Should I get ROW airboxes?
lighten up gents
Did you try searching. Because your EXACT question has been answered at least six hundred times.
Search: row, boxes, sound
I'm on my phone so I don't feel like searching for the thread, but maybe someone else can link it.
He should of done clean oem with row then pop in afe filters.
Just stop.
I said he used his stock air box and stock filter and dyno'd and the power was the same as when he used the row air box with the stock filter and got on the dyno. Then he dyno'd using the row air boxes and afe filter and that's where all the power gains came from.
So based on that, if you just put the afe filter in the normal air box, you'll be getting the same amount of power gains so the actual row air box is a waste of money.
Again, one guy out of thousands has had that result. And there are plenty of dyno results that say otherwise.
But you do what you want. Have fun.
The row box didn't pick up power because the bottleneck was the dirty old filters.
You own an AMG... pony up and get a set (of ROW airboxes, among other things)...
https://www.ecstuning.com/b-genuine-.../1560940306kt/
Thank you.
Thank you.
All ROW airboxes will come with new MAF sensors regardless of where you buy them.
