C63 AMG (W204) 2008 - 2015
Running too hot? Oil temp average 220F - 240F+. Yes another oil temp thread.
Old Jan 2, 2012 | 06:19 PM
enochroot's Avatar
2016 G550
Yet another oil temp question. Searching through old posts I can see its been discussed many times before.
2012 C63 P31 sedan, stock, just cat back Eisenmann exhaust.
Outside temp anywhere from 50F - 70F.
Transmission in C mode, if I drive around like an old lady for 15 minutes I'm at 220F+. It's never below 220F.
Transmission in S (or S+) mode, 230F - 240F.
Some light spirited driving will always yield the secondary engine fan turning on after 15 minutes (sounds like a vacuum cleaner)
Transmission in M. 240F+. Fan screaming like a vacuum cleaner.
Back in November I did some runs with xtyper and we ran our cars pretty hard. His 2011 C63 was a good 20F degrees cooler then my car and never had the fan come on.
After every run I was 240F+ and had the fan screaming.
How to explain the huge 20F difference between xtyper's C63 and mine when we did the multiple roll runs?
Took it by the dealership last month, they claim they did a couple "hot laps" around the block and temps looked normal. Oil level looked normal.
Anything to worry about? or are these really normal temps?
Just curious, any insight appreciated.
Old Jan 2, 2012 | 08:27 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
I'm always running 215 - 245...usually closer to 225 235.
Seems normal to me...
Old Jan 2, 2012 | 08:36 PM
BK63amg's Avatar
'16 GTS Solar
I'm rarely above 221 in normal driving. The temp ranges btwn 211-221 on average.
Old Jan 2, 2012 | 08:40 PM
alrasheed1991's Avatar
2011 C63AMG P31
It normal it happen to me allot with hot weather we have here in Saudi Arabia (Desert weather ) at noun the temperature in the summer gets to 48C And the Fan screaming as you describe it's normal i think the fan start working to cool down the engine oil temperature
thats All , and the highest temperature i reached is 131C engine oil temperature with hot weather so it's don't worry it is normal .
Any question Ask !
Abdullah
Old Jan 3, 2012 | 02:30 AM
_AMG_'s Avatar
C63
Alrasheed1991, I noticed in your sig that you have carbon ceramic brakes. Since when did MHP start selling CC rotors?
Mind posting a pic of your car?
Old Jan 3, 2012 | 09:03 AM
2011 C63AMG P31
Yea sure after I install them and they did recently relase it you can see it on MHP website
Old Jan 3, 2012 | 02:58 PM
houstonT's Avatar
My car runs 220 or so cruising on the highway...I haven't hammered it yet.
Peter
Old Jan 3, 2012 | 03:12 PM
enochroot's Avatar
2016 G550
Thanks for the feedback everyone.
houstonT, the break in period was painful!
Old Jan 3, 2012 | 03:56 PM
houstonT's Avatar
enoch - trust me, i have NOT been 100% compliant but have yet to really rail it.
Peter
Old Jan 3, 2012 | 06:06 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
My car usually runs around 210 to 215.. but the last 2 weeks, the temps have been jumping around between 220 and 231.... and the temps have been cold.... I'm worried that my cooling system may be flaking out...
Old Jan 3, 2012 | 06:47 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Average for me is 220f, in all modes, my 2011. I realize that our cars get hotter during traffic. The more congested, the hotter.
Old Jan 5, 2012 | 01:45 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Your car runs hotter oil than mine which is usually 204-220F. I once saw 245F on a mountain road on snow ice I could not overcome. With the synthetic there should be no concern up to 250 260F IMO.
Old Jan 21, 2012 | 11:01 AM
stopngo's Avatar
mercedes
Hello
I am new here and my question is this.
I am wondering how you all know your Oil Temperatures. Usually we refer to Coolant Temperatures.
Do you all have OIL TEMP Gauges? Do you also know what your coolant temperatures are? I ask this because I am curious as to how close the two temperatures are to each other in relative terms.
