec 13, 2011 | 01:40 PM
Quote: It wouldn't be the first time its happened. But you should be fine. The sensors can be cleaned off too.
The only time I've seen it happen is when people over-oil the filters. K&N makes a good product and I've ran them on almost every vehicle I've ever owned, starting with my GoPed when I was 12 years old.
Quote: Fitment is good?
aFe also makes a good product. Fitment is OEM level. I can get you either one.
Reply 0
Dec 13, 2011 | 01:45 PM
K&N's provide no benefit. They flow marginally (and I do mean marginally) better when they are clean, but they filter worse so you get more silica in your oil.
When they get dirty, they flow less than a dirty paper filter.
In other words, there is absolutely no reason to run one. Any power gained will be so small as to be unnoticeable and you have to deal with cleaning and getting the right amount of oil, etc.
the stock filters work great and are cheap.
Reply 0
Dec 13, 2011 | 01:48 PM
Quote: aFe also makes a good product. Fitment is OEM level. I can get you either one.
Thank you. I will keep you in mind when I need replacement.
Reply 0
Dec 13, 2011 | 02:22 PM
I have used them on most of my cars without a problem.
Some of them however do ship with a bit to much oil.
So i always just use an air gun and blow therm off for a few seconds before I put them in.
Nothing crazy just 2 or so blasts per side..
Reply 0
Dec 13, 2011 | 02:36 PM
Been using K&N for 3 years..no problem.
Reply 0
Dec 13, 2011 | 03:47 PM
I agree with Olivewerk. The negatives (CEL and MAF issues) far outweighs the small claimed benefit
Reply 0
Dec 13, 2011 | 04:03 PM
Have K&N and my car sounds just a bit louder upon acceleration and louder initial bark on start up...2000K miles no issues. They fit like a glove in the air box. And had no oil issues...
Reply 0
Dec 13, 2011 | 04:48 PM
K&N says not to use compressed air as it can damage the filter material. If you suspect there is too much oil it might by better to pat it down carefully with a paper towel.
Reply 0
Dec 13, 2011 | 05:49 PM
Quote: The only time I've seen it happen is when people over-oil the filters. K&N makes a good product and I've ran them on almost every vehicle I've ever owned, starting with my GoPed when I was 12 years old.
Send me a PM on price, please sir.
Reply 0
Subscribe
Currently Active Users (1)
