Sun shades?
if you fit any type of shade inside the car, behind the windscreen, the damage is really done, as the heat has already entered the car.
My "solution" is to fit a screen over the outside of the windscreen. I bought some "UV reflective" rubber sheet, cut it to the size of the windscreen (with little flaps on each side which will hold it tight by shutting the front doors).
Therefore you have a rubber sheet covering the whole of the outside of the windscreen, which completely protects the dashboard etc & keeps the heat out of the car....VERY useful in the land of Aus, where we have MASSIVE heat.
Cheers, Pickles.
Cheers, Pickles.
Cheers, Pickles.
It's just a thin anti U.V. rubber sheet you can buy anywhere in rolls....ya just cut it to shape with a scissors....ya don't even notice it when ya close the doors.
Cheers, Pickles.
I've got a couple of sheets only cut roughly to shape that I've used on several different cars over the years.
Without it, after a few hours in the sun, your steering wheel & top of dash will be really HOT.....not with this cover....they'll be UV protected & simply warm.
Cheers, Pickles.