Thank you so much in advance
Old Jan 21, 2012 | 02:07 PM
motoman's Avatar
stoopngo, steering wheel button with 4 arrows...press leftmost once, then twice and see oil and cool temp . Press ok in center to keep on while driving, Cancels with ignition off. reset if desired
Old Jan 21, 2012 | 02:18 PM
motoman's Avatar
After destroying an AC ride around lawn mower I ventured into the rich jungle of oil data The lawnmower ran 300F worst case. I found that the SAE cats have a chart which shows doomsday temp called "flash." Anyway it's out at 390F on 10-30 oil - the oil is vaporized and ignites. Oil temp gauges typically go to 300-325F. Sumps should run above 200F to drive off moisture. The synthetics are made for high temps. The C63 probably has an oil thermostat to keep it hot. Worry at about 280F and running hotter without cool off. IMO
Old Jan 21, 2012 | 04:06 PM
stopngo's Avatar
mercedes
Thank you Motoman...........I dont know how I lived without the Web prior to this.
Old Jan 21, 2012 | 06:42 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
Your engine will go into limp mode way before you are at risk for temperature problems. Doesn't sound like you have an issue.
Old Jan 22, 2012 | 12:29 AM
jvanbrecht's Avatar
Originally Posted by stopngo
Hello
The oil temp and coolant temp are listed under the AMG menu on the screen inside the speedometer.
Old Jan 24, 2012 | 01:59 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
enochroot,
It's not a secondary engine fan you hear. It's the oil cooler fan located on the passenger side behind the bumper. As it tries to cope with the extrememly hot engine oil.
Old Jan 25, 2012 | 11:50 AM
C63newdude's Avatar
C63 AMG
Have them check your thermostat. My car never ever goes above 215-217 in normal driving and I went through 3 hot 110plus degrees summers in Tucson, AZ.
Old Jan 25, 2012 | 08:09 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
233-hottest oil temp.
201- " water temp.
Old May 21, 2012 | 04:57 PM
ctown113's Avatar
'12 C63 AMG,'11 Lexus RX450H,'10 VW Routan,'09 E92 ///M3 (Sold),'07 E85 Z4 ///M Roadster (Sold)
201- " water temp.
Saw mine at 249 degrees (Fahrenheit) last night
2012 C63 AMG Yes, I was driving pretty darn hard in S+
Old May 21, 2012 | 05:44 PM
Sirex63's Avatar
C63
I believe his thread says it arrived on the 8th of January 2012. Today is the 22nd of May.
I wonder why isn't installed till now
He says now :
I also believe he mentioned on January that he installed them !
sorry but that Due to shipping , and i have it installed with out any problem and realated to our Customs they open any box and they dont take any caution .
Abdullah
P.S : MHP rotors arrived damaged lol
Back to topic. My normal temp. in this season varies from 212F-215F @ 88F-95F weather temp. ( I'm avoiding using the car from morning till sunset where temp. raises to 110F minimum )
In a hard run it goes up to 224F and then cools down within minutes
Highest oil temp been reached is 252F due to hard drive.
Old May 27, 2012 | 11:43 PM
HoozyerdaddyC63's Avatar
C63
I ran into an issue today where my car decided to go into limp mode. I immediately checked my oil temp and it was 277 F. I couldn't downshift or anything.
I need to bring my car into the shop to make sure the outside temp gauge is correct because it seems too high, but today had to be over 100 F and I had the air conditioning on. As soon as I turned the A/C off the temp dropped to 274 F and I could downshift again.
From there it stayed around 266 F for the rest of the trip.
Maybe there is something else going on with the car because it didn't do much better on the ride home tonight when the temps were in the low 70's.
Old May 28, 2012 | 12:26 AM
ctown113's Avatar
Wow.. 277 is DEFINITELY the highest I have ever heard of...
In the short time that I've had my 2012 (1700 miles), I tend to see it get up to the high 240's.. 247 or 248 being the highest (of course while driving pretty hard in short bursts in S+ or M modes) and even those temps start bugging me out where I'll tone it down until it drops to at least 240...
(Yes, the fan is blowing or whistling like craZy as well)..
That said, have you or anyone else ever noticed that the other gauge below it
(I think it's the water temp stays at 199 degrees, no higher or lower, while the oil temp is going up and down??)
I'm not a scientist or a mechanic, but why is that???
btw, good luck w your issue and keep us posted
