C63 AMG (W204) 2008 - 2015
ACG Proud to Announce Brake Packages!
Old Jan 4, 2012 | 07:52 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
ACG W204 C63 Stage 1 Street Brake Package: $1,050.00 Shipped
- Endless MX72 Front and Rear Street/Track Brake Pads
- ACG Complete Stainless Steel Brake Line Kit
- Motul RBF 600 Racing Brake Fluid (2 500ML Containers)
ACG W204 C63 Stage 1 Race Brake Package: $1,200.00 Shipped
- Endless ME20 Front and Rear Track Brake Pads
- Motul RBF 660 Racing Brake Fluid (2 500ML Containers)
ACG W204 C63 Stage 2 Street Brake Package: $2,950.00 Shipped
- 360x36mm Front 2pc Slotted Racing Rotors
- 330x26mm Rear 2pc Slotted Racing Rotors
ACG W204 C63 Stage 2 Race Brake Package: $3,150 shipped
- 360x36 Front 2pc Slotted Racing Rotors
- 330x26 Rear 2pc Slotted Racing Rotors
Our 2 piece rotors are a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The rear rotors are approx 5-6lbs lighter per rotor then the stock units. 23.5lbs vs. 35.5lbs. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the ACG Brake system is in place, simply replace the cast iron rotor when needed for only $350 per corner.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors.
All items can be purchased separately, Ti Shim's are also available.
Old Jan 4, 2012 | 07:58 PM
James@ACG's Avatar
I've gotten a few PM's the rotors alone are $1050 for the Fronts, or $2000 for all 4.
Old Jan 4, 2012 | 08:04 PM
xtyper's Avatar
2013 E63 AMG
Nice James! No doubt a quality product for a very reasonable price.
May have make another trip down to SD soon.
Old Jan 4, 2012 | 08:07 PM
James@ACG's Avatar
Thanks Eric i just posted in your other tread, also we've decided to only offer slotted rotors as these are less prone to stress fractions from heat.
Old Jan 4, 2012 | 08:30 PM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
check my PM please
Old Jan 4, 2012 | 08:44 PM
James@ACG's Avatar
Originally Posted by jacob502
check my PM please
PM'ed you back Jacob
Old Mar 7, 2012 | 02:50 PM
James@ACG's Avatar
Rotors are back in stock!
ready to be shipped... let me know
Old Mar 7, 2012 | 03:34 PM
mthis's Avatar
Anything W/4Wheels
Nice packages
Can u pm me price for lines and fluid ?
Tnx
Old Mar 7, 2012 | 04:47 PM
Merc63's Avatar
C63 AMG
For the front rotors, what thickness are they and what is the wear limit in mm if you have please?
So 1050 for 2 front rotors? What do they weigh compared to the P30 2 piece rotors?
Old Mar 7, 2012 | 07:12 PM
gthal's Avatar
2012 C63 coupe
Just bought a set of pads, lines and fluid from James. Can't wait to get them on for the summer season.
Old Mar 7, 2012 | 08:47 PM
James@ACG's Avatar
The P30 2-piece front rotors weigh 29.5#'s, our 2pc rotors come in at 24.2#
Also keep in mind that along with weight reduction, our rotors have directional vented disk as well.
Wear limit is 34mm
Old Mar 7, 2012 | 08:49 PM
James@ACG's Avatar
Originally Posted by mthis
Nice packages
Tnx
SS lines and 2 bottles of Motul RBF600 is $220.00 shipped anywhere in the connected US.
Old Mar 7, 2012 | 11:21 PM
Merc63's Avatar
C63 AMG
Wear limit is 34mm
How many mm are they brand new?
Old Mar 15, 2012 | 03:36 PM
James@ACG's Avatar
36mm like stock
Old Jan 7, 2015 | 03:15 AM
0-60Motorsports's Avatar
W124 E280 95
PM SENT
